Deleted zwave devices keep re-appearing
heggink
Domoticz version: 12451
Post by heggink »
I have 3 FGSD002 Smoke Sensors one of which gave me hassle. It finally worked after including/excluding it a couple of times.
At some point, the controller showed 3 'ghost' devices for which I excluded the smoke sensor before. In the device list under the controller, I just deleted them.
Weirdly, every time I restart domoticz, they reappear.
Anyone any ideas on how I can permanently delete these entries?
Cheers,
H
DASHTICZ 🙃
P1 meter & solar panel
mgugu
Re: Deleted zwave devices keep re-appearing
Post by mgugu »
Afaik you cannot do that directly from domoticz, you need a tool (ex. zensys tool working on windows).
Working procedure given at https://community.openhab.org/t/remove- ... min/6640/6
For those of you trying to remove a node using zensys tool here are the steps required:
1 Highlight the node you believe has failed from the top left frame’s node list/table
2 Toggle the “Quene Overrided” checkbox for this selected node (a check should appear)
3 Send a NOP (i.e. no operation) command by selecting the exclamation mark from the tools menu
4 Check to see if the node is failed by selecting the “is node failed” icon from the tools menu. If it has failed, you should see a message stating it has failed in the lower right frame (i.e. log actions tab)
5 Select the “remove failed” icon from the tools menu
Note: If uncertain which icon from the tools menu corresponds to a particular action, hoover your mouse over each to receive a “tool tip” message specifying the corresponding action.
