yesterday i had one of the weirdest things.
I had a zwave device(pump) which aparently activated on it's own
looking at the log it seems it was activated by a dzvents script.
the thing is this script does not have the pump device in it
is there a way to tell what activated this device
so it looks like pir sensor triggered dzvents script which turned on switch 19(veranda) and then also triggered Tuinsproeier
2020-05-04 22:05:57.801 Status: OpenZWave: Alarm received (Home Security: Motion Detected at Unknown Location), NodeID: 16 (0x10)
2020-05-04 22:05:57.802 (Aeonlabs Z-wave stick Gen5) Light/Switch (Sensor)
2020-05-04 22:05:57.804 (Aeonlabs Z-wave stick Gen5) General/Alarm (Alarm Type: Burglar 7 (0x07))
2020-05-04 22:05:57.807 (Aeonlabs Z-wave stick Gen5) Light/Switch (PIR sensor)
2020-05-04 22:05:57.858 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2020-05-04 22:05:57.895 OpenZWave: Domoticz has send a Switch command! NodeID: 19 (0x13)
2020-05-04 22:05:57.897 (Aeonlabs Z-wave stick Gen5) Light/Switch (Veranda)
2020-05-04 22:05:58.326 MQTT: Topic: domoticz/in, Message: {"idx":339,"RSSI":10,"nvalue":0,"svalue":"22.1"}
2020-05-04 22:05:59.475 (Aeonlabs Z-wave stick Gen5) Usage (Watt Tuinlampen)
2020-05-04 22:05:59.479 (Aeonlabs Z-wave stick Gen5) General/kWh (kWh Tuinlampen)
2020-05-04 22:05:59.662 (Aeonlabs Z-wave stick Gen5) Light/Switch (Tuinsproeier)
2020-05-04 22:05:59.713 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2020-05-04 22:05:59.741 Status: Notification: Domoticz
2020-05-04 22:05:59.742 Notification sent (email) => Success
2020-05-04 22:05:59.742 Notification sent (browser) => Success
2020-05-04 22:05:59.874 Notification sent (telegram) => Success
so in my situation it turned on device veranda at 22:05:57 and turned on device tuinsproeier at 22:05:59
-- Script wat er voor zorgt dat de veranda verlichting automatisch aan gaat bij beweging
-- PIR sensor staat zelf ingesteld dat deze alleen werkt bij minder dan 5 lux
active = true,
devices = {
['PIR sensor'] = {'between sunset and 00:00'}
execute = function(domoticz, beweging)
if beweging.state == 'On' then
domoticz.devices('Veranda').switchOn().checkFirst().forMin(5)
}they both have dependency in it regarding timeframe.
-- Script zorgt er voor dat de tuinsproeier na inschakeling altijd weer uit gaat na 50 minuten
active = true,
devices = { ['Tuinsproeier'] = {'on 01/04-30/09'} }
execute = function(domoticz, switch)
local timestamp=domoticz.time.rawTime
if (switch.state == 'On') then
local results = domoticz.helpers.addRollingTextLine(domoticz, 'Status', 'Tuinsproeier ingeschakeld', '4')
domoticz.devices('Tuinsproeier').switchOff().afterMin(50)
--domoticz.notify("Domoticz", timestamp.."\r\n".."Tuinsproeier ingeschakeld", "telegram")
domoticz.globalData.tuinsproeierlaststatus = 'On'
if (switch.state == 'Off') then
--tuinsproeierlaststatus wordt gebruikt om geen onnodige off meldingen via telegram te krijgen
if domoticz.globalData.tuinsproeierlaststatus == 'On' then
local results = domoticz.helpers.addRollingTextLine(domoticz, 'Status', 'Tuinsproeier uitgeschakeld', '4')
--domoticz.notify("Domoticz", timestamp.."\r\n".."Tuinsproeier uitgeschakeld", "telegram")
domoticz.globalData.tuinsproeierlaststatus = 'Off'
