cookie support in dzVents
akamming
Post by akamming »
i created a dzvents script which sends a Notification if i have to put my garbage container at the road by accessing the API of the company which collects the garbage. This API uses cookies. And since domoticz.openURL does not support cookies i had to use curl. Unfortunately this does not work as an asynchronous mechanism, so sometimes when the internet is slow my domoticz 'hangs' on completing this request.
my suggestion would therefore be to extend the domoticz.openURL function with cookiesupport, by adding a 'cookie' field to the definitiion, e.g.
domoticz.openURL({
url = 'http://domain/path/to/something',
method = 'POST',
callback = 'mycallbackstring',
cookie = 'cookiedata'
postData = {
paramA = 'something',
paramB = 'something else'
so i can change this curl statement to domoticz.openURL command
curl --cookie "RovaLc_inwoners={\"Id\":160266,\"ZipCode\":\"8013TP\",\"HouseNumber\":\"10\",\"HouseAddition\":null,\"Municipality\":\"Zwolle\",\"Province\":null,\"Firstname\":null,\"Lastname\":null,\"UserAgent\":\"\",\"School\":null,\"Street\":null,\"Country\":null,\"Portal\":null,\"AreaLevel\":5,\"City\":\"Zwolle\",\"Ip\":null}" https://www.rova.nl/api/TrashCalendar/GetCalendarItems?portal=inwoners
Would this be possible? If not? Is there another way to make this an asynchronous call in dzvents?
stephanvdplas
Domoticz version: 2023.1
Re: cookie support in dzVents
Post by stephanvdplas »
Bump
This would be a very nice step in making my implementation OS-independent.
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
stephanvdplas wrote: Tuesday 05 May 2020 13:29 This would be a very nice step in making my implementation OS-independent.
I would also like to have this functionality in domoticz / dzVents but this cannot be solved in dzVents. DzVents just uses the openURL API domoticz provides. Until then using io.popen or os.execute with a curl running in the background and a follow up triggered by a customEvent is a proven and asynchronous work-around that will not block the eventSystem.
I am aware that the dzVents- and OS script code cannot be the same for Windows and for Linux based systems but it is possible to use such an approach for both OS.
stephanvdplas
agreed, but still would be nice if things could be solved native-dzvents.
