Yesterday I thought that only adding a new motionsensor was not working, today I discovered that Zigbee2MQTT isn't working at all..
My config:
homeassistant: false
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://localhost'
user: sameUser
password: samePassword
serial:
port: /dev/ttyACM0
devices:
'0x00158d0003f11c5e':
friendly_name: TempSensorWoonkamer
'0x00158d0002f82c3c':
friendly_name: Switch1
'0x00158d00034925f0':
friendly_name: Switch2
'0x00158d00033efd25':
friendly_name: Switch3
'0x00158d0004184f53':
friendly_name: TempSensorStudeerkamer
'0x00158d00045195c5':
friendly_name: MotionSensor1
'0x00158d00044943fa':
friendly_name: MotionSensor2
'0x7cb03eaa00a7759c':
friendly_name: '0x7cb03eaa00a7759c'
'0x00158d00044d60fc':
friendly_name: MotionSensor3Code: Select all
systemctl status zigbee2mqtt.servicezigbee2mqtt.service - zigbee2mqtt
Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-04-05 13:14:48 CEST; 53min ago
Main PID: 25795 (npm)
Tasks: 23 (limit: 4915)
CGroup: /system.slice/zigbee2mqtt.service
├─25795 npm
├─25809 sh -c node index.js
└─25810 node index.js
Apr 05 13:51:41 domoticz npm[25795]: zigbee2mqtt:info 2020-04-05 13:51:41: MQTT publish: topic 'zig
sudo journalctl -u zigbee2mqtt.service -fSo this looks good, but running-- Logs begin at Sat 2020-04-04 21:31:18 CEST. --
Apr 05 14:09:35 domoticz npm[25795]: zigbee2mqtt:info 2020-04-05 14:09:35: MQTT publish: topic 'zigbee2mqtt/MotionSensor2', payload '{"battery":100,"voltage":3005,"illuminance":10,"illuminance_lux":10,"linkquality":15,"occupancy":false}'
Apr 05 14:10:22 domoticz npm[25795]: zigbee2mqtt:info 2020-04-05 14:10:22: MQTT publish: topic 'zigbee2mqtt/TempSensorWoonkamer', payload '{"battery":86,"voltage":2975,"temperature":19.57,"humidity":38.29,"pressure":1014.1,"linkquality":15}'
Apr 05 14:13:35 domoticz npm[25795]: zigbee2mqtt:info 2020-04-05 14:13:35: MQTT publish: topic 'zigbee2mqtt/MotionSensor3', payload '{"battery":100,"voltage":3025,"illuminance":23,"illuminance_lux":23,"linkquality":2,"occupancy":true}'
mosquitto_sub -d -u sameUser -P samePassword -t /#And therefore Domoticz receives nothing too...Client mosq-Vbwr5gEfnmyqEJcaQE sending CONNECT
Client mosq-Vbwr5gEfnmyqEJcaQE received CONNACK (0)
Client mosq-Vbwr5gEfnmyqEJcaQE sending SUBSCRIBE (Mid: 1, Topic: /#, QoS: 0, Options: 0x00)
Client mosq-Vbwr5gEfnmyqEJcaQE received SUBACK
Subscribed (mid: 1): 0
Client mosq-Vbwr5gEfnmyqEJcaQE sending PINGREQ
Client mosq-Vbwr5gEfnmyqEJcaQE received PINGRESP
However if I send this:
mosquitto_pub -d -u sameUser -P samePassword -t /zigbee2mqtt/MotionSensor3 -m "Test message"Where did I mess up?Client mosq-Jjra6Mz97fdXCC3ozf received PUBLISH (d0, q0, r0, m0, '/zigbee2mqtt/MotionSensor3', ...
12 bytes))
Test message
