The logic is as follows: When the TV is turned on, the power consumption increases and the dzVents script starts a wi-fi relay that supplies power to the LED lights and music amplifier.
Problem: when you turn on the TV, the relay does not start immediately, since the readings are updated every 5 minutes.
Q: is there a way to reduce the time to survey the power consumption of the outlet? Or any other way out of the situation.
I have described the principle of operation on the site
