HTTPResponses array?  [Solved]
papoo
Domoticz version: 4.10
Post by papoo »
I wish query a website several times by changing a parameter for each request in the same script
with the domoticz.openURL command
httpTesponses can be an array?
how to recover the name of multiple httpresponses?
the beginning of my script
local les_horoscopes = {}
les_horoscopes[#les_horoscopes+1] = {device = 'Horoscope 1', signe = 'belier'}
les_horoscopes[#les_horoscopes+1] = {device = 'Horoscope 2',   signe = 'taureau'}
local horoscope = ''
local device = ''
local signe = ''
local site_url  = 'https://astro.rtl.fr/horoscope-jour-gratuit'  -- url
    active = true,
    on  =   {
        timer           =   { 'every hour' },--https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#timer_trigger_rules
        httpResponses   =   { 'belier, taureau, gemeaux, cancer, lion, vierge, balance, scorpion, sagittaire, capricorne, verseau, poissons' }    -- Trigger
    execute = function(dz, item)
        local function logWrite(str,level)             -- Support function for shorthand debug log statements
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        if (item.isTimer) then
            for k,v in pairs(les_horoscopes) do-- On parcourt chaque horoscope
                device = v.device
                if device ~= nil and device ~= '' and dz.devices(device).name ~= nil then
                    logWrite('--- --- --- traitement '..device..'  --- --- --')
                    signe = v.signe
                    dz.openURL({--https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#httpResponses
                        url = site_url..'/'..signe,
                        callback = signe
            end --for
        if (item.isHTTPResponse and item.ok) then
                device = v.device
                    signe = v.signe
            end --for
--test the callback name or httpresponsename
boum
Domoticz version: 4.10717
Re: HTTPResponses array?
Post by boum »
Just enumerate the different HTTP responses in the lua array:
    on  =   {
        httpResponses   =   { 'belier', 'taureau', 'gemeaux', 'cancer', 'lion', 'vierge', 'balance', 'scorpion', 'sagittaire', 'capricorne', 'verseau', 'poissons' }    -- Trigger
In your script, when item.isHTTPResponse is true, you can get the corresponding string with item.trigger or item.callback.
boum
Post by boum »
To make things easier to change, I'd do something like that (feel free to use or not this version ;))
  ['belier'] = 'Horoscope 1',
  ['taureau'] = 'Horoscope 2',
local site_url  = 'https://astro.rtl.fr/horoscope-jour-gratuit/'  -- url
    active = true,
    on  =   {
        timer           =   { 'at 04:17' },
            for signe,device in pairs(les_horoscopes) do-- On parcourt chaque horoscope
                if device and dz.devices(device).name then
                        url = site_url..signe,
                        callback = signe
            end --for
        elseif (item.isHTTPResponse and item.ok) then
            local signe = item.trigger
            local device = les_horoscopes[signe]
It might even be possible to generate the httpResponses array from the les_horoscopes table automatically.
papoo wrote: Monday 30 March 2020 13:48 I wish query a website several times by changing a parameter for each request in the same script
Could be something like
return
    on  =
        timer  =
            'every minute'
        httpResponses =
            'belier', 'taureau', 'gemeaux', 'cancer', 'lion', 'vierge', 'balance', 'scorpion', 'sagittaire', 'capricorne', 'verseau', 'poissons',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'horoscope',
            { device = 'Horoscope 1', signe = 'belier'},
            { device = 'Horoscope 2', signe = 'taureau'},
            { device = 'Horoscope 3', signe = 'gemaux'},
            for index, record in ipairs(les_horoscopes) do-- On parcourt chaque horoscope
                dz.utils.dumpTable(record)
                if dz.utils.deviceExists(record.device) then
                    logWrite('--- --- --- traitement '.. record.device..'  --- --- --')
                    dz.openURL(
                            url = site_url .. record.signe,
                            callback = record.signe
            end --for
                logWrite('--- --- --- traitement '..record.device..'  --- --- --')
                    dz.log(item.data,dz.LOG_DEBUG) -- Just the html page ??
                    dz.devices(record.device).updateText(record.signe or 'no Horoscope today')
papoo
Post by papoo »
there is only one httpresponse, the first
how can i test each item.trigger in the if (item.isHTTPResponse) with a for boucle ?
do I have to create each test independently?
boum
Post by boum »
The script should be called 1 time for every dz.openURL call. Each time you will get a different item.trigger, so you'll have to update the device one by one.
papoo
Post by papoo »
no only the first
two openurl but only one httpresponse processed
2020-03-30 14:58:00.467 Status: dzVents: Info: Horoscope v2.0: ------ Start external script: horoscope.lua:, trigger: "every 2 minutes"
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement Horoscope 1--- --- --
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: url = https://astro.rtl.fr/horoscope-jour-gratuit/cancer
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: method = GET
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: post data = nil
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: headers = nil
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: callback = cancer
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement Horoscope 2 --- --- --
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: url = https://astro.rtl.fr/horoscope-jour-gratuit/capricorne
2020-03-30 14:58:00.468 Status: dzVents: Debug: Horoscope v2.0: OpenURL: callback = capricorne
2020-03-30 14:58:00.469 Status: dzVents: Info: Horoscope v2.0: ------ Finished horoscope.lua
2020-03-30 14:58:01.550 Status: dzVents: Info: Horoscope v2.0: ------ Start external script: horoscope.lua: HTTPResponse: "cancer"
2020-03-30 14:58:01.550 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement --- --- --
2020-03-30 14:58:01.557 Status: dzVents: Debug: Horoscope v2.0: Processing device-adapter for Horoscope Pascal: Text device
2020-03-30 14:58:01.557 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement Horoscope 1 --- --- --
2020-03-30 14:58:01.557 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement signe cancer --- --- --
2020-03-30 14:58:01.559 Status: dzVents: Debug: Horoscope v2.0: En ce qui vous concerne, Mars et Saturne sont en lien avec le domaine financier, il y a évidemment une crise dans ce domaine, accentuée semble-t-il pour ceux de juin.
2020-03-30 14:58:01.560 Status: dzVents: Debug: Horoscope v2.0: Processing device-adapter for Horoscope 2: Text device
2020-03-30 14:58:01.560 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement Horoscope Lina --- --- --
2020-03-30 14:58:01.560 Status: dzVents: Info: Horoscope v2.0: ------ Finished horoscope.lua
with this code
                    logWrite('--- --- --- traitement   --- --- --')
            for index,record in pairs(les_horoscopes) do-- On parcourt chaque horoscope
                device = record.device
                    signe = record.signe
                    if item.trigger == signe then
                        logWrite('--- --- --- traitement signe '..item.trigger..'  --- --- --')
                        for instance in item.data:gmatch("<body>(.-)</body>") do
                            div, horoscope=instance:match('<h2>En résumé</h2>(.-)<p class="text">(.-)</p>')
                        horoscope = TronquerTexte(unescape(horoscope), 240)
                        logWrite(horoscope)
            end --for
boum
Post by boum »
I tried locally and got 2 triggers (I kept only those in your first script)
2020-03-30 15:15:13.693 Status: dzVents: Info: ------ Start internal script: horoscope: Device: "Switch (Dummy)", Index: 1
2020-03-30 15:15:13.697 Status: dzVents: Info: ------ Finished horoscope
2020-03-30 15:15:14.036 Status: dzVents: Info: Handling httpResponse-events for: "belier"
2020-03-30 15:15:14.036 Status: dzVents: Info: ------ Start internal script: horoscope: HTTPResponse: "belier"
2020-03-30 15:15:14.051 Status: dzVents: belier
2020-03-30 15:15:14.052 Status: dzVents: Horoscope 1
2020-03-30 15:15:14.052 Status: dzVents: ok
2020-03-30 15:15:14.056 Status: dzVents: Info: ------ Finished horoscope
2020-03-30 15:15:14.222 Status: dzVents: Info: Handling httpResponse-events for: "taureau"
2020-03-30 15:15:14.222 Status: dzVents: Info: ------ Start internal script: horoscope: HTTPResponse: "taureau"
2020-03-30 15:15:14.237 Status: dzVents: taureau
2020-03-30 15:15:14.237 Status: dzVents: Horoscope 2
2020-03-30 15:15:14.237 Status: dzVents: ok
2020-03-30 15:15:14.240 Status: dzVents: Info: ------ Finished horoscope
Weird.
papoo
Post by papoo »
with witch code?
with mine there is only one httpresponse
the 2 responses is same
2020-03-30 15:22:01.446 Status: dzVents: Info: Horoscope v2.0: ------ Start external script: horoscope.lua: HTTPResponse: "cancer"
2020-03-30 15:22:01.446 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement Horoscope 1 --- --- --
2020-03-30 15:22:01.448 Status: dzVents: Debug: Horoscope v2.0: En ce qui vous concerne, Mars et Saturne sont en lien avec le domaine financier, il y a évidemment une crise dans ce domaine, accentuée semble-t-il pour ceux de juin.
2020-03-30 15:22:01.455 Status: dzVents: Debug: Horoscope v2.0: Processing device-adapter for Horoscope 1: Text device
2020-03-30 15:22:01.455 Status: dzVents: Debug: Horoscope v2.0: --- --- --- traitement Horoscope 2 --- --- --
2020-03-30 15:22:01.457 Status: dzVents: Debug: Horoscope v2.0: En ce qui vous concerne, Mars et Saturne sont en lien avec le domaine financier, il y a évidemment une crise dans ce domaine, accentuée semble-t-il pour ceux de juin.
2020-03-30 15:22:01.458 Status: dzVents: Debug: Horoscope v2.0: Processing device-adapter for Horoscope 2: Text device
2020-03-30 15:22:01.458 Status: dzVents: Info: Horoscope v2.0: ------ Finished horoscope.lua
boum
Post by boum »
I used this:
    on  =   {
		devices = {			'Switch'		},
        if not item.isHTTPResponse then
                    dz.openURL({
                        callback = signe
            end --for
        elseif item.isHTTPResponse and item.ok then
            print(signe, device, (item.ok and 'ok' or 'KO'))
papoo
Post by papoo »
mea culpa, to test I had reduced httpresponses to a single item and forgot to put it back to normal
papoo
Re: HTTPResponses array?  [Solved]
Post by papoo »
thanks boum and waaren
my finished script
auteur : papoo
Mise à jour : 30/03/2020
Création : 26/06/2016 =>V1.x https://github.com/papo-o/domoticz_scripts/blob/master/Lua/script_time_horoscope.lua
https://pon.fr/dzvents-horoscope-v2
https://easydomoticz.com/forum/
github : https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/horoscope.lua
Principe :
 Ce script vérifie toutes les x heures les horoscopes du site <a href="https://astro.rtl.fr/horoscope-jour-gratuit">astro.rtl.fr</a> signe par signe et mets à jour les éventuels devices texte associés sur domoticz
            { device = 'Horoscope 2',    signe = 'capricorne'},
            { device = 'Horoscope 3',  signe = 'vierge'},
            { device = 'Horoscope 4',    signe = 'balance'},
local device = ''
local signe = ''
----------- Fin variables à éditer ---------
local scriptName        = 'Horoscope'
local scriptVersion     = '2.0'
    active = true,
    on  =   {
        timer           =   { 'every 6 hours' },--https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting#timer_trigger_rules
        httpResponses   =   { 'belier','taureau','gemeaux','cancer','lion','vierge','balance','scorpion','sagittaire','capricorne','verseau','poissons' }    -- Trigger
        --httpResponses   =   { 'cancer','capricorne' }    -- Trigger
    logging =   {
        level    =   domoticz.LOG_DEBUG,                -- Seulement un niveau peut être actif; commenter les autres
        -- level    =   domoticz.LOG_INFO,              -- Only one level can be active; comment others
        -- level    =   domoticz.LOG_ERROR,
        -- level    =   domoticz.LOG_MODULE_EXEC_INFO,
     marker = scriptName..' v'..scriptVersion },
        local function TronquerTexte(texte, nb)  -- texte à tronquer, Nb maximum de caractère
        local sep ="[?;!.]"
        local DernierIndex = nil
        texte = string.sub(texte, 1, nb)
        local p = string.find(texte, sep, 1)
        DernierIndex = p
        while p do
            p = string.find(texte, sep, p + 1)
            if p then
                DernierIndex = p
        return(string.sub(texte, 1, DernierIndex))
function unescape(str)--remplace le code html
    if (str) then
    str = string.gsub( str, '&nbsp;', ' ')
    str = string.gsub( str, '&iexcl;', '¡')
    str = string.gsub( str, '&cent;', '¢')
    str = string.gsub( str, '&pound;', '£')
    str = string.gsub( str, '&curren;', '¤')
    str = string.gsub( str, '&yen;', '¥')
    str = string.gsub( str, '&brvbar;', '¦')
    str = string.gsub( str, '&sect;', '§')
    str = string.gsub( str, '&uml;', '¨')
    str = string.gsub( str, '&copy;', '©')
    str = string.gsub( str, '&ordf;', 'ª')
    str = string.gsub( str, '&laquo;', '«')
    str = string.gsub( str, '&not;', '¬')
    str = string.gsub( str, '&shy;', '­')
    str = string.gsub( str, '&reg;', '®')
    str = string.gsub( str, '&macr;', '¯')
    str = string.gsub( str, '&deg;', '°')
    str = string.gsub( str, '&plusmn;', '±')
    str = string.gsub( str, '&sup2;', '²')
    str = string.gsub( str, '&sup3;', '³')
    str = string.gsub( str, '&acute;', '´')
    str = string.gsub( str, '&micro;', 'µ')
    str = string.gsub( str, '&para;', '¶')
    str = string.gsub( str, '&middot;', '·')
    str = string.gsub( str, '&cedil;', '¸')
    str = string.gsub( str, '&sup1;', '¹')
    str = string.gsub( str, '&ordm;', 'º')
    str = string.gsub( str, '&raquo;', '»')
    str = string.gsub( str, '&frac14;', '¼')
    str = string.gsub( str, '&frac12;', '½')
    str = string.gsub( str, '&frac34;', '¾')
    str = string.gsub( str, '&iquest;', '¿')
    str = string.gsub( str, '&Agrave;', 'À')
    str = string.gsub( str, '&Aacute;', 'Á')
    str = string.gsub( str, '&Acirc;', 'Â')
    str = string.gsub( str, '&Atilde;', 'Ã')
    str = string.gsub( str, '&Auml;', 'Ä')
    str = string.gsub( str, '&Aring;', 'Å')
    str = string.gsub( str, '&AElig;', 'Æ')
    str = string.gsub( str, '&Ccedil;', 'Ç')
    str = string.gsub( str, '&Egrave;', 'È')
    str = string.gsub( str, '&Eacute;', 'É')
    str = string.gsub( str, '&Ecirc;', 'Ê')
    str = string.gsub( str, '&Euml;', 'Ë')
    str = string.gsub( str, '&Igrave;', 'Ì')
    str = string.gsub( str, '&Iacute;', 'Í')
    str = string.gsub( str, '&Icirc;', 'Î')
    str = string.gsub( str, '&Iuml;', 'Ï')
    str = string.gsub( str, '&ETH;', 'Ð')
    str = string.gsub( str, '&Ntilde;', 'Ñ')
    str = string.gsub( str, '&Ograve;', 'Ò')
    str = string.gsub( str, '&Oacute;', 'Ó')
    str = string.gsub( str, '&Ocirc;', 'Ô')
    str = string.gsub( str, '&Otilde;', 'Õ')
    str = string.gsub( str, '&Ouml;', 'Ö')
    str = string.gsub( str, '&times;', '×')
    str = string.gsub( str, '&Oslash;', 'Ø')
    str = string.gsub( str, '&Ugrave;', 'Ù')
    str = string.gsub( str, '&Uacute;', 'Ú')
    str = string.gsub( str, '&Ucirc;', 'Û')
    str = string.gsub( str, '&Uuml;', 'Ü')
    str = string.gsub( str, '&Yacute;', 'Ý')
    str = string.gsub( str, '&THORN;', 'Þ')
    str = string.gsub( str, '&szlig;', 'ß')
    str = string.gsub( str, '&agrave;', 'à')
    str = string.gsub( str, '&aacute;', 'á')
    str = string.gsub( str, '&acirc;', 'â')
    str = string.gsub( str, '&atilde;', 'ã')
    str = string.gsub( str, '&auml;', 'ä')
    str = string.gsub( str, '&aring;', 'å')
    str = string.gsub( str, '&aelig;', 'æ')
    str = string.gsub( str, '&ccedil;', 'ç')
    str = string.gsub( str, '&egrave;', 'è')
    str = string.gsub( str, '&eacute;', 'é')
    str = string.gsub( str, '&ecirc;', 'ê')
    str = string.gsub( str, '&euml;', 'ë')
    str = string.gsub( str, '&igrave;', 'ì')
    str = string.gsub( str, '&iacute;', 'í')
    str = string.gsub( str, '&icirc;', 'î')
    str = string.gsub( str, '&iuml;', 'ï')
    str = string.gsub( str, '&eth;', 'ð')
    str = string.gsub( str, '&ntilde;', 'ñ')
    str = string.gsub( str, '&ograve;', 'ò')
    str = string.gsub( str, '&oacute;', 'ó')
    str = string.gsub( str, '&ocirc;', 'ô')
    str = string.gsub( str, '&otilde;', 'õ')
    str = string.gsub( str, '&ouml;', 'ö')
    str = string.gsub( str, '&divide;', '÷')
    str = string.gsub( str, '&oslash;', 'ø')
    str = string.gsub( str, '&ugrave;', 'ù')
    str = string.gsub( str, '&uacute;', 'ú')
    str = string.gsub( str, '&ucirc;', 'û')
    str = string.gsub( str, '&uuml;', 'ü')
    str = string.gsub( str, '&yacute;', 'ý')
    str = string.gsub( str, '&thorn;', 'þ')
    str = string.gsub( str, '&yuml;', 'ÿ')
    str = string.gsub( str, '&euro;', '€')
    str = string.gsub( str, '&#(%d+);', function(n) return string.char(n) end )
    str = string.gsub( str, '&#x(%d+);', function(n) return string.char(tonumber(n,16)) end )
    str = string.gsub( str, '&amp;', '&' ) -- Be sure to do this after all others
    return (str)
                        callback = signe
            end --for
                        logWrite(horoscope)
                        dz.devices(record.device).updateText(horoscope or 'Pas d\'horoscope aujourd\'hui')
            end --for
