Trigger scene with multiple conditions  [Solved]
GuidoP18
Post by GuidoP18 »
Hy All,
I had a blocky script that checked a dusk sensor and a presence detector to turn on the scene.
Unfortunately the dusk sensor broke and I've bought an Fibaro Multi sensor.
So now I would like to make a script that checks the lux, is there is motion, and also the presence detector.
Something like this:
If lux is smaller than 50 lux and there is motion detected or presence dector is active than turn on scene.
I can make this in blocky, but every time the lux is updated the scene wil be triggered even if it is already on.
Can anybody help me to make a script that doesn't trigger every time?
Guido
Re: Trigger scene with multiple conditions
GuidoP18 wrote: Monday 04 May 2020 14:46 If lux is smaller than 50 lux and there is motion detected or presence dector is active than turn on scene.
Can you try this and reply with your findings?
return
    on =
        devices =
            'motion sensor', -- change to names of sensors
            'presence sensor',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR if all OK
        marker = 'scene trigger'
    data =
        onTime =
            initial = 0 ,
    execute = function(dz, item)
        local lux = dz.devices('lux sensor').lux  -- Change to name of sensor
        local myScene = dz.scenes('my scene') -- Change to name of scene
        local sceneTime = myScene.lastUpdate.dDate
        dz.log(item.name .. ' state is: ' .. item.state .. ' (active = '.. tostring(item.active) .. ')',dz.LOG_DEBUG )
        dz.log('sceneTime is: ' .. sceneTime .. '; onTime = ' .. dz.data.onTime ,dz.LOG_DEBUG )
        if item.active and lux < 50 and sceneTime > dz.data.onTime then
            myScene.switchOn()
            dz.data.onTime = dz.time.dDate
GuidoP18
Post by GuidoP18 »
The only thing I see in the log is this.
2020-05-04 15:50:29.319 (Zwave+) Lux (Woonkamer Lux)
2020-05-04 15:50:29.402 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-05-04 15:50:29.447 Status: dzVents: Debug: Processing device-adapter for Woonkamer Lux: Lux device adapter
2020-05-04 15:50:29.447 Status: dzVents: Debug: dzVents version: 3.0.2
2020-05-04 15:50:29.447 Status: dzVents: Debug: Event triggers:
2020-05-04 15:50:29.447 Status: dzVents: Debug: - Device: Woonkamer Lux
GuidoP18 wrote: Monday 04 May 2020 15:54 The only thing I see in the log is this.
Probably because the script does not trigger on Lux but only on motion and presence sensor.
GuidoP18
Post by GuidoP18 »
Yes you're right.
changed it tot the lux sensor and I got this
2020-05-04 16:00:01.096 Status: dzVents: Debug: - Device: Woonkamer Lux
2020-05-04 16:00:01.155 Status: dzVents: Info: Handling events for: "Woonkamer Lux", value: "1584"
2020-05-04 16:00:01.155 Status: dzVents: Info: scene trigger: ------ Start internal script: Script #2: Device: "Woonkamer Lux (Zwave+)", Index: 118
2020-05-04 16:00:01.157 Status: dzVents: Debug: scene trigger: Processing device-adapter for Thuis: Scene device adapter
2020-05-04 16:00:01.157 Status: dzVents: Debug: scene trigger: Woonkamer Lux state is: 1584 (active = false)
2020-05-04 16:00:01.157 Status: dzVents: Debug: scene trigger: sceneTime is: 1588599092; onTime = 0
2020-05-04 16:00:01.158 Status: dzVents: Info: scene trigger: ------ Finished Script #2
GuidoP18 wrote: Monday 04 May 2020 16:01 Yes you're right.
Maybe I misunderstood but I thought your requirement was that it would not trigger on lux changes but only on on motion / presence and that the action was depending on Lux value.
GuidoP18
Post by GuidoP18 »
Yes that is correct. I changed the wrong device. I wil change the presence state an check again.
GuidoP18
Re: Trigger scene with multiple conditions  [Solved]
Post by GuidoP18 »
It works! Thank you!
2020-05-04 16:26:50.071 Status: dzVents: Info: Handling events for: "Guido", value: "Off"
2020-05-04 16:26:50.071 Status: dzVents: Info: scene trigger: ------ Start internal script: Script #2: Device: "Guido (Presence detection)", Index: 78
2020-05-04 16:26:50.073 Status: dzVents: Debug: scene trigger: Processing device-adapter for Woonkamer Lux: Lux device adapter
2020-05-04 16:26:50.073 Status: dzVents: Debug: scene trigger: Processing device-adapter for Thuis: Scene device adapter
2020-05-04 16:26:50.073 Status: dzVents: Debug: scene trigger: Guido state is: Off (active = false)
2020-05-04 16:26:50.073 Status: dzVents: Debug: scene trigger: sceneTime is: 1588599092; onTime = 0
2020-05-04 16:26:50.074 Status: dzVents: Info: scene trigger: ------ Finished Script #2
