Vomera wrote: ↑Saturday 01 August 2020 15:53
When i set start date i get the following. The first day shows a lot of numbers (i think because of the calulation)
Hmmm. So do I
I found out why. Basically, when you use a start date, like 01/07/2020, with Mode 2 (daily growth), it has no previous data to calculate the growth between 01/07/2020 and the day before. I have updated the code to start one day before the start date, so it can calculate the difference between the two days. In your case, this is 30/06/2020. But this date is not plotted on the graph, it is only used to calculate the growth for 01/07/2020. Hope that makes sense - it does in my head
It now looks like this:
I also tweaked the code so it only formats 1000 to K for the Total, not the day. As you can see above, it is now just showing the unformatted value.
I have submitted a PR for this change. I will hopefully be merged soon in the latest beta.
By the way - the actual graphs are a little scary. I think people are relaxing too quickly, as daily cases have more than tripled in 2 weeks
