What I am trying to achieve is to use the dewpoint in a room to trigger an action that closes the valves on the underfloor cooling in that room when the temperature above the floor is at a safe level (say 2 degrees) above the dewpoint to avoid condensation on the floor. I was planning on measuring both temperature and dewpoint with an Aeotec Multisensor 6 (but if there are better sensor options, I'm open to suggestions.
Dewpoint
ErikM
Dewpoint
Is there anyone who can explain to me how to use the dewpoint device in a Blockly script? The wiki doesn't offer any explanation on it and I'm still very new to using Blockly (or any form of scripting, for that matter).
knielen
Re: Dewpoint
As far as I know that's not possible with Blockly. You can compare the value of the dewpoint with the actual temperature. Or you can compare the dewpoint with a fixed number. But it's not possible to compare with the actual temperature and an offset.
Try to master dzvents, pretty steep learning curve, but eventually you need it anyway
ErikM
Re: Dewpoint
Darn... I already found Blockly to be a steep learning curve and when I look at a dzvents or lua script I break out in a sweat...
All the indentation makes it look extremely complicated and while Dewpoint is a device in Blockly, it is not in the normal device list. This is looking to be a lot more complicated than I had expected it to be...
jake
Re: Dewpoint
That was my first thought about lua (before dzvents was around) too. I didn't look forward to the learning curve. But when you want to do something more complicated than just a single if then else, it becomes a nightmare in blockly. So at some point I was fed up with it and decided to go for it. In the dzvents wiki is plenty of material to learn and 'steal' from. Over time I collected my scripts from using parts from other scripts and reuse of my own scripts. For instance I always start with a copy of an existing script, so the base is correct.ErikM wrote:Darn... I already found Blockly to be a steep learning curve and when I look at a dzvents or lua script I break out in a sweat...All the indentation makes it look extremely complicated and while Dewpoint is a device in Blockly, it is not in the normal device list. This is looking to be a lot more complicated than I had expected it to be...
rrozema
Re: Dewpoint
dzVents isn't hard. I've written you below example in 15 minutes. I hope the comments in the code will help you understand what this code does and opens up the opportunity to learn dzVents fast.
-- Change the names below to match your device names.
-- When changing the names take care to use the exact same
-- case as used in your device names.
-- For example: "TempHum" is not the same as "Temphum".
local TEMPERATURE_DEVICE_NAME = 'Keuken: TempHum'
local SWITCH_DEVICE_NAME = 'Keuken: Cooling'
-- I like to use variables for device names to avoid mistyping a
-- name when it is referenced multiple times in a script. I make
-- these variable names in all caps, but that is nu requirement.
-- I do this to easily identify where the variable is used.
-- Please also not the use of "local" in front of every declaration
-- of a variable. If you don't put that "local" in front of your
-- variables the script will run without problems. If however you
-- use in another script a variable with the same name, the variables
-- wil get mixed-up. So always specify the word "local" in front of
-- every variable declaration.
-- Indentation (spaces or tabs in front of lines) is not a requirement,
-- but it does help keep the code readable. So do yourself a favor,
-- always use proper indentation.
-- The "devices" section defines for which devices the execute-section
-- below will be executed. It can contain a list of device names
-- separated by a , . In this example only 1 device is listed
-- so no comma needed.
devices = {
-- This execute section is the code that will get executed when the device
-- in the devices section changes value.
-- The way to show output in your log file (if the log level is high enough).
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
-- Ask domoticz for a device object with the name of SWITCH_DEVICE_NAME.
local switch = domoticz.devices(SWITCH_DEVICE_NAME)
-- If you misspelled the name a nil-value will be returned.
-- "==" is equals, "~=" is not equals.
-- Every "if <condition>" must be followed by a "then", which must be
-- closed by an "end". Optionally an "else" can be used in between the
-- "then" and the "end".
if nil == switch then
-- This is another message i want shown in the log, here I specify
-- LOG_ERROR to make the text show up in bold and red in the log.
domoticz.log("Switch device " .. SWITCH_DEVICE_NAME .. " not found.", domoticz.LOG_ERROR)
-- what properties a device exposes depends on the type of the
-- device. Documentation is available in the wiki:
-- https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting
-- In this case I tried to implement what I think you asked for:
-- if the temperature is at least 2 degrees above the dewPoint
-- the switch must be switched off, if it falls below that it must
-- be switched on again.
if device.temperature >= device.dewPoint + 2 then
-- .switchOff() changes the devices' state to "Off". I don't
-- like to send to many commands, so I specify .checkFirst()
-- to make sure that no "Off" command is sent if the device
-- is already "Off".
switch.switchOff().checkFirst()
switch.switchOn().checkFirst()
end -- This is the "end" for the execute section.
