MQTT -> control more then one switch by one message
RafWojTar
Post by RafWojTar »
I hope this is the right forum section for this topic...
Is it possible to control more then one Domoticz's Ligth/Switch by MQTT broker message ("Domoticz/in" topic).
Everythings work fine when I use MQTT Topic: domoticz/in, Message: { "idx" : 2, "nvalue" : 1}
But I want to control more than one ligth/switch in one MQTT message, is it possible ?
I try to use JSON array like:
{{ "idx" : 2, "nvalue" : 1} { "idx" : 3, "nvalue" : 1} }
[ { "idx" : 2, "nvalue" : 1}, { "idx" : 3, "nvalue" : 1} ]
{[{ "idx" : 2, "nvalue" : 1}, { "idx" : 3, "nvalue" : 1}]}
{ "idx": [ { "idx" : 2, "nvalue" : 1}, { "idx" : 3, "nvalue" : 1} ] }
{ "idx": 2, "nvalue": [ { "idx" : 2, "nvalue" : 1}, { "idx" : 3, "nvalue" : 1} ] }
someone could point to me whether I use the wrong syntax or Domoticz doesn't handle such inquiries ?
R.W.
Re: MQTT -> control more then one switch by one message
RafWojTar wrote: Saturday 18 April 2020 11:19 Is it possible to control more then one Domoticz's Ligth/Switch by MQTT broker message ("Domoticz/in" topic).
But I want to control more than one light in one MQTT message, is it possible ?
If you want to do this in one command then you could use a domoticz group, with the devices you want to handle included, and send
mosquitto_pub -m '{"command": "switchscene", "idx": 1, "switchcmd": "On" }' -t domoticz/in
please note that On / Off are case sensitive. on / off does not work.
More information on MQTT in / out domoticz can be found in the wiki
RafWojTar
Post by RafWojTar »
I didn't mean to control the switch, I wantd to keep the temperature up to date.
(I could suggest that I used nvalue in JSON - sorry)
Group control won't solve the problem ;-)
But I appreciate the hint and thank you very much
R.W.
