Qubino ZMNHADx 1 Relay not refreshed
hestia
Domoticz version: 2022.1
Post by hestia »
I've a Qubino (Goap) ZMNHADx Flush 1 Relay+ that remains On in Domoticz while it was switched off with the real device.
When I look at the OpenZWave Control Panel it is on On also! But, just after as I look again in Domoticz the state is Off, so it is ok again.
But it was a wrong state during all the night!
What to do to fix it?
Version: 2020.1 (build 11970)
Z-Wave Plus Z-Stick Gen5 OpenZWave USB Version: 1.6-1033-g3661f170
ronaldbro
Re: Qubino ZMNHADx 1 Relay not refreshed
Post by ronaldbro »
Hi Hestia, looks like the same problem you encountered before. Did you check the lifeline? Group 1 configured to 1 or 1.1.
Gr Ronald
hestia
Post by hestia »
Hi Ronald, thanks for your advice
I kept the config files provided by 2020.1.
I've checked the lifeline and it is Group 1. I also have 1 in Group2 and Group9. I don't know if it is issue related.
I also find the same issue with Qubino (Goap) ZMNHBDx Flush 2 Relays+, and there there is 1.1
