My configuration is Domoticz + ESPEasy + MQTT.
I'm using a virtual switch to ON/OFF an SSR(relay) attached to ESPEASY (using MQTT protocol).
And it works like a charm! I can ON/OFF SSR by using Domoticz switch.
Then I added a physical button to ESPEasy and it can ON/OFF virtual button in Domoticz (using MQTT), but it doesn't work.
So clicking the physical switch Domoticz changes state properly but it doesn't take effect on SSR.
When I click in Domoticz virtual switch everything works well - SSR goes on/off.
How to resolve this problem? (configuration/scripting)?
best regards
Lukas
Domoticz + ESPEasy + MQTT +SSR + button problem
- FireWizard
Re: Domoticz + ESPEasy + MQTT +SSR + button problem
@lukamati
I think, you should have a look at: https://www.domoticz.com/forum/viewtopi ... hilit=mqtt
Best regards
@lukamati
Best regards
