New Radiator Thermostat DANFOSS Ally
pipiche
Post by pipiche »
I could have an opportunity to work and integrate such Radiator Thermostat on the Zigate Plugin for Domoticz.
Anyone interested ?
https://zigbeealliance.org/zigbee_produ ... hermostat/
ronaldbro
Re: New Radiator Thermostat DANFOSS Ally
Post by ronaldbro »
Can’t find any pricing info yet, so don’t know yet. I have Bluetooth comets now and would like these more for sure. But the price tag will decide...
pipiche
Post by pipiche »
ronaldbro
Post by ronaldbro »
For 60 euro it isn’t on top of my wishlist. If I replace 6 or 8 valves it will be a lot of money and the return on investment is low.
competer
Post by competer »
I got one of these new radiator valves.
It works great, connected by Zigbee (Conbee II stick and Deconz)
there are 10 types of people in this world, those who understand binary and those who dont
pipiche
Post by pipiche »
competer wrote: Thursday 03 September 2020 12:09 I got one of these new radiator valves.
Yes, they have implemented their firmware in the right way, and are very compliant to the Zigbee Alliance Standard, so integration should be quiet straightforward
bas26
Post by bas26 »
@competer, how did you manage to pair the danfoss ally to your Conbee II ?
I tried searching for a Sensor in the Deconz app and resetting the Danfoss, but Deconz does not find the Danfoss.
I have the newest firmware and deconz version running on my Pi.
Hencor
Domoticz version: 2021.1
Post by Hencor »
Just another question:
Does anyone know if i can get a heating request status from the Ally? Can I check if the valve is open?
I want to use it to regulate the supplier temperatur only if there is a heating demand in a room.
pipiche
Post by pipiche »
With the ZiGate-Plugin integration, yes you get the Valve % so you have indeed the heating demand
Hencor
Post by Hencor »
Thanks for the quick response.
Sorry I was not precise enouth, I'm using Deconz. Is it also possible with it? I don't see a device with this information.
pipiche
Post by pipiche »
At least the device it self has the capability to report the Heating demand. May be @smanar will comment on that for deConz
Thorgal789
Post by Thorgal789 »
Hencor wrote: Wednesday 22 September 2021 10:22 Just another question:
IF I m right you will have 3 entries created in deconz, the setheatpoint, the temperature and a selector switch with mode (name is finishing by _mode), the last one can be used to check for device state.
Thelion
Domoticz version: 2022.1
Post by Thelion »
I'm looking at this setup with the Danfoss Ally an the Conbee II. Do I need anything else, besides these 2 and Domoticz (running on RPi) of course? The Deconz Github mentions a "Dresden Elektronik gateway". Do I need that?
Thorgal789
The "Dresden Elektronik gateway" is the conbee 2.
And this gateway can work with zigbee2mqtt or deconz.
Thelion
Post by Thelion »
Thorgal789 wrote: Sunday 28 November 2021 19:15 The "Dresden Elektronik gateway" is the conbee 2.
OK, great! Thanks for the quick response!
Thelion
Post by Thelion »
I do have another question.
I can't get the Danfoss Ally to pair with the conbee 2 and zigbee2mqtt. Everything is working, but the Danfoss keeps showing a blinking antenna.
I can see the controller in Domoticz, but that's about it.
Already reset the Danfoss to factory default, but also no go.
Any tips on this?
