Json parse - how to get value?
tomes
Post by tomes »
I have a JSON string:
{"folder":{"testA":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testB":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testC":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1}}}
How can I get 2nd lever names using DzVents? I want to print testA testB testC
In my case these names may be different, so i must know all path to get for example item.json.folder.testA.tg
Or maybe there is a simpler way to extract these values?
I will be grateful for any hint.
Tom
Re: Json parse - how to get value?
tomes wrote: Sunday 05 April 2020 23:32 I have a JSON string:
Not sure I completely understand the question but this should get you going.
return
    on =
        devices =
            'jsonTrigger' -- virtual switch to start the script.
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'json converter',
    execute = function(dz)
        local lodash = dz.utils._ -- set of very useful tools
        myJSON = '{"folder":{"testA":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testB":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testC":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1}}}'
        myTable = dz.utils.fromJSON(myJSON)
        dz.utils.dumpTable(myTable) -- dumps the complete json (converted  to a table)
        for key, subTable in pairs(myTable.folder) do
            dz.log(key ..': ' .. lodash.str(subTable), dz.LOG_DEBUG) -- key are the tableNames below 'folder'
tomes
Post by tomes »
Works perfectly! Thanks a lot.
So, i have another question. How to get KEY which have set isTalker:true?
Tom
tomes wrote: Monday 06 April 2020 15:48 Works perfectly! Thanks a lot.
Tom
return
    on =
        devices =
    logging =
        myJSON = '{"folder":{"testA":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testB":{"isTalker":true,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testC":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1}}}'
            if subTable.isTalker then -- if true
                dz.log(lodash.str(key),dz.LOG_DEBUG)
tomes
Post by tomes »
Great! Thanks again. Everything works perfectly!
