Python Script or plugin for Xiaomi Mi Temp and Humidity Sensor
- Domoticz version: 4.10717
Hi Everybody,
i have four Xiaomi Mi Temperature and Humidity Sensors (lLYWSDCGQ/01ZM https://www.aliexpress.com/i/32849595532.html) and i'm searching for a way to integrate them into domoticz. I found a library with examplescript to poll them directly from the raspi without gateway (https://zsiti.eu/xiaomi-mijia-hygrother ... pberry-pi/). Is there a way to parse the output directly into domoticz as sensor?
thanx for any help in advance
- Domoticz version: bèta
Re: Python Script or plugin for Xiaomi Mi Temp and Humidity Sensor
Here you can find a script and a manual for use with Domoticz.
https://github.com/pFenners/mijia-sensor-domoticz
Use to find the sensor and note the MAC address of the device.
After downloading the code from GitHub, you must make 3 changes to the file
And line 25 you must change the word: into
At the end of the script there are 3 examples of the function update.
Eg.
Remove the # of one of the functions and replace the MAC address with the one you noted.
The number after the comma, "120" is the IDX of the sensor in Domoticz.
To test it you can now run the command:
Use
sudo hcitool lescan
At the first line type:domoticz_mijia.py
#! /usr/bin/python3
base64.encodestring
base64.encodebytes
Eg.
update("58:2D:34:39:18:66","120")
./domoticz_mijia.py
- Hesitated
- Domoticz version: V4.11665
Where do i find this file? It's not in the repository...
Domoticz 2020.2 - RPi3B+ - RFXtrx433XL - P1 - CC2531 - Somfy - Xiaomi - Hue - Omron - MQTT
Sorry.
I used the wrong github address.
You should use this one: https://github.com/pFenners/mijia-sensor-domoticz
- Hesitated
Minor detail...
First upgrade to Buster this weekend, then I'll look into it.
- Domoticz version: 2020.2
how does this work? using a esp32 of some kind with bluetooth? i could not find which device to use for bluetooth connection. i do not want to use the bluetooth on my pi since it does not cover the whole house. with multiple esp32 it would be possible but it is not listed how to do that.
I noticed that 1 Rpi does not receive all the units in our house. You could use an ESP32 on each floor.
I have a Rpi on each floor. That is a choice you can make.
For use with an ESP32, see this video: https://www.youtube.com/watch?v=RtJpx8BZvMw
I adjusted the script as per instructions.
When I run the script I get:
File "./domoticz_mijia.py", line 5, in <module>
from mijia.mijia_poller import MijiaPoller, \
ModuleNotFoundError: No module named 'mijia'
I also installed the script mija_poller, made it executable and added python3 to it.
Any ideas?
Any ideas?
- Target OS: OS X
Hi All, could anyone solve tis?
I am also stuck after following the instructions above:
File "domoticz_mijia.py", line 5, in <module>
Any help?
Any help?
- Domoticz version: 2025.1
Perhaps easier to use a Python plugin like viewtopic.php?f=65&t=22281
- Target OS: OS X
In case some of you are interested, here the solution for the Mijia V2 (
https://github.com/erdose/xiaomi-mi-lywsd03mmc
model LYWSD03MMC
I am getting sometimes an error "Failed to connect to peripheral", but it works from time to time and I can see the data in my domoticz
model LYWSD03MMC
Hey, thanks for that!
Getting somewhat further now.
Just like you I get the occasional "Failed to connect", but also " Bluetooth command failed (code: 1, error: Invalid handle)".
And when it is working, I don't see the "INFO The request is http://192.168.178.23:8080/json.htm?typ ... battery=74" line in my log file.
No data appearing in Domoticz.
When I use curl to post the data myself, I see it appear in Domoticz, so the error seems to be on the side of the script, not on the Domoticz side.
menno@quokka:~$ curl 'http://192.168.178.23:8080/json.htm?typ ... battery=74'
"status" : "OK",
"title" : "Update Device"
"status" : "OK",
That's for the Flower Mate, I don't think it works for these devices.waltervl wrote: ↑Tuesday 10 August 2021 17:27 Perhaps easier to use a Python plugin like viewtopic.php?f=65&t=22281
I also own a Flower Mate and the scripts works for it, but does not pick up my three Xiaomi Temperature and Humidity Sensors.
Meanwhile, back to getting the module not found error.
For Python module load errors check the last paragraph of the wiki https://www.domoticz.com/wiki/Using_Python_plugins
- Domoticz version: 2022.2
Hi Menno,Menno wrote: ↑Saturday 09 October 2021 15:28 Hey, thanks for that!
And when it is working, I don't see the "INFO The request is http:// 192 .168 .178 .23:8080/json .htm?type=command¶m=udevice&idx=1053&nvalue=0&svalue=28 .72;66;1&battery=74" line in my log file.
menno@quokka:~$ curl 'http:// 192 .168 .178 .23 :8080/json .htm?type=command¶m=udevice&idx=1053&nvalue=0&svalue=20;66;1&battery=74'
"status" : "OK",
Can I ask you to come over to the thread of the Temp & Hum Sensor 2, and give me some hints to move forward making it working for me, please?
For me the script is not even getting to this part, only prints the following lines:
2023-08-06 17:20:02 INFO ***************************************
2023-08-06 17:20:02 INFO Start script...
2023-08-06 17:20:02 INFO Input parameters:
Domoticz Server IP: 127 .0 .0 .1
Domoticz Server Port: 8080
Domoticz Server User: <myuserhere>
Domoticz Server Password: <mypasshere>
I started to play with the script, and eventually changing the scanner.scan first param from 10 to 15 made it work:Lacman wrote: ↑Sunday 06 August 2023 17:22Hi Menno,Menno wrote: ↑Saturday 09 October 2021 15:28 Hey, thanks for that!
"status" : "OK",
For me the script is not even getting to this part, only prints the following lines:I'd appreciate your, or anyone's help.Code: Select all
2023-08-06 17:20:02 INFO *************************************** 2023-08-06 17:20:02 INFO Start script... 2023-08-06 17:20:02 INFO Input parameters: Domoticz Server IP: 127 .0 .0 .1 Domoticz Server Port: 8080 Domoticz Server User: <myuserhere> Domoticz Server Password: <mypasshere>
try:
scanner = Scanner().withDelegate(TempHumDelegate())
scanner.scan(15.0, passive=True)
except Exception as e:
logger.error(str(e))
pass
BR,
Lacman
Nothing there at that link, but did you get it working?Lacman wrote: ↑Sunday 13 August 2023 21:10
BR,
Lacman
The script no longer works.
I get 401 errors, despite having allowed basic-auth and having the proper IP-ranges as trusted networks.
Anyone else experiencing this and more importantly, having it fixed?
- Domoticz version: 2023.2
Yup, i'm also having troubles..... also with this plugin... viewtopic.php?t=34348
It's since the domoticz update 2023.2
