Has anyone managed to run Domoticz and Unifi controller on the same Raspberry?
I have a Pi 3 which had a Unifi controller running.
But after installing Domoticz (with the curl script) the Unificontroller is no longer accessable at the designated port (8443).
Maybe conflicting HTTPS configurations? Anyhow I am stuck...
Combine Unifi controller and Domoticz on Raspberry
- bbqkees
- Domoticz version: 4.1x
Re: Combine Unifi controller and Domoticz on Raspberry
The web interface of both Unifi and Domoticz run at port 8080 by default.
So you need to change only one of them. In my case I changed the port of Domoticz to something else.
You need to edit the port setting in /etc/init.d/domoticz.sh
Remember at the next startup to visit the Domoticz web interface at the new port instead of 8080.
rbosch
- Domoticz version: 2020.2
Thx! That solved the problem!You need to edit the port setting in /etc/init.d/domoticz.sh
lumjajo
- Domoticz version: 4.10717
Ihave the same issue, does anyone know who to change the default port of the Unifi controller. I do not want to change the domoticz web port as its used in some scripts as well...
Dickey
- Domoticz version: 2022.1
https://help.ubnt.com/hc/en-us/articles ... r-and-UAPslumjajo wrote: Friday 03 April 2020 14:50 Ihave the same issue, does anyone know who to change the default port of the Unifi controller. I do not want to change the domoticz web port as its used in some scripts as well...
Dz-beta | Dashticz 3.8.10 BETA | Tradfri | RF-Link | Z-Wave | Harmony | Unify | P1 |
Ron
- Domoticz version: 2.2284
Is it easy to install a Unify controller onto a Raspberry Pi?
I could use this to contol my AP-LC-LR access point.
jake
I just went through the experience to find out by trial and error that the unifi controller and domoticz are in each others way. I just documented the solution for myself, so I thought, I'd share it with your guys:
I started of with the available guide online: https://lazyadmin.nl/home-network/insta ... -in-5-min/
CAUTION: when you read this after you got stuck with a non working Unifi controller due to this port usage, skip the steps here below until the "stop domoticz service" . Also replace the next command "install unifi controller" (since you installed it before and you need to reinstall), by this one instead: sudo apt-get install --reinstall unifi -y
Install OpenJDK (instead of Java):
sudo apt-get install openjdk-8-jre-headless -y
Download repository:
echo 'deb http://www.ui.com/downloads/unifi/debian stable ubiquiti' | sudo tee /etc/apt/sources.list.d/100-ubnt-unifi.list
Install GPG-key:
sudo wget -O /etc/apt/trusted.gpg.d/unifi-repo.gpg https://dl.ubnt.com/unifi/unifi-repo.gpg
Stop domoticz (because unifi tries to use port 8080 and install fails when 8080 is in use):
sudo service domoticz stop (use Monit when this is installed, otherwise Domoticz restarts within minutes!)
Install Unifi Controller:
sudo apt-get update; sudo apt-get install unifi -y
Stop and disable mongodb, it is not needed:
sudo systemctl stop mongodb
sudo systemctl disable mongodb
check which ports are in use:
sudo netstat -ntpl
Switch to super user to be able to change the unifi config file:
sudo -i
nano /usr/lib/unifi/data/system.properties
change # unifi.http.port=8080 to: unifi.http.port=8083 (remove the hash sign, port number 8080->8083, or whatever suits you)
Stop super user:
exit
Restart Domoticz:
sudo service domoticz start (or use Monit)
Install GPG-key:
sudo netstat -ntpl
sudo -i
Stop super user:
exit
Restart Domoticz:
