Quite new on Domoticz and testing and trying to learn
I bought a Neo Coolcam Z-WAVE PLUS 2
Inclusion went fine, devices went fine, motion detection, lux parameter, temperature all ok.
However when I read the manual if parameter 8 is enabled it should listen to parameter 5. (see pictures below)
You see that the Lux is above 1000 but that both switches on movement are switched on.
I totally expected to see at least one off based on the settings 5 and 8..
Where do I go wrong? I want based on Lux parameter and movement the light to be switched on, of course that can be programmed by if lux and if motion .. but I expect that one of the devices should do that automatically right?
Kind regards robbert
