Blockly not executed with http command and dummy level switch Topic is solved
ebretteville
Domoticz version: 2.3530
Post by ebretteville »
Hye,
Here is a piece of blockly that should be executed on a dummy level switch. I don't know why it is not working.
Here is the dummy level switch:
Thanks for your heads up.
wouterlet
Re: Blockly not executed with http command and dummy level switch
Post by wouterlet »
Nothing happens?
Does the dummy switch get to the right state?
What's written in your log?
You can also add an "write to log" to debug maybe
ebretteville
Thanks for your reply.
It's a nice idea to add a write to log, here is how I modified the blockly:
And here is the log when changing the state of the switch:
2020-04-09 08:52:49.698 ([CAM]) Light/Switch ([CAM] ABSENT/PRESENT)
2020-04-09 08:52:49.688 Status: User: etienne initiated a switch command (1410/[CAM] ABSENT/PRESENT/Set Level)
2020-04-09 08:53:13.215 ([CAM]) Light/Switch ([CAM] ABSENT/PRESENT)
2020-04-09 08:53:13.204 Status: User: etienne initiated a switch command (1410/[CAM] ABSENT/PRESENT/Set Level)
And in the events variable state tab i see 20 or 10 but a strange:
Idx    Dernière mise à jour  Nom                                 État          Valeur
1410	2020-04-09 09:03:22	[CAM] ABSENT/PRESENT	PRESENT	2/20
So from my understanding, it even don't go inside one of those two tests... Strange, maybe because no actions are configured in the switch for each level?
ebretteville
I found a way to "enter" in the test. Instead of checking the level value. I check the string value. Strange. Now I have to figure out if it's possible to open url with cgi commands...
ebretteville
Found the pbm. One of url type was malformed for domoticz. It worked in a browser but not in blockly. So I homogenized all urls and with the string level test, everything worked. It's a solved pbm.
jarmoboy
Domoticz version: v2022.2
Post by jarmoboy »
For those who dont know, if you want to set level, it should be a tab of percentage, not integer!
So you can use name of level as a string (caps sensitive) or percentage bar.
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
