Dashticz - Show your dashboard and how-to's!
- HansieNL
If you buy Kiosk Basic version the advertisement will be removed and you can run Dashticz fullscreen on iPad.
Blah blah blah
hi folks,
learned allot from you all so a big thanks for al the tips and tricks!
for now a small question i can't figure out does anybody know how i can change the scale to these value's ?
thanks in advance
thanks in advance
docker with sonos http api / mosquitto / zigbee2mqtt assistant / portainer / dashticz / nodeJS on windows with Zigbee2Mqtt, and some flask builds of my own
Alfagek
- Domoticz version: 2020.1
Just read the documentary
: https://dashticz.readthedocs.io/en/mas ... ck-titles
- clinkadink
- Domoticz version: 2020.2
Well done with your dash, looks great! Thanks for reporting this issue with the graph header. I have reproduced at my end and fixed the problem.nfuse wrote: Friday 27 March 2020 14:25 for now a small question i can't figure out does anybody know how i can change the scale to these value's ?
thanks in advance
Please apply the latest beta to apply the fix.
https://github.com/Dashticz/dashticz/tree/beta
- EdwinK
- Domoticz version: BETA
Nice looking dashboard.
wow that was fast i will check it out asap.clinkadink wrote: Friday 27 March 2020 20:28Well done with your dash, looks great! Thanks for reporting this issue with the graph header. I have reproduced at my end and fixed the problem.nfuse wrote: Friday 27 March 2020 14:25 for now a small question i can't figure out does anybody know how i can change the scale to these value's ?
thanks in advance
thanks allot.
thanks it is showing on a 15,4" modified laptop with touchscreen build into the wall
the laptop is running stable with the following software:
- windows 10
- Domoticz ( i like it under windows)
- Sonos software
- TinyVNC
- nodeJS -> zigbee2mqtt with a CC26X2R1 zigbee controller
- hyper-V -> ubuntu 18.04 with docker Pi-hole and the following containers
- Portainer
- Mynodered
- dashticz
- zigbee2mqttassistant
- mosquitto
some pictures:
Since last week I have been playing with Domoticz/Dashticz. I start to understand how it works
Any others that want to share their nice dashboards and code/files?
HNBC84
Using it for a couple of days now. Just a clean low level easy to use layout. And just a samsung 8" tablet on the wall (Stolen it from my daugther
- dashtczhc.png (318.67 KiB) Viewed 3380 times
Lokonli
Well done! Nice stand
toro
After a lot of tinkering, changing, editing, adding, removing and changing again this is the result (for now)
I'm pretty happy with it.
It also has other screens for weather, traffic en transport, energy and for showing webcam fullscreen if someone is ringing the doorbell.
And a fullscreen image af the last person hoe rang, is case we missed it (well, doesn't happen now as we are all at home of course
- EdwinK
Nice
dennis075
Looking good!toro wrote: Wednesday 29 April 2020 22:23 After a lot of tinkering, changing, editing, adding, removing and changing again this is the result (for now)
And a fullscreen image af the last person hoe rang, is case we missed it (well, doesn't happen now as we are all at home of course)
I really like the F1 icon, can you share it?
toro
Thanks.
Sure, here's also for next year, let's hope we see Max drive in Zandvoort then!
- F1_flat_white_128_2021.png (8.13 KiB) Viewed 3089 times
- F1_flat_white_128_2020.png (8.2 KiB) Viewed 3089 times
- clinkadink
The attachments aren't showing.toro wrote: Sunday 03 May 2020 15:12 Thanks.
Sure, here's also for next year, let's hope we see Max drive in Zandvoort then!![]()
dennis075
Thanks toro. And that's because of a white logo and white backgroundclinkadink wrote: Sunday 03 May 2020 15:15The attachments aren't showing.toro wrote: Sunday 03 May 2020 15:12 Thanks.
- clinkadink
Ah, white on transparent ... always trips me updennis075 wrote: Sunday 03 May 2020 16:18Thanks toro. And that's because of a white logo and white backgroundclinkadink wrote: Sunday 03 May 2020 15:15The attachments aren't showing.toro wrote: Sunday 03 May 2020 15:12 Thanks.
But they while show correct in dashticz!
dorenberg
- Domoticz version: 4.10982
After some weeks of tweaking, here my dashboard with all info I could find here on the fora. See the screenshots. If someone is interested in some code. let me know.
Tweaks:
Temp and RH in 1 block
Different icons for some topics which change colour when on or off (However the red indicated is not the red in the FF0000 colour code. very strange)
Nett usage of P1 meter for daily and current use
Temperature alarms of freezer and fridge in colours
Tweaks:
- dash2.jpg (168.17 KiB) Viewed 4197 times
- dash1.jpg (166.92 KiB) Viewed 4197 times
Jimster
Last week I installed my water usage sensor, so finally my dashboard is complete. There is still a small gap left, but will be filled when I receive the switch for this.
On the first screen I have the weather info from Open Weather. Below that I have my Xiaomi temp sensors which are connected to a Xiaomi Hub. And then my Tado thermostat.
In the middle you see the energy usage and delivery. Info comes directly from the energy meter and also from the Solar system.
On the right public transport info, Google calendar and my Xiaomi robo vacuum.
On the next screen. The energy usage of some devices. I use energy meter sockets flashed with Tasmota. Gas & Water usage graph, Rain radar, Raspberry status info and the online/offline status of some devices.
And the last one is for switching lights, I also use smart plugs for that. Will add some more in the future.
This is how it looks:
- Main dashboard
- Dashticz1.jpg (181.44 KiB) Viewed 4033 times
- Dashticz2.jpg (190.22 KiB) Viewed 4033 times
