Hi Pipiche,
It looks like there is a problem pairing Aqara THB sensors with the latest beta.
I successfully paired hue bulbs, tradfri, hue remote, Aqara opple switch, Aqara door sensors but the Aqara THB just won’t bind.
I tried 3 different THB sensors already.
Don’t see anything in the logs.
Hope you can help.
Regards Ronald
ZiGate paring Aqara THB sensor
Re: ZiGate paring Aqara THB sensor
Just did one without any issue.
Wiki is available here.
Zigbee for Domoticz FAQ
- Domoticz version: 2020.2
Found the problem. I had 5 THB sensors to connect and only one worked. I changed the battery of that one some time ago.
After changing the battery of the other 4 it worked without any problem.
Guess they had enough juice to send the temperature but not for a pairing process.
yes, that is quiet often the case. You can also feel it at the power of the blue led which is very low
