camera snapshot stops working Topic is solved
- Domoticz version: 2022.2
hello,
I have a script running to take a snapshot from my frontdoor camera and send it via Telegram to my phone. It runs flawless until the shortly. Today I realised that I keep getting the same image for some days now.
So the script is running perfectly, it shows in the logging, but the imagefile in the scripts directory is not updating anymore.
What is going on?
This is the logging:
2020-04-20 20:36:55.001 Status: dzVents: Info: ------ Start internal script: deurbelfoto: Device: "bel naar zolder (bel doorgeven)", Index: 203
2020-04-20 20:36:55.001 Status: dzVents: Info: ------ Finished deurbelfoto
What is going on?
Raspberry Pi 3B, Raspberry Pi 4, RFXCOM - RFXtrx433, Z-wave, ESP8266
- Domoticz version: V2022.1
Re: camera snapshot stops working
Not easy to help, with only that kind of information.
Which script are you using?
Which OS are you using?
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
Domoticz runs on a raspberry pi 3B with Buster and Domoticz update this year.
Its a lua-script from the internet but, a long time ago and I don't remember the site. It worked for some years now.
This is the script:
This is the script:
devices = {'Deurbel'},
if(device.state == 'On') then
local teleTok = aaaaaaaaa:etcetera
local chatId = 123456789
local snapFile = '/home/pi/domoticz/scripts/camera_'
local domoReq = 'http://192.168.1.35:8080/camsnapshot.jpg?idx=1'
local camName = 'Voordeur'
os.execute('wget -O "/home/pi/domoticz/scripts/camera_Voordeur.jpg" "http://192.168.1.240:80/cgi-bin/snapshot.cgi?chn=1"')
os.execute('curl -s -X POST "https://api.telegram.org/ aaaaaaaaa:etcetera /sendPhoto?"chat_id=123456789/sendphoto -F photo="@/home/pi/domoticz/scripts/camera_Voordeur.jpg"')
- waaren
What do see if you enter the commands separately from the Command Line Interface?
sudo wget -O "/home/pi/domoticz/scripts/camera_Voordeur.jpg" "http://192.168.1.240:80/cgi-bin/snapshot.cgi?chn=1"
sudo curl -s -X POST "https://api.telegram.org/ aaaaaaaaa:etcetera /sendPhoto?"chat_id=123456789/sendphoto -F photo="@/home/pi/domoticz/scripts/camera_Voordeur.jpg
I use exactly the same script, but mine has an extra row.
This row is added in my script;
When removing it, i notice when the camera_voordeur.jpg file is not there it works. When there is a camera_voordeur.jpg file it doesn't refresh it with a new image. By adding the remove row, it works for me
Yours will look like this with the extra row added.:
Just some extra fune for this script.
When you change one row in the script to this, than your image has text in telegram
The extra fun will look like this
os.execute("rm " ..snapFile..camName..'.jpg')
os.execute('rm /home/pi/domoticz/scripts/camera_Voordeur.jpg')
os.execute('curl -s -X POST "https://api.telegram.org/ aaaaaaaaa:etcetera /sendPhoto?"chat_id=123456789/sendphoto -F photo="@/home/pi/domoticz/scripts/camera_Voordeur.jpg" -F caption="Er wordt aangebeld aan de voordeur."')
the reaction on wget:
Connecting to 192.168.1.240:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 37829 (37K) [image/jpeg]
Saving to: ‘/home/pi/domoticz/scripts/camera_Voordeur.jpg’
/home/pi/domoticz/scripts/camera_Voor 100%[=========================================================================>] 36.94K --.-KB/s in 0.003s
2020-04-21 23:04:40 (13.7 MB/s) - ‘/home/pi/domoticz/scripts/camera_Voordeur.jpg’ saved [37829/37829]
The second command sends the photo to my phone.
So that all works fine, but the lua script has no wget command because, as you know, it is on the commandline.
I can put it on the switch itself, there one can give a command and that fires a script. But it does not solve this peculiar problem.
- waaren
not sure I completely understand your statement on the wget not being in the Lua.
Below script works for me (after entering my teleTok and chatId )
return
on =
devices =
'Deurbel'
logging =
level = domoticz.LOG_DEBUG,
marker = 'sendPicture',
local function osCommand(cmd)
if dz == nil then dz = domoticz end -- make sure dz is declared as domoticz object if not already done earlier
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_ERROR)
else -- all is fine!!
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
if device.state == 'On' then
local teleTok = 'aaaaaaaaa:etcetera'
local chatId = '123456789'
local domoReq = 'http://192.168.1.240:80/cgi-bin/snapshot.cgi?chn=1'
osCommand('wget -O '.. snapFile .. ' ' .. domoReq)
osCommand('curl -s -X POST "https://api.telegram.org/bot' ..teleTok .. '/sendPhoto?chat_id=' .. chatId .. '" -F photo=@' .. snapFile .. ' &')
I meant that wget is not a command in lua itself. In your script you call it via osCommand. That part is not in my original script, as you can see, and it was never in my script by now. I have got it working now with the adjustments as mentioned here.
So thanks to the contributors for they're comments and instructions. It has set me on the right path.
For me this item can be closed.
sorry for the wget not being in my script, I was to fast with my reply. It is there.
But once more, why did it stop making the photo when the script is fired? The only thing changed was the Domoticz-update.
No change in configuration this year. Out of the blue no more photo's taken by the event. I saw the same picture for days but I realised it only this week.
As you can see, in my script there is no deleting of the photo, it gets overwritten by the new photo.
When I deleted the picture by hand, there was no new one when the doorbel was ringing.
Maybe I was not clear on that. Telegram has been working all of the time. The problem was in the making of the photo.
But as I mentioned in my (way to soon) post, It has been solved.
When i read your reply, than i would say it is a rights problem to the directory the image needs to be written in.
This parts doesn't give an error, there should be an image, but it is not you have written.
When rights are not correct, than writting images is not possible.
Don't know if domoticz updates can change rights to directories.
Check which rights your /home/pi/domoticz/scripts directory has.
Ctenberge wrote: ↑Tuesday 21 April 2020 23:17 the reaction on wget:
I have checked the rights to the directory, seems normal:
drwxr-xr-x 8 pi pi 4096 Apr 21 23:04 scripts
Buster runs on a SSD. But I don't think that's relevant.
Last night I tested the commands on commandline and there it was, the snapshot in the /scripts directory. It answers your question as well.
Now I have an executable script with these commands and let it start by the device. Works nice so I let the lua go.
I used your comment too, to notify me that there is someone at the door. Thanks for that.
How are you using Telegram? As mine stopped working after the update
Telegram is still working for me after the last update of Domoticz,I think jadijkstra2000 that you have another problem. Propably with the account with Telegram.
To me, this post in question, camera snapshot stops working, is closed for I have found a bypass.
Thanks to all who contributed.
