JacEngels wrote: Sunday 24 December 2017 15:04
I'm setting this up for my DS212j Synology NAS running on DSM 6.1.4-15217 Update 5.
Both temperature checks are working but the disk checks don't work: there is nothing to find for the OID! I used .41 and several others.
Which OID do I use to get the script working?
I had the same. I did some Internet searching and found that the OID needs to be .42 for DSM 6.1., which works on my Synology. I updated the script on the Domoticz wiki.
Thank you for the update. I've figured that out some time ago but forgot to mention it here!
So, I think I'm almost there with this script. Still, I also think that there is something not quite right. This is the script I use. I only have 4 drives, so commented out where it looks for more drives.
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>HTTP/1.1 400 Bad Request
Content-Length: 89
Content-Type: text/html
Content-Length: 89
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>./nas.sh: line 86: (No Such Instance currently exists at this OID - No Such Instance currently exists at this OID) * No Such Instance currently exists at this OID / 1024 / 1024 / 1024: missing `)' (error token is "Such Instance currently exists at this OID - No Such Instance currently exists at this OID) * No Such Instance currently exists at this OID / 1024 / 1024 / 1024")
0.333
1
NAS already ON
HTTP/1.1 200 OK
Content-Length: 53
Content-Type: application/json;charset=UTF-8
Cache-Control: no-cache
Pragma: no-cache
Access-Control-Allow-Origin: *
#!/bin/bash
# Settings
NASIP="" # NAS IP Address
PASSWORD="" # SNMP Password
DOMO_IP="" # Domoticz IP Address
DOMO_PORT="" # Domoticz Port
NAS_IDX="335" # NAS Switch IDX
NAS_HD1_TEMP_IDX="336" # NAS HD1 Temp IDX
NAS_HD2_TEMP_IDX="337" # NAS HD2 Temp IDX
NAS_HD3_TEMP_IDX="338"
NAS_HD4_TEMP_IDX="343"
NAS_HD_SPACE_IDX="344" # NAS HD Space IDX in Go
NAS_HD_SPACE_PERC_IDX="341" # NAS HD Space IDX in %
NAS_CPU_IDX="339" # NAS CPU IDX
NAS_MEM_IDX="340" # NAS MEM IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
if [ $? -eq 0 ] ; then
echo "NAS already ON"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
# Temperature HD2
HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.1`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&id$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
# Temperature HD3
HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.2`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD3_TEMP_IDX&nvalue=0&svalue=$HDtemp3"
# Temperature HD4
HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.3`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD4_TEMP_IDX&nvalue=0&svalue=$HDtemp4"
# Free space volume in Go
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.4.51` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.5.51` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.6.51` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space volume in percent
HDTotal=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.51` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDUsed=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.51` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDFreePerc=$((($HDUsed * 100) / $HDTotal))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD_SPACE_PERC_IDX&nvalue=0&svalue=$HDFreePerc"
# CPU utilisation
CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
CpuUse=$(($CpuUser + $CpuSystem))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
# Free Memory Available in %
MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0`
MemAvailableinMo=$(($MemAvailable / 1024))
MemUsepercent=$((($MemAvailableinMo * 100) / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=On"
# Temperature HD1
# Send data
# Temperature HD2
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
# Temperature HD3
# Send data
# Temperature HD4
HDtemp4=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.3`
# Send data
# Send data
# Send data
# CPU utilisation
# Send data
# Send data
fi
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
echo "NAS already OFF"
exit
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=Off"
fi
fi
It works for disk temps, cpu percentage used and harddisk % used, these are correct.
But there is something wrong with the memory, it is giving 500% and the harddisk counter is giving only 1 result, I dont know if thats right.
12-3-2019 08-31-40.jpg (66.52 KiB) Viewed 8829 times
12-3-2019 08-29-36.jpg (144.28 KiB) Viewed 8829 times
12-3-2019 08-28-39.jpg (105.33 KiB) Viewed 8829 times
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
Got some problems making it work with my Synology DS112 single bay NAS.
It has something to do with the OID’s but I just don’t see where I’m going wrong.
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.4.36` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.5.36` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.6.36` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
# Send data
HDTotal=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.36` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
HDUsed=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.36` # Change OID to .38 on DSM 5.1, .41 on DSM 6.0, 42 on DSM 6.1
# Send data
Doing a snmpwalk -v1 -c <password> 192.168.1.10 results in a big list off information.
I think the part below is related to the script
The percentage calculation is wrong, as it only uses the available memory without getting total amount of memory. So how do you calculate a percentage with only one value .
So try this:
Hopefully some can help me with an error which occurs when i run the scripts.
I'm a noob in developing..
Domoticz is running on my Synology NAS, could that be the cause of this error? If yes, anybody an idea if it is possible to monitor my NAS via domoticz which is installed on the NAS i want to monitor?
ok, ok.
Probleem solved. Username pwd was activated on domonicz and i didn't exclude the internal network setting..
i have copied the mentioned script and created a userdefined scheduled job which starts the script every 5 minutes.
This error occurs
Since I upgraded to this version my script is faulty on HDSPace calculation
on this part
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.4.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.5.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.6.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+
# Send data
HDTotal=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+
HDUsed=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.52` # Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+
# Send data
Thank you
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
on this part
# Send data
# Send data
