lua socket require socket.http and socket.core problem and solution
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
Just in case anyone has the same problem when trying to run lua-socket on Debian on X86 (Intel NUC):
(this took me a couple of hours to solve correctly).
If you need to use http in lua, you need to add the module lua-socket.
You can't just grab any compiled lua-socket module from the web, because the .so files are specific to the hardware platform you use.
For Debian, the normal apt-get install will do to get the correct version:
sudo apt-get install lua-socket
But this will install the files in a different location than where Lua in Domoticz expects.
Domoticz expects the files to be in f.i. /usr/local/share/lua.
But in my Debian Jessy X86 system the system independent files (the .lua files) are located in: /usr/share/lua/5.2/
and the system dependent files (the .so files) are located in: /usr/lib/x86_64-linux-gnu/lua/5.2/.
If you then execute a script, you get the error: "module 'socket.core' not found" or "module 'socket.http' not found".
This is because the lua 'require' function cannot find these files in the default locations.
Before you call the following in your script;
local http = require("socket.http")
add;
package.cpath ="/usr/lib/x86_64-linux-gnu/lua/5.2/?.so;" .. package.cpath
package.path = "/usr/share/lua/5.2/?.lua;" .. package.path
These two lines prepend the default search locations with the actual folders the files are in.
If the require function is executed, it will look in the correct folders first and the error will be gone.
The best method to solve this is to find the correct file locations first before adding the possible locations to the function above.
It is also possible to add more search locations by adding the following after the last semicolon:
/folder-to-look-in/?.so;
If you can't find where the files are installed you can use f.i.
find /usr -name "core.so"
Derik
Re: lua socket require socket.http and socket.core problem and solution
Post by Derik »
i do have the same error in my system..
Please explane how to use this option..
hansonexperience
Domoticz version: 2020.1
Post by hansonexperience »
I have the same problem after updating to buster. How can I use your solution?
Solar: pvoutput, solarman, JFY inverter, enelogic, slimmemeterportal, Greenchoice
Weather: Davis VUE ISS, meteobridge wunderground, Asus WL -330N3G, leuven template
Website: http://www.hansonexperience.com / http://www.mooiweerboxtel.nl
cabbie
Post by cabbie »
I'm using domoticz for a couple of years now, and never required to register to this forum to solve issues.
however after installing the V2020.1 version my domoticz setup is broken regarding the lua issues.
Above solution partly solved my issue, when I add the code as below:
-- Require parameters
package.cpath ="/usr/lib/arm-linux-gnueabihf/lua/5.2/?.so;" .. package.cpath
I get the next error message:
2020-03-25 09:58:02.267 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_calculate_consumption.lua: error loading module 'socket.core' from file '/usr/lib/arm-linux-gnueabihf/lua/5.2/socket/core.so':
2020-03-25 09:58:02.267 /usr/lib/arm-linux-gnueabihf/lua/5.2/socket/core.so: undefined symbol: lua_gettop
anyone know how to solve this issue?
ErikM
Post by ErikM »
cabbie wrote: Wednesday 25 March 2020 10:04 Hi,
I'm facing the exact same problem since updating to V2020.1... Tried changing folders, lua5.2 to 5.3 etc, but no result.
Edit: I solved the issue by putting -- in front of the lines in the script. Apparently they are not required anymore.
cabbie
Post by cabbie »
ErikM wrote: Thursday 26 March 2020 8:48
cabbie wrote: Wednesday 25 March 2020 10:04 .
Specifically for the script I quoted it isn't required anymore, however I still require the socket.http in another LUA script to upload data to pvoutput.
so my problem still persists.
never mind. I converted my script to dzVents zo no more Lua required...
DiaDomo
Post by DiaDomo »
Hi Cabbie,
I have the same problem with the lua script "script_time_upload_to_PVOutput.lua".
2020-03-28 13:35:00.054 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_upload_to_PVoutput.lua: .../domoticz/scripts/lua/script_time_upload_to_PVoutput.lua:47: attempt to index a nil value (global 'http')
Unfortunately I'm not very familiar with dzVents (yet). Could you please share your solution?
Thx in advance
Raspberry PI 2 & 3 & 4 | RFlink | MySensors | ESP32 | Homebridge | Tasmota Sonoff | Zigbee2Mqtt | ADS-B
DiaDomo wrote: Saturday 28 March 2020 14:01 I have the same problem with the lua script "script_time_upload_to_PVOutput.lua".
You can find a dzVents pvoutput script here
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
