Backup Domoticz
Mrtn83
Backup Domoticz
Post by Mrtn83 »
I have created a script with the wiki ( https://www.domoticz.com/wiki/Daily_ba ... ternal_hdd ) to backup the database and the scripts to my NAS. It al works great besides the fact that the database file only contains the message unauthorized. If I FTP to the domoticz backup folder access is denied aswel. What am I doing wrong?
jvdz
Domoticz version: 4.107
Re: Backup Domoticz
Post by jvdz »
Are you using an Userid/Password for 127.0.0.1 or LAN ip addresses?
In that case you need to include the userid:password in the url:
/usr/bin/curl -s http://$userid:$password@$DOMO_IP:$DOMO_PORT/backupdatabase.php > /tmp/$BACKUPFILE
Jos
Mrtn83
Re: Backup Domoticz
Post by Mrtn83 »
I used what was in the wiki:
/usr/bin/curl -s http://$DOMO_IP:$DOMO_PORT/backupdatabase.php > /tmp/$BACKUPFILE
jvdz
Re: Backup Domoticz
Post by jvdz »
understood, but the question was whether you are using security in Domoticz for the IP address you have specified in the batch file? ;)
When that is the case you need to change that line as indicated or when you run it on the same server you could use 127.0.0.1 for DOMO_IP and add that to the networks in system setup: "Local Networks (no username/password):"
Jos
Mrtn83
Re: Backup Domoticz
Post by Mrtn83 »
Took me while to get back on to this subject. But you're suggestion fixed the problem.
