Blocky to DzVents Curtains  [Solved]
wouterlet
Post by wouterlet »
Sorry for another Noob question.
I'm really trying around, but still got a lot to learn.
I attached my Blocky, and underneath my translation to DzVents:
		timer = {'at 9:00', 'at 19:00', 'at 21:00'},
		devices = {'UV Accuweather'}
    execute = function(domoticz, timer)
	if  dz.time.matchesRule('at 09:00') or
	    (dz.devices('UV Accuweather') < '2' and
	    dz.time.matchesRule('> 09:00') and
	    dz.time.matchesRule('< 19:00') and
	    dz.variables('Var Luik Pim Ivo') == 1) then
	    dz.devices('Gordijn Ivo').switchOff()
	    dz.devices('Gordijn Pim').switchOff()
	    dz.variables('Var Luik Pim Ivo').set(0)
	if  dz.time.matchesRule('at 09:00 on mon, tue, wed, thu, fri') then
	    dz.devices('Gordijn Ons').switchOff()
	    dz.variables('Var Luik Ons').set(0)
	if  dz.devices('UV Accuweather') < 2 and dz.time.matchesRule('> 14:00') and  dz.time.matchesRule('< 19:00') and dz.variables('Var Luik Ons') == 1 then
    if dz.time('< 12:30') and dz.devices('UV Accuweather') > 1 and dz.variables('Var Luik Pim Ivo') == 0 then
        dz.devices('Gordijn Ivo').switchStop()
	    dz.devices('Gordijn Pim').switchStop()
	    dz.variables('Var Luik Pim Ivo').set(1)
    if dz.time('< 14:30') and dz.devices('UV Accuweather') > 1 and dz.variables('Var Luik Ons') == 0 then
        dz.devices('Gordijn Ons').switchStop()
	    dz.variables('Var Luik Ons').set(1)
	if  dz.time.matchesRule('at 19:00') then
	    dz.devices('Gordijn Ivo').switchOn()
	    dz.devices('Gordijn Pim').switchOn()
	if  dz.time.matchesRule('at 21:00') then
	    dz.devices('Gordijn Ons').switchOn()
My log gives me back:
2020-05-01 21:26:10.113 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Gordijnen Boven DzVents
2020-05-01 21:26:10.113 Error: dzVents: Error: (3.0.2) ...ts/dzVents/generated_scripts/Gordijnen Boven DzVents.lua:7: attempt to index a nil value (global 'dz')
Line 7 is: if dz.time.matchesRule('at 09:00') or
I also tried without 'at', so only '09:00', but that gave the same error.
Any help would be really appreciated!
Re: Blocky to DzVents Curtains
wouterlet wrote: Friday 01 May 2020 22:05
execute is here a function with 2 parms.
first parm (here named domoticz) is the domoticz object which is in fact a table with all devices, variables, cameras, scenes, groups, etc )
2nd parm (here named timer) is the object that triggered this script.
so if you refer in the rest of the script to the domoticz object (like you try in dz.time.matchesRule) you should use the same name as in the function call.
So either you change
to
function(dz, timer)
or you change 'dz' to ' domoticz' everywhere else in the script.
wouterlet
Re: Blocky to DzVents Curtains  [Solved]
Post by wouterlet »
Someone allready told you you're amazing?
Always so quick answers with a nice explanation. I changed it and now it went to the next error. But at least I could solve thisone with google.
Thanks man!
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
@Wouterlet, Could you please post your end-scripts in your posts. The one's that are working for you?
Now I see a lot of code and suggestions to change them, but not sure how the end result would look like. :? I'd like to learn dzvents too but need some more working examples.
