Login mix-up Thermosmart
Alain
Domoticz version: 2022.1
Post by Alain »
We have two homes next to each other that I am connecting via Domoticz. In each home we have a Thermosmart to control the heating. Aside from sometimes having a login error (also mentioned elsewhere ion this forum) I get that the two devices get mixed up after them logging in.
Instead of having both devices displaying the settings and readings from each separate device, I will have both hardware devices in Domoticz showing the values from just one device.
In reality Thermosmart 9 will be set to 20 degrees and reading a room temperature of 20.4 degrees. Thermosmart 11 will be set to 21 degrees and reading 21.6 degrees. Domoticz will, for instance, show both 9 and 11 as being set to 21 degrees and reading 21.6. It can also be vice-versa.
If I go to hardware and select each Thermosmart and press "Update", the login is repeated and the values correspond to what they should be. How can this be happening? And how can I prevent this? It's rather annoying, as because of another issue I'm still having with a plugin causing Domoticz to crash a few times a day, this happens too often.
For now, I have removed one of the hardware devices, but would like to add it again in the near future.
Hue | Zigbee2Mqtt | MQTT | P1 | Xiaomi | RFXCom | Modbus | TP-Link | Node-Red | Grafana |
Alain
Re: Login mix-up Thermosmart
Post by Alain »
Has anyone else had this problem?
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
I have a Thermosmart and Honeywell running together, works fine of course. I had lots of trouble with the Thermosmart (couldn't log in), which is solved in the 2020.1 version. Be sure to have that version (or rather 2020.2), if you don't have it already, as Thermosmart support is improved in these versions
Alain
Post by Alain »
i run the latest version. Because of some other problems I was having, I created a VM to run Linux, but that didn't solve this problem though.
