openURL error
cjb75
Re: openURL error
You are probably right, the strange thing is that it used to work (and it works for others - see the thread I mentioned above).
- waaren
Re: openURL error
What I read in this thread is that it worked in a previous version of unifil under stretch. The move from previous stable or beta to latest stable did not change anything in the dzVents openURL behavior.cjb75 wrote: Friday 10 April 2020 21:20 You are probably right, the strange thing is that it used to work (and it works for others - see the thread I mentioned above).
Maybe some other changes on your environment either on the unifil or OS side of the domoticz system caused the method you use not to function any longer ?
Did you got an answer on your questions in the other thread ?
cjb75
Re: openURL error
My understanding is that is works for other users (using buster) so I guess I managed to change something in my environment but I can’t figure out what and when....The systems can reach each other, ping is working and I can login using the API.
I have already spent quite a lot of hours on this so I guess I have to give up but it hurt my self-confidence
