Popp Z-rain
Popp Z-rain
Greetings
After my Oregon Scientific 433mhz rain gauge broke I got me a Z-wave rain gauge instead. Seems much more robust than the Oregon one. I've got the Aeon Z-stick connected to my Pi3 running Domoticz beta 4.11590 with one other Z-wave node connected, a Fibaro switch.
Pairing the Z-rain was pretty easy and Domoticz sees it as a rain rate/Custom sensor and rain sensor. However when I test the gauge, a few hours after pairing, by tipping a cup of water into the bucket only the rain rate is updated. The rain amount is not.
Also the Domoticz logs gives the error message when I include the Z-rain gauge, don't know if it's related.
"2020-01-01 13:28:22.390 Error: OpenZWave: Value_Changed: Unhandled value type ZDTYPE_SWITCH_NORMAL (2). Node: 14 (0x0e), CommandClass: SENSOR MULTILEVEL, Label: General Purpose, Instance: 1, Index: 2 (OpenZWave.cpp:3188)"
Any idea what this is?
/Fredrik
/Fredrik
kevster
Re: Popp Z-rain
Did you get any further with this. I'm looking for a new guage too...
Snowtiger
- Domoticz version: 4.10915
Re: Popp Z-rain
It looks like it's interpreting this device as a Switch, 1 value, opposed to it being a Sensor multi level device - 1 instance, 2 index.
The module OpenZwave.cpp can not detect it as a multi level device and therefor throws this error in the specified line number.
Is it Popp product code 700168? If it is, then it is in the Zwave product database.
Re: Popp Z-rain
If it's in the Zwave product database it should work, no?
Snowtiger
Popp Z-rain
Yes, it should work
BTW to be precise - it is the OpenZwave 'database' which is incorporated into Domoticz.
Abber
Re: Popp Z-rain
How did this end? Does the Popp Z-rain work as expected? Is the rain amount monitoren correctly in Domoticz?
I am considering to buy the Popp z-rain, but fot €80 I want to be sure that the amount of rain is monitored correctly!
Thanks for letting me know!
mickmack82
Re: Popp Z-rain
For what it's worth, i use this device for over a year without any problems. Rain rate and total amount of rain is updated as expected.
Abber
Re: Popp Z-rain
Thanks Mickmack! Now I dare to invest my €80
Since you are using it for more than a year now, how is the accuracy? Does it register little amounts of rain as well?
mickmack82
Re: Popp Z-rain
It reports the rainfall with 0.5mm accuracy. I never compared it to a official rain gauge though. But overall I am quite satisfied with this device.
For the problem above: try to refresh node info. Not only from the ozw panel but also from the domoticz hardware page. That did resolve some zwave errors with other zwave devices generating messages like this.
Abber
Re: Popp Z-rain
Ok thanks. I am going to order one.
mickmack82
Re: Popp Z-rain
After the update to the 2020 version I also receive the error mentioned in the first post:
Unhandled value type ZDTYPE_SWITCH_NORMAL (2). Node: 15 (0x0f), CommandClass: SENSOR MULTILEVEL, Label: General Purpose, Instance: 1, Index: 2 (OpenZWave.cpp:3189)
However, rainrate and rainfall is updated as it should.
Any progress with this?
Kyrille
- Domoticz version: 2020.01
Re: Popp Z-rain
I just discovered this topic and I have exactly the same issue as you. I created a new ticket yesterday (https://www.domoticz.com/forum/viewtopi ... 24&t=32312) and I am still investigating. Even if the device is still working fine, I now receive emails everyday (I want to be warned when Domoticz encounters an error, and it happens for each exchange between the controller and the z-rain).mickmack82 wrote: Saturday 18 April 2020 17:53 After the update to the 2020 version I also receive the error mentioned in the first post:
Regards.
Raspberry Pi 4 (8GB) & 3B+ (buster) / Conbee II / Z-Stick Gen 5 / RFXCOM 433 XL / Domoticz 2020.02
Pi zero 2 ordered
Pi zero 2 ordered
mickmack82
Re: Popp Z-rain
Did some more digging and found the following:
The section of code mentioned in the error (line 3188 in OpenZWave.cpp) handles the datatypes bool, byte, string and list.
However the datatype defined in Config/popp/700168.xml, for index 1 is "short". All other indexes have datatype "byte".
Could it be that index 1, which has "short" as a datatype is causing this error?
The error message mentions index 2, but that index has "byte" as datatype, so that should be ok.
if (vType == OpenZWave::ValueID::ValueType_Bool)
if (bValue == true)
intValue = 255;
intValue = 0;
else if (vType == OpenZWave::ValueID::ValueType_Byte)
if (byteValue == 0)
intValue = 0;
intValue = 255;
else if (vType == OpenZWave::ValueID::ValueType_String)
if (commandclass == COMMAND_CLASS_COLOR_CONTROL)
//New color value received, not handled yet
return;
else if (vType == OpenZWave::ValueID::ValueType_List)
//Color Index changed, not used
return;
_log.Log(LOG_ERROR, "OpenZWave: Value_Changed: Unhandled value type ZDTYPE_SWITCH_NORMAL (%d). Node: %d (0x%02x), CommandClass: %s, Label: %s, Instance: %d, Index: %d (%s:%d)", vType, NodeID, NodeID, cclassStr(commandclass), vLabel.c_str(), vID.GetInstance(), vID.GetIndex(), std::string(__MYFUNCTION__).substr(std::string(__MYFUNCTION__).find_last_of("/\\") + 1).c_str(), __LINE__);
return;
<Value genre="config" index="1" instance="1" label="Rain Counter" max="32000" min="0" size="2" type="short" units="mm" value="0">
<Help>
Ths values shows the total count of rain from the moment of inclusion in mm water level. By writing this value this counter can be reset.
Default Value: 0
</Help>
</Value>
<Value genre="config" index="2" instance="1" label="Rain Start Command" max="99" min="0" size="1" type="byte" units="" value="99">
<Help>
This BASIC Set Command value is sent out into Association Group 2 when the device detects start of rain.
Default Value: 99
</Help>
</Value>
Re: Popp Z-rain
This issue is fixed in the latest beta.
Verstuurd vanaf mijn Nokia 8.1 met Tapatalk
commentator
Re: Popp Z-rain
had one for a year, then it stopped working when it was raining 55mm/hour. It was complete wet inside the deviceTheHoff wrote: Wednesday 01 January 2020 12:26 Greetings
/Fredrik
- Solderbro
- Domoticz version: 2020.1
Re: Popp Z-rain
Let's figure that out, i changes the term in the popp file to byte and will see what happens. Because this bug is the major annoying thing, you have to total disable the email alerts or it spam your inbox every 5 minutes with the popp error.
General question, can we download beta and extract only the bugged files for the stable?
Solderbro
Solderbro
Raspi 3B+RTC, SSD 128GB, Aeotec Gen5, Eurotronic SpiritZ, Fibaro FRGBW, Zipato PIR, Everspring AN180, Neo Coolcam Plug, Fibaro FGMS, Neo Coolcam Doorsensor, Popp Z-Weather
