nighttime not working  [Solved]
molnaratti
Post by molnaratti »
I want to turn on my outdoor lights at night. Unfortunately, for some reason, it always turns on, ignoring the 'at nighttime' option. What do I mess up?
      timer = { 'at nighttime' },
      devices = { 'terasz mozgas' }
      if (item.isTimer) then
         -- the timer was triggered
         domoticz.devices('terasz').switchOff()
         domoticz.devices('Pince elott kulteri l').switchOff()
      elseif (item.isDevice and item.active) then
         -- it must be the detector
         domoticz.devices('terasz').switchOn().forMin(6)
         domoticz.devices('Pince elott kulteri l').switchOn().forMin(6)
Re: nighttime not working
molnaratti wrote: Monday 13 April 2020 13:51 I want to turn on my outdoor lights at night. Unfortunately, for some reason, it always turns on, ignoring the 'at nighttime' option. What do I mess up?
Thx for reporting. Seems like a bug in dzVents. Until fixed you can use
'every minute at nighttime'
if you want the script to be processed every minute during nighttime or
'at sunset'
if you want the script to be processed only at the start of nighttime
BTW. you are now switching the devices Off at nighttime in your script
molnaratti
Thanks for the help.
Unfortunately, "every minute at nighttime" and "at sunset" doesn't work either.
Domoticz2020.1 (build 11835)
molnaratti wrote: Monday 13 April 2020 14:26 Thanks for the help.
Checked this again but it is working as expected. Are you sure Eventsystem and dzVents are enabled ? I tested with the script below so you should see lines in the log like:
2020-04-13 21:21:00.074  Status: dzVents: Info: ------ Start internal script: dz timer nighttime:, trigger: "at nighttime"
2020-04-13 21:21:00.074  Status: dzVents: !Info: item.trigger is: at nighttime
2020-04-13 21:21:00.075  Status: dzVents: Info: ------ Finished dz timer nighttime
return
    on =
        timer =
            'at nighttime',
        devices =
            'terasz mozgas'
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'nighttime',
    execute = function(dz, item)
        dz.log('item.trigger is: ' .. item.trigger,dz.LOG_FORCE)
        if item.isTimer then
            dz.devices('terasz').switchOff()
            dz.devices('Pince elott kulteri l').switchOff()
        elseif item.isDevice and item.active) then
            dz.devices('terasz').switchOn().forMin(6)
            dz.devices('Pince elott kulteri l').switchOn().forMin(6)
molnaratti
waaren wrote: Monday 13 April 2020 21:22
return
    on =
        timer =
            'at nighttime',
        devices =
            'terasz mozgas'
    logging =
Yes, Eventsystem and dzVents enabled. I modified the script as suggested, but the nighttime log will not be:
2020-04-22 13:04:02.553 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Script #4.lua
"2020-04-22 12:57:00.742 Status: dzVents: Info: ------ Finished halo_ajto_warn
2020-04-22 12:57:00.742 Status: dzVents: Info: ------ Start internal script: halo_klima_futes_dz:, trigger: "at 7:30-21:46"
2020-04-22 12:57:00.753 Status: dzVents: Info: ------ Finished halo_klima_futes_dz
2020-04-22 12:57:00.753 Status: dzVents: Info: ------ Start internal script: hatso_ajto_warn:, trigger: "every minute"
2020-04-22 12:57:00.757 Status: dzVents: Info: ------ Finished hatso_ajto_warn
2020-04-22 12:57:00.758 Status: dzVents: Info: ------ Start internal script: Kandallo termosztát:, trigger: "every minute"
2020-04-22 12:57:00.766 Status: dzVents: Info: ------ Finished Kandallo termosztát
2020-04-22 12:57:00.767 Status: dzVents: Info: ------ Start internal script: radiator_dz:, trigger: "every minute"
2020-04-22 12:57:00.767 Status: dzVents: Info: ------ Finished radiator_dz"
i checked the raspberry clock with the date command, ok.
The problems came when updating to the new stable, now I switched to devel branch but it didn't solve.
I don't understand where the problem might be.
Thank you for your help, sorry for my bad English.
molnaratti wrote: Wednesday 22 April 2020 13:02 Interestingly, only new dzvents scripts do not take the nighttime switch into account.
Maybe I don't understand the intention of the script correctly. Can you describe in words what you expect the script to do during daytime and what you expect it to do during nighttime ?
molnaratti
waaren wrote: Wednesday 22 April 2020 13:13
Only turn on the lamp for 5 minutes at night when the motion sensor is turned on, currently it always turns on, not just at night.
molnaratti wrote: Wednesday 22 April 2020 14:02 Only turn on the lamp for 5 minutes at night when the motion sensor is turned on, currently it always turns on, not just at night.
You should use this syntax in the on = section to achieve that.
return
    on =
        devices =
            ['terasz mozgas'] = { 'at nighttime' },
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all works OK
        marker = 'device at nighttime',
        local terasz = dz.devices('terasz')
        if item.active then
            terasz.cancelQueuedCommands()
            terasz.switchOn().checkFirst()
            terasz.switchOff().afterSec(300)
molnaratti
Re: nighttime not working  [Solved]
Thank you waaren!
Your code is working flawlessly. With that in mind, I will review the others as well.
Users browsing this forum: andrehj and 1 guest
