Blocky to DzVents Bathroom Fan  [Solved]
wouterlet
Post by wouterlet »
I have an Aeotec Multisensor 6, this gives a device Temp/Hum.
For this script I only need the humidity, but I can't see how to select this. See my code underneath, I also tried device.humidity, but it gives the same result. The subtype of the device is WTGR800.
		devices = {'Temp/Hum Badkamer'}
    if device.hum('Temp/Hum Badkamer') > 60 then
    dz.devices('Afzuiging Badkamer').switchOn()
    if device.hum('Temp/Hum Badkamer') < 60 then
    dz.devices('Afzuiging Badkamer').switchOff().afterMin(15)
This gives the following error in my log:
2020-05-01 21:18:38.175 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Afzuiging Badkamer DzVents
2020-05-01 21:18:38.175 Error: dzVents: Error: (3.0.2) ...dzVents/generated_scripts/Afzuiging Badkamer DzVents.lua:6: attempt to call a number value (field 'humidity')
Re: Blocky to DzVents Bathroom Fan
wouterlet wrote: Friday 01 May 2020 22:11 This gives the following error in my log:
Can you try this
return
    on =
        devices =
            'Temp/Hum Badkamer',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'badkamer humidity',
    execute = function(dz, item)
        local afzuiging = dz.devices('Afzuiging Badkamer')
        if item.humidity > 60 then
            afzuiging.switchOn().checkFirst()
        elseif afzuiging.state ~= 'Off' then
            -- afzuiging.switchOff().afterMin(15) -- This will re-schedule the switchoff many times during the 15 minutes
wouterlet
Re: Blocky to DzVents Bathroom Fan  [Solved]
Post by wouterlet »
Thanks, that works great like that!
