problem with os.execute in dzVents, while in "normal" lua all is fine  [Solved]
Maarten112
Post by Maarten112 »
Hi guy's,
I'm having a bit of trouble to do the following using dzVents:
- Shutdown a remote host using os.execute over ssh from a local host (e.g. domoticz that shutsdown another raspbeery pi)
What did I do:
- installing keys to remotely ssh without a password ( :arrow: works)
- verified from local cli on domoticz pi that command used is working to shutdown remote host ( :arrow: works)
- verified from local cli on domoticz pi that using "normal" lua without dzvents, code is working ( :arrow: works)
- Using a script on the remote host to shutdown, containing simple "sudo shutdown now" triggered over ssh from local host with
ssh [email protected] sh /home/pi/shutdown.sh
( :arrow: works)
- Directly triggering from local host to remote host with
ssh [email protected] sh sudo shutdown now
(I added the pi users to the visudo list to directly use "shutdown" instead of /sbin/shutdown) ( :arrow: works)
- trying both the "os.execute" and "assert(io.popen(cmd, 'r')" way using a standard lua script on local host ( :arrow: works)
What is the problem:
When using dzvents do accomplish the same as above, it is not working. Even if relevant parts of lua codes that works in standard lua get copied to dzvents.
Full Script:
		devices = {
		'Werkkamer - Sw_L'
	logging = {
		level = domoticz.LOG_DEBUG,
		marker = "P3STEELSWITCH.LUA"
	execute = function(domoticz, switch)
		local cmd = "ssh [email protected] sh /home/pi/shutdown.sh"
		domoticz.log(switch.state)
		if(domoticz.devices('Werkkamer - P3Steel').state == 'On') then
			if(domoticz.devices('Werkkamer - P3Steel').lastUpdate.minutesAgo >= 1) then
					domoticz.log("3D printer powered on > 1 minute ago, shutdown")
					domoticz.log(cmd)
					os.execute(cmd)
					--local f = assert(io.popen(cmd, 'r'))
					--s = assert(f:read('*a'))
					--f:close()
					--print(s)
					--domoticz.log(s)
					domoticz.devices('Werkkamer - P3Steel').switchOff()
					domoticz.log("3Dprinter powered on < 1 minute ago, don't shutdown.")
			domoticz.devices('Werkkamer - P3Steel').switchOn()
The relevants part that must trigger the remote host to shutdown are these:
os.execute(cmd)
or
f:close()
--print(s)
domoticz.log(s)
I hope that somebody can help me out. Thanks already!
Re: problem with os.execute in dzVents, while in "normal" lua all is fine
Maarten112 wrote: Tuesday 14 April 2020 14:31 I'm having a bit of trouble to do the following using dzVents:
I suspect that it has something to do with the user executing the local ssh command being another one as the one you tested with or use another environment. For some other tasks I use ssh with generated keys (without password) from dzVents (root - root) without problems.
I use below function for my os commands because it gives me more debug information
        local function osCommand(cmd)
            domoticz.log('Executing Command: ' .. cmd,domoticz.LOG_DEBUG)
            local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
            local commandOutput = assert(fileHandle:read('*a'))
            local returnTable = {fileHandle:close()}
            if commandOutput:find '::ERROR::' then     -- something went wrong
               domoticz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message
' ) ,domoticz.LOG_DEBUG)
            else -- all is fine!!
                domoticz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, domoticz.LOG_DEBUG)
            return commandOutput,returnTable[3] -- rc[3] contains returnCode
Maarten112
Hi Waaren,
Thanks for your reply! Indeed, it is the only possible explanation I could think of also. However, at the same time I think it's a bit weird.
Let's suppose dzvents is running as user root. As user root, the local system where domoticz is running does " ssh [email protected]". This way, the user ssh'ing to the remote system is pi, despite the fact that dzvents is running as user root.
I am not in the opportunity right now, but I will check with your code if i'm able to debug something. One of the problems was that I didn't know how to get some detaild debug output with DzVents (and in "plain" lua all went fine.....).
Also, I will try what happens when I add user 'root' to the remote system and give the user the right permissions.
Maarten112
Re: problem with os.execute in dzVents, while in "normal" lua all is fine  [Solved]
my o my.....thanks to your little function everything is working now! :mrgreen: I did a good old fuckup...... :oops:
ssh keys where only available to pi user, not root..... Dzvents running as root.....so didn't had any keys to connect to the remote host :oops:
Users browsing this forum: hemant5400z and 1 guest
