Does this script hold up?
drwurn
Post by drwurn »
Not sure if this works but idea of this script is:
The 'Zwembadpomp' turns on between 12.00 and 16.00
If I'm going to swim then I want to turn off the 'Zwembadpomp', that goes manually. If I turn it off manually (probably somewhere between 12:01 and 16:00) the 'Zwembadpomp' has to turn on between 20:00 and 23:59.
return { on = { timer = {   "at 12:00",
                            "at 16:00",
                            "at 20:00",
                            "at 23:59",
    execute = function(dz)
        local Zwembadpomp                  = dz.devices(47)
        if dz.time.matchesRule("at 12:00") then
            Zwembadpomp.switchOn()
        elseif dz.time.matchesRule("at 16:00") then
            Zwembadpomp.switchOff().checkFirst()
        if Zwembadpomp.lastUpdate.minutesAgo < 479
        and Zwembadpomp.lastUpdate.minutesAgo > 240
        and dz.time.matchesRule("at 20:00") then
        elseif dz.time.matchesRule("at 23:59") then
Re: Does this script hold up?
drwurn wrote: Monday 20 April 2020 14:33 Not sure if this works but idea of this script is:
Your if statements are not correct
you use
if a and if b and if c then
dzVents (Lua) expects
if a and b and c then
local onAfternoon = 'at 12:00'
local offAfternoon = 'at 16:00'
local onEvening = 'at 20:00'
local offEvening = 'at 23:59'
return
    on =
        timer =
            onAfternoon,
            offAfternoon,
            onEvening,
            offEvening,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'zwembad',
    execute = function(dz, item)
        dz.log('Zwembadpomp trigger: ' .. item.trigger, dz.LOG_DEBUG)
        if item.trigger == onAfternoon  then
        elseif item.trigger == offAfternoon then
        elseif item.trigger == onEvening and Zwembadpomp.lastUpdate.minutesAgo > 240 and Zwembadpomp.lastUpdate.minutesAgo < 479 then
        elseif item.trigger == offEvening  then
drwurn
Post by drwurn »
Hi Waaren,
I saw it and changed it before you posted your ( I guess improved) script.
I see you put in some logging, and further a lot has changed :)
Is that because my version is not working properly or because my poorly way of making a script? :)
drwurn wrote: Monday 20 April 2020 15:49 I saw it and changed it before you posted your ( I guess improved) script.
Every person has an own style of coding. One is not necessarily better then the other. Forums where code styles are debated typically turn into shouting games and I certainly want to stay far from that. I just want to show there are always other ways of coding a solution.
One thing I do believe in strongly is to include the option to produce a bit of debug logging. Especial when you create and test a new script you will find that the behavior deviates quite often from what you think it will do :D
Once all immediate bugs are out, I set the logging level to domoticz.LOG_ERROR so that it will stay quiet in my log. Only when I or someone else sees an unexpected behavior of a script, I change it back to domoticz.LOG_DEBUG to see what is happening.
Call it a personal best practice... ;)
drwurn
Post by drwurn »
Thanks for the feedback and help!
