Tnx,
Antoinne
blocks['cumalatief'] = {
title: 'P Elektriciteitsmeter',
devices: [idx], // <---- idx of your P1 device
graph: 'line',
borderColors:['rgba(83, 51, 198, 1)'],
datasetColors: ['rgba(83, 51, 198, 0.33)'],
legend: true
}Code: Select all
columns[1] = {}
columns[1]['width'] = 12;
columns[1]['blocks'] = [ 'cumalatief']Code: Select all
config['standard_graph'] = 'day'; I'll DOS you all. I still write batchfiles in my sleep
No, this is correct for the master and the beta. These will only change if you specify custom data in your block.Antoinne wrote: Friday 17 April 2020 0:24 Maybe it is because I am running Dashticz V3.4.3 Beta, but my default buttons are last hours, today and last month.
This is because P1 meters have multiple datasets. This can be demonstrated by using my example block above, i.e. without any custom data, and with legend set to true. The legend will then show each of your datasets and their key names, e.g. v2, v_2, etc. If you only want to display data for v2 (for example), then add this to your block:Antoinne wrote: Friday 17 April 2020 0:24 I also got confused because the available (or shown?) data of the P1 meter changes.
graphTypes: ['v2'],Code: Select all
http://[DOMOTICZ_IP_AND_PORT]/json.htm?type=graph&sensor=counter&idx=[IDX]&range=dayCode: Select all
[code]http://[DOMOTICZ_IP_AND_PORT]/json.htm?type=devices&rid=[IDX]Sorry, I cannot help you with this, I do not use Bienradar. Instead, I use Rainviewer. https://www.rainviewer.com/api.htmlAntoinne wrote: Friday 17 April 2020 0:24 The next challenge will be incorporating information from the JSON Buienradar offers. I already have some 20 Buienradar API-devices running on Domoticz/Dashticz, but now I need to figure out how to incorporate data that is only available through JSON on Buienradar.
devices: [8],
graph: 'line',
graphTypes: ['eu_8'],
lineFill: [true],
buttonsText: ['Today', 'Week', 'Month'],
maxTicksLimit: 14,
zoom: 'x',
debugButton: true,
legend: {
'Cumalatief' : 'eu_8'
}Users browsing this forum: Bing [Bot] and 1 guest
