Revert to previous version
zenodalla
Domoticz version: 4
Post by zenodalla »
Hi, I have a RPi3b+ running osmc. For this reason I think I cannot run the latest domoticz 2020 ver. In fact it doesn't work anymore. Yesterday it was all ok, then an update message appeared in the web interface, so I updated it, but it was an error. I read today after wasting hours that a new version of linux is needed and I can't update it. So my question is: how do i revert to previous version? I found in the github page a section called releases in which i found this release "Stable Release 4.10717" but I don't know how to instll it and I can't find a guide about how to install it. Can anyone help me?
thank you all
edit: I didn't make a backup :(
edit edit: I found an sd card which contains a versione of domoticz that i don't update from last year. So if I copy the domoticz folder from that sd home/pi/domoticz to /home/osmc after I install the current 2020 ver.1 it should work, doesn't it?
Domange
Re: Revert to previous version
Post by Domange »
I can't find how to retrieve a previous binary version but I follow the instructions indicated here https://www.domoticz.com/wiki/Build_Dom ... rom_source
I choose the version tagged 4.10726 on the source control
I must adapt the script because I have 2 errors, one about Lua 5.2 (the 5.3 version was installed in the document) and the other is about the BOOST library.
I do quick and ugly, I remove the 2 tests but It works fine.
So I have the following CMakeLists.txt file
#set to minimum version that supports clean build on cygwin
cmake_minimum_required(VERSION 2.8.4)
project(domoticz)
## required min. libBoost version
SET(DOMO_MIN_LIBBOOST_VERSION 106000)
MACRO(Gitversion_GET_REVISION dir variable)
  EXECUTE_PROCESS(COMMAND ${GIT_EXECUTABLE} --git-dir ./.git rev-list HEAD --count
    WORKING_DIRECTORY ${dir}
    OUTPUT_VARIABLE ${variable}
    OUTPUT_STRIP_TRAILING_WHITESPACE)
ENDMACRO(Gitversion_GET_REVISION)
Gitversion_GET_REVISION("${CMAKE_SOURCE_DIR}" ProjectRevision)
IF(NOT ProjectRevision)
  MESSAGE(STATUS "Failed to get ProjectRevision from git")
  IF(EXISTS ${CMAKE_SOURCE_DIR}/appversion.default)
    MESSAGE(STATUS "Read ProjectRevision from appversion.default")
    FILE(STRINGS ${CMAKE_SOURCE_DIR}/appversion.default AppVersionContent)
    LIST(GET AppVersionContent 0 AppVersionContent)
    STRING(REPLACE " " ";" AppVersionContent ${AppVersionContent})
    LIST(GET AppVersionContent 2 ProjectRevision)
  ELSE(EXISTS ${CMAKE_SOURCE_DIR}/appversion.default)
    MESSAGE(STATUS "No appversion.default, set ProjectRevision to 0")
    set (ProjectRevision 0)
  ENDIF(EXISTS ${CMAKE_SOURCE_DIR}/appversion.default)
ELSE(NOT ProjectRevision)
  MATH(EXPR ProjectRevision "${ProjectRevision}+2107")
ENDIF(NOT ProjectRevision)
MESSAGE(STATUS "###########################")
MESSAGE(STATUS "Compiling Revision #${ProjectRevision}")
# The version number.
set (domoticz_VERSION_MAJOR 4)
set (domoticz_VERSION_MINOR 0)
set (domoticz_VERSION_PATCH ${ProjectRevision})
if (CMAKE_CXX_COMPILER_ID MATCHES "Clang")
  set(CMAKE_CXX_STANDARD 11)
  set(CMAKE_CXX_STANDARD_REQUIRED ON)
  set(CXX_EXTENSIONS NO)
endif()
option(USE_OPENSSL_STATIC "Link OpenSSL static" YES)
IF(USE_OPENSSL_STATIC)
	set(OPENSSL_USE_STATIC_LIBS TRUE)
ENDIF(USE_OPENSSL_STATIC)
option(USE_BUILTIN_LUA "Use builtin lua library" YES)
#IF(USE_BUILTIN_LUA)
IF(CMAKE_SYSTEM_NAME STREQUAL "Darwin")
	add_definitions(-DLUA_USE_MACOSX)
ENDIF()
add_subdirectory (lua)
get_directory_property (LUA_LIBRARIES DIRECTORY lua
	DEFINITION LUA_LIBRARIES)
option(USE_BUILTIN_MQTT "Use builtin Mosquitto library" YES)
IF(USE_BUILTIN_MQTT)
  message(STATUS "Using builtin Mosquitto library")
  add_subdirectory (MQTT)
  get_directory_property (MQTT_LIBRARIES DIRECTORY MQTT
      DEFINITION MQTT_LIBRARIES)
  add_definitions(-DBUILTIN_MQTT)
ELSE(USE_BUILTIN_MQTT)
  find_path(MQTT_INCLUDE_DIRS NAMES mosquittopp.h)
  IF(MQTT_INCLUDE_DIRS)
    message(STATUS "Found mosquittopp.h at: ${MQTT_INCLUDE_DIRS}")
    find_library(MQTT_LIBRARIES NAMES libmosquittopp.so)
    IF(MQTT_LIBRARIES)
      message(STATUS "Found libmosquittopp at: ${MQTT_LIBRARIES}")
    ENDIF(MQTT_LIBRARIES)
    INCLUDE_DIRECTORIES(${MQTT_INCLUDE_DIRS})
  ELSE(MQTT_INCLUDE_DIRS)
     message(FATAL_ERROR "Mosquitto includes or library cannot be found, and you ask to NOT use builtin")
  ENDIF(MQTT_INCLUDE_DIRS)
ENDIF(USE_BUILTIN_MQTT)
option(USE_BUILTIN_SQLITE "Use builtin sqlite library" YES)
IF(USE_BUILTIN_SQLITE)
  add_subdirectory (sqlite)
  get_directory_property (SQLite_LIBRARIES DIRECTORY sqlite
      DEFINITION SQLite_LIBRARIES)
ELSE(USE_BUILTIN_SQLITE)
  find_package(PkgConfig)
  pkg_check_modules(SQLite QUIET sqlite3)
  IF(SQLite_FOUND)
    INCLUDE_DIRECTORIES(${SQLite_INCLUDE_DIRS})
    add_definitions(-DWITH_EXTERNAL_SQLITE)
  ELSE(SQLite_FOUND)
    MESSAGE(FATAL_ERROR "SQLite3 not found but USE_BUILTIN_SQLITE=NO")
  ENDIF(SQLite_FOUND)
ENDIF(USE_BUILTIN_SQLITE)
option(USE_PYTHON "Use Python for Plugins and Event-Scripts" YES)
IF(USE_PYTHON)
  find_package(PythonInterp 3.4)
  find_package(PythonLibs 3.4)
  IF(PYTHONLIBS_FOUND)
    MESSAGE(STATUS "Python3 includes found at: ${PYTHON_INCLUDE_PATH}")
    INCLUDE_DIRECTORIES(${PYTHON_INCLUDE_PATH})
    add_definitions(-DENABLE_PYTHON)
  ELSE(PYTHONLIBS_FOUND)
    MESSAGE(FATAL_ERROR "Python3 not found on your system, use USE_PYTHON=NO or sudo apt-get install python3-dev)")
  ENDIF(PYTHONLIBS_FOUND)
ENDIF(USE_PYTHON)
SET(EXECUTABLE_OUTPUT_PATH "" CACHE INTERNAL
  "Where to put the executables for Domoticz"
INCLUDE(CheckIncludeFile)
CHECK_INCLUDE_FILE (execinfo.h HAVE_EXECINFO_H)
IF(HAVE_EXECINFO_H)
  # FreeBSD has to include libexecinfo
  IF(CMAKE_SYSTEM_NAME STREQUAL "FreeBSD")
    find_library(EXECINFO_LIBRARIES NAMES libexecinfo.so)
    IF(EXECINFO_LIBRARIES)
      ADD_DEFINITIONS(-DHAVE_EXECINFO_H)
    ENDIF()
  ELSEIF(CMAKE_SYSTEM_NAME STREQUAL "NetBSD")
    ENDIF()
  ELSE()
  ENDIF()
ENDIF(HAVE_EXECINFO_H)
INCLUDE(CheckIncludeFiles)
option(INCLUDE_LINUX_I2C "Include I2C support" YES)
IF (INCLUDE_LINUX_I2C)
	CHECK_INCLUDE_FILES ("sys/types.h;linux/i2c-dev.h;linux/i2c.h" HAVE_LINUX_I2C_H)
	IF (HAVE_LINUX_I2C_H)
		message(STATUS "Building with I2C support")
		add_definitions(-DHAVE_LINUX_I2C)
	ELSE()
		message(WARNING "I2C support disabled: headers not found!")
	ENDIF (HAVE_LINUX_I2C_H)
ENDIF (INCLUDE_LINUX_I2C)
option(INCLUDE_SPI "Include SPI support" YES)
IF (INCLUDE_SPI)
	CHECK_INCLUDE_FILES ("sys/types.h;linux/spi/spidev.h" HAVE_LINUX_SPI_H)
	IF (HAVE_LINUX_SPI_H)
		message(STATUS "Building with SPI support")
		add_definitions(-DHAVE_LINUX_SPI)
	ELSE()
		message(WARNING "SPI support disabled: headers not found!")
	ENDIF (HAVE_LINUX_SPI_H)
ENDIF (INCLUDE_SPI)
#set(CMAKE_EXE_LINKER_FLAGS "-static")
# Macro for setting up precompiled headers. Usage:
#   add_precompiled_header(target header.h [FORCEINCLUDE])
# MSVC: A source file with the same name as the header must exist and
# be included in the target (E.g. header.cpp).
# MSVC: Add FORCEINCLUDE to automatically include the precompiled
# header file from every source file.
# GCC: The precompiled header is always automatically included from
# every header file.
MACRO(ADD_PRECOMPILED_HEADER _targetName _input)
  GET_FILENAME_COMPONENT(_inputWe ${_input} NAME_WE)
  SET(pch_source ${_inputWe}.cpp)
  FOREACH(arg ${ARGN})
    IF(arg STREQUAL FORCEINCLUDE)
      SET(FORCEINCLUDE ON)
    ELSE(arg STREQUAL FORCEINCLUDE)
      SET(FORCEINCLUDE OFF)
    ENDIF(arg STREQUAL FORCEINCLUDE)
  ENDFOREACH(arg)
  IF(MSVC)
    GET_TARGET_PROPERTY(sources ${_targetName} SOURCES)
    SET(_sourceFound FALSE)
    FOREACH(_source ${sources})
      SET(PCH_COMPILE_FLAGS "")
      IF(_source MATCHES \\.\(cc|cxx|cpp\)$)
  GET_FILENAME_COMPONENT(_sourceWe ${_source} NAME_WE)
  IF(_sourceWe STREQUAL ${_inputWe})
    SET(PCH_COMPILE_FLAGS "${PCH_COMPILE_FLAGS} /Yc${_input}")
    SET(_sourceFound TRUE)
  ELSE(_sourceWe STREQUAL ${_inputWe})
    SET(PCH_COMPILE_FLAGS "${PCH_COMPILE_FLAGS} /Yu${_input}")
    IF(FORCEINCLUDE)
      SET(PCH_COMPILE_FLAGS "${PCH_COMPILE_FLAGS} /FI${_input}")
    ENDIF(FORCEINCLUDE)
  ENDIF(_sourceWe STREQUAL ${_inputWe})
  SET_SOURCE_FILES_PROPERTIES(${_source} PROPERTIES COMPILE_FLAGS "${PCH_COMPILE_FLAGS}")
      ENDIF(_source MATCHES \\.\(cc|cxx|cpp\)$)
    ENDFOREACH()
    IF(NOT _sourceFound)
      MESSAGE(FATAL_ERROR "A source file for ${_input} was not found. Required for MSVC builds.")
    ENDIF(NOT _sourceFound)
  ENDIF(MSVC)
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wno-switch -Wno-parentheses-equality -Wno-deprecated-declarations -Wno-tautological-compare -Wno-unused-value -Wno-comment -Wno-unsequenced -Wno-logical-op-parentheses -Wno-literal-conversion")
  ENDIF()
  IF(CMAKE_SYSTEM_NAME STREQUAL "OpenBSD")
    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -pthread")
  ENDIF()
  ENDIF()
  IF(CMAKE_COMPILER_IS_GNUCXX)
    SET(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++11")
    #SET(CMAKE_C_FLAGS "${CMAKE_C_FLAGS} -Wno-switch")
    #ADD_DEFINITIONS( -Wall -O0 -ggdb )
    #ADD_DEFINITIONS( -Wfatal-errors -Wformat=2 -Werror=format-security )
    GET_FILENAME_COMPONENT(_name ${_input} NAME)
    SET(_source "${CMAKE_CURRENT_SOURCE_DIR}/${_input}")
    SET(_outdir "${CMAKE_CURRENT_BINARY_DIR}/${_name}.gch")
    MAKE_DIRECTORY(${_outdir})
    SET(_output "${_outdir}/.c++")
    STRING(TOUPPER "CMAKE_CXX_FLAGS_${CMAKE_BUILD_TYPE}" _flags_var_name)
    # Strip out -Wl,… linker directives as they make GCC fail
    STRING(REGEX REPLACE " -Wl,[^ ]*" " " _compiler_FLAGS " ${CMAKE_CXX_FLAGS} ${${_flags_var_name}}")
    GET_DIRECTORY_PROPERTY(_directory_flags INCLUDE_DIRECTORIES)
    FOREACH(item ${_directory_flags})
      LIST(APPEND _compiler_FLAGS "-I${item}")
    ENDFOREACH(item)
    GET_DIRECTORY_PROPERTY(_directory_flags COMPILE_DEFINITIONS)
      LIST(APPEND _compiler_FLAGS "-D${item}")
    ENDFOREACH(item)
    SEPARATE_ARGUMENTS(_compiler_FLAGS)
    MESSAGE("${CMAKE_CXX_COMPILER} ${CMAKE_CXX_COMPILER_ARG1} ${_compiler_FLAGS} -x c++-header -o ${_output} ${_source}")
    ADD_CUSTOM_COMMAND(
      OUTPUT ${_output}
      COMMAND ${CMAKE_CXX_COMPILER} ${CMAKE_CXX_COMPILER_ARG1} ${_compiler_FLAGS} -x c++-header -o ${_output} ${_source}
      DEPENDS ${_source} )
    ADD_CUSTOM_TARGET(${_targetName}_gch DEPENDS ${_output})
    ADD_DEPENDENCIES(${_targetName} ${_targetName}_gch)
    SET_TARGET_PROPERTIES(${_targetName} PROPERTIES COMPILE_FLAGS "-include ${_name} -Winvalid-pch")
  ENDIF(CMAKE_COMPILER_IS_GNUCXX)
ENDMACRO()
FIND_PROGRAM(GIT_EXECUTABLE git
  DOC "git command line client")
include_directories(${CMAKE_SOURCE_DIR}/main)
include_directories(${CMAKE_SOURCE_DIR}/tinyxpath)
# a custom target that is always built
ADD_CUSTOM_TARGET(revisiontag ALL)
# creates appversion.h using cmake script
ADD_CUSTOM_COMMAND(TARGET revisiontag COMMAND ${CMAKE_COMMAND}
   -DSOURCE_DIR=${CMAKE_CURRENT_SOURCE_DIR}
   -P ${CMAKE_CURRENT_SOURCE_DIR}/getgit.cmake)
## Target
set(
domoticz_SRCS
main/stdafx.cpp
main/BaroForecastCalculator.cpp
main/CmdLine.cpp
main/Camera.cpp
main/domoticz.cpp
main/dzVents.cpp
main/EventSystem.cpp
main/EventsPythonModule.cpp
main/EventsPythonDevice.cpp
main/Helper.cpp
main/IFTTT.cpp
main/localtime_r.cpp
main/Logger.cpp
main/LuaCommon.cpp
main/LuaHandler.cpp
main/mainworker.cpp
main/RFXNames.cpp
main/Scheduler.cpp
main/SignalHandler.cpp
main/SQLHelper.cpp
main/SunRiseSet.cpp
main/TrendCalculator.cpp
main/WebServer.cpp
main/WebServerHelper.cpp
main/WindCalculation.cpp
push/BasePush.cpp
push/FibaroPush.cpp
push/GooglePubSubPush.cpp
push/HttpPush.cpp
push/InfluxPush.cpp
push/WebsocketPush.cpp
httpclient/HTTPClient.cpp
httpclient/UrlEncode.cpp
hardware/1Wire.cpp
hardware/1Wire/1WireByOWFS.cpp
hardware/1Wire/1WireByKernel.cpp
hardware/1Wire/1WireCommon.cpp
hardware/1Wire/1WireForWindows.cpp
hardware/AccuWeather.cpp
hardware/AnnaThermostat.cpp
hardware/Arilux.cpp
hardware/ASyncSerial.cpp
hardware/ASyncTCP.cpp
hardware/AtagOne.cpp
hardware/BleBox.cpp
hardware/cayenne_lpp/CayenneLPP_Dec.cpp
hardware/ColorSwitch.cpp
hardware/Comm5Serial.cpp
hardware/Comm5SMTCP.cpp
hardware/Comm5TCP.cpp
hardware/csocket.cpp
hardware/CurrentCostMeterBase.cpp
hardware/CurrentCostMeterSerial.cpp
hardware/CurrentCostMeterTCP.cpp
hardware/Daikin.cpp
hardware/DarkSky.cpp
hardware/DavisLoggerSerial.cpp
hardware/DenkoviDevices.cpp
hardware/DenkoviUSBDevices.cpp
hardware/DenkoviTCPDevices.cpp
hardware/DomoticzHardware.cpp
hardware/DomoticzInternal.cpp
hardware/DomoticzTCP.cpp
hardware/Dummy.cpp
hardware/EcoCompteur.cpp
hardware/EcoDevices.cpp
hardware/eHouseTCP.cpp
hardware/eHouse/EhouseEvents.cpp
hardware/eHouse/EhouseTcpClient.cpp
hardware/eHouse/EhouseUdpListener.cpp
hardware/EnOceanESP2.cpp
hardware/EnOceanESP3.cpp
hardware/EnphaseAPI.cpp
hardware/Ec3kMeterTCP.cpp
hardware/EvohomeBase.cpp
hardware/EvohomeRadio.cpp
hardware/EvohomeScript.cpp
hardware/EvohomeSerial.cpp
hardware/EvohomeTCP.cpp
hardware/EvohomeWeb.cpp
hardware/ETH8020.cpp
hardware/FritzboxTCP.cpp
hardware/GoodweAPI.cpp
hardware/Gpio.cpp
hardware/GpioPin.cpp
hardware/HardwareMonitor.cpp
hardware/HarmonyHub.cpp
hardware/Honeywell.cpp
hardware/HEOS.cpp
hardware/I2C.cpp
hardware/ICYThermostat.cpp
hardware/InComfort.cpp
hardware/KMTronicBase.cpp
hardware/KMTronic433.cpp
hardware/KMTronicSerial.cpp
hardware/KMTronicTCP.cpp
hardware/KMTronicUDP.cpp
hardware/Kodi.cpp
hardware/Limitless.cpp
hardware/LogitechMediaServer.cpp
hardware/Meteostick.cpp
hardware/MochadTCP.cpp
hardware/MQTT.cpp
hardware/MultiFun.cpp
hardware/MySensorsBase.cpp
hardware/MySensorsSerial.cpp
hardware/MySensorsTCP.cpp
hardware/MySensorsMQTT.cpp
hardware/NefitEasy.cpp
hardware/Nest.cpp
hardware/NestOAuthAPI.cpp
hardware/Netatmo.cpp
hardware/HttpPoller.cpp
hardware/OnkyoAVTCP.cpp
hardware/OpenWeatherMap.cpp
hardware/OpenWebNetTCP.cpp
hardware/OpenWebNetUSB.cpp
hardware/openwebnet/bt_openwebnet.cpp
hardware/OpenZWave.cpp
hardware/openzwave/control_panel/ozwcp.cpp
hardware/openzwave/control_panel/zwavelib.cpp
hardware/OTGWBase.cpp
hardware/OTGWSerial.cpp
hardware/OTGWTCP.cpp
hardware/PanasonicTV.cpp
hardware/P1MeterBase.cpp
hardware/P1MeterSerial.cpp
hardware/P1MeterTCP.cpp
hardware/PhilipsHue/PhilipsHue.cpp
hardware/PhilipsHue/PhilipsHueHelper.cpp
hardware/PhilipsHue/PhilipsHueSensors.cpp
hardware/PiFace.cpp
hardware/Pinger.cpp
hardware/PVOutput_Input.cpp
hardware/RAVEn.cpp
hardware/Rego6XXSerial.cpp
hardware/RelayNet.cpp
hardware/RFLinkBase.cpp
hardware/RFLinkSerial.cpp
hardware/RFLinkTCP.cpp
hardware/RFXBase.cpp
hardware/RFXComSerial.cpp
hardware/RFXComTCP.cpp
hardware/Rtl433.cpp
hardware/S0MeterBase.cpp
hardware/S0MeterSerial.cpp
hardware/S0MeterTCP.cpp
hardware/SatelIntegra.cpp
hardware/SBFSpot.cpp
hardware/serial/serial.cpp
hardware/serial/impl/unix.cpp
hardware/SolarEdgeAPI.cpp
hardware/SolarMaxTCP.cpp
hardware/Sterbox.cpp
hardware/SysfsGpio.cpp
hardware/Tado.cpp
hardware/TCPProxy/tcpproxy_server.cpp
hardware/TE923.cpp
hardware/TE923Tool.cpp
hardware/TeleinfoBase.cpp
hardware/TeleinfoSerial.cpp
hardware/Tellstick.cpp
hardware/TellstickFactory.cpp
hardware/Thermosmart.cpp
hardware/ToonThermostat.cpp
hardware/TTNMQTT.cpp
hardware/USBtin.cpp
hardware/USBtin_MultiblocV8.cpp
hardware/VolcraftCO20.cpp
hardware/Winddelen.cpp
hardware/WOL.cpp
hardware/Wunderground.cpp
hardware/XiaomiGateway.cpp
hardware/Yeelight.cpp
hardware/YouLess.cpp
hardware/ZiBlueBase.cpp
hardware/ZiBlueSerial.cpp
hardware/ZiBlueTCP.cpp
hardware/ZWaveBase.cpp
hardware/plugins/DelayedLink.cpp
hardware/plugins/Plugins.cpp
hardware/plugins/PluginManager.cpp
hardware/plugins/PluginProtocols.cpp
hardware/plugins/PluginTransports.cpp
hardware/plugins/PythonObjects.cpp
notifications/NotificationBase.cpp
notifications/NotificationBrowser.cpp
notifications/NotificationEmail.cpp
notifications/NotificationGCM.cpp
notifications/NotificationHelper.cpp
notifications/NotificationHTTP.cpp
notifications/NotificationKodi.cpp
notifications/NotificationLogitechMediaServer.cpp
notifications/NotificationPushbullet.cpp
notifications/NotificationProwl.cpp
notifications/NotificationPushover.cpp
notifications/NotificationPushsafer.cpp
notifications/NotificationPushalot.cpp
notifications/NotificationSMS.cpp
notifications/NotificationTelegram.cpp
smtpclient/SMTPClient.cpp
tcpserver/TCPClient.cpp
tcpserver/TCPServer.cpp
webserver/Base64.cpp
webserver/connection.cpp
webserver/connection_manager.cpp
webserver/cWebem.cpp
webserver/fastcgi.cpp
webserver/mime_types.cpp
webserver/proxycereal.cpp
webserver/proxyclient.cpp
webserver/reply.cpp
webserver/request_handler.cpp
webserver/request_parser.cpp
webserver/server.cpp
webserver/Websockets.cpp
webserver/WebsocketHandler.cpp
json/json_reader.cpp
json/json_value.cpp
json/json_writer.cpp
tinyxpath/action_store.cpp
tinyxpath/htmlutil.cpp
tinyxpath/lex_util.cpp
tinyxpath/node_set.cpp
tinyxpath/tinystr.cpp
tinyxpath/tinyxml.cpp
tinyxpath/tinyxmlerror.cpp
tinyxpath/tinyxmlparser.cpp
tinyxpath/tokenlist.cpp
tinyxpath/xml_util.cpp
tinyxpath/xpath_expression.cpp
tinyxpath/xpath_processor.cpp
tinyxpath/xpath_stream.cpp
tinyxpath/xpath_stack.cpp
tinyxpath/xpath_static.cpp
tinyxpath/xpath_syntax.cpp
add_executable(domoticz ${domoticz_SRCS})
# explicitly say that the executable depends on the revisiontag
add_dependencies(domoticz revisiontag)
INCLUDE(TestBigEndian)
TEST_BIG_ENDIAN(BIGENDIAN)
IF(${BIGENDIAN})
     ADD_DEFINITIONS(-DIS_BIG_ENDIAN)
ENDIF(${BIGENDIAN})
## Link libraries
# Find MD5/RMD160/SHA library
find_package(OpenSSL REQUIRED)
if(NOT OPENSSL_INCLUDE_DIR)
	message(SEND_ERROR "Failed to find OpenSSL include files (ssl.h), no HTTPS support")
endif()
if(NOT OPENSSL_FOUND)
  message(SEND_ERROR "Failed to find the OpenSSL library, no HTTPS support")
  find_library(MD_LIBRARY NAMES md)
  if(MD_LIBRARY)
    target_link_libraries(domoticz ${MD_LIBRARY})
  endif(MD_LIBRARY)
else()
  message(STATUS "OPENSSL_LIBRARIES: ${OPENSSL_LIBRARIES}")
  add_definitions(-DWWW_ENABLE_SSL)
  include_directories(${OPENSSL_INCLUDE_DIR})
  target_link_libraries(domoticz ${OPENSSL_LIBRARIES})
endif()
# Boost
option(USE_STATIC_BOOST "Build with static BOOST libraries" YES)
set(Boost_USE_STATIC_LIBS ${USE_STATIC_BOOST})
set(Boost_USE_MULTITHREADED ON)
unset(Boost_INCLUDE_DIR CACHE)
unset(Boost_LIBRARY_DIRS CACHE)
find_package(Boost REQUIRED COMPONENTS thread system)
if(USE_STATIC_BOOST)
   message(STATUS "Linking against boost static libraries")
else(USE_STATIC_BOOST)
   message(STATUS "Linking against boost dynamic libraries")
endif(USE_STATIC_BOOST)
include_directories(${Boost_INCLUDE_DIRS})
# ZLIB
option(USE_BUILTIN_ZLIB "Use builtin zlib library" NO)
if(USE_BUILTIN_ZLIB)
  add_subdirectory (zlib)
  include_directories(${ZLIB_INCLUDE_DIRS})
else(USE_BUILTIN_ZLIB)
  find_package(ZLIB REQUIRED)
  if(ZLIB_FOUND)
    MESSAGE(STATUS "ZLIB libraries found at: ${ZLIB_LIBRARIES}")
    MESSAGE(STATUS "ZLIB includes found at: ${ZLIB_INCLUDE_DIRS}")
  else()
    MESSAGE(FATAL_ERROR "ZLIB not found on your system, see install.txt how to get them installed. (for example 'sudo apt-get install zlib1g-dev')")
  endif(ZLIB_FOUND)
endif(USE_BUILTIN_ZLIB)
# MINIZIP
option(USE_BUILTIN_MINIZIP "Use builtin minizip library" YES)
if(USE_BUILTIN_MINIZIP)
  add_subdirectory(zip)
  get_directory_property(MINIZIP_LIBRARIES DIRECTORY zip DEFINITION MINIZIP_LIBRARIES)
  get_directory_property(MINIZIP_INCLUDE_DIRS DIRECTORY zip DEFINITION MINIZIP_INCLUDE_DIRS)
  include_directories(${MINIZIP_INCLUDE_DIRS})
else(USE_BUILTIN_MINIZIP)
  pkg_check_modules(MINIZIP minizip)
  if(MINIZIP_FOUND)
    MESSAGE(STATUS "MINIZIP libraries found at: ${MINIZIP_LIBRARIES}")
    MESSAGE(STATUS "MINIZIP includes found at: ${MINIZIP_INCLUDE_DIRS}")
  else()
    MESSAGE(FATAL_ERROR "MINIZIP not found on your system, see install.txt how to get them installed. (for example 'sudo apt-get install libminizip-dev')")
  endif(MINIZIP_FOUND)
endif(USE_BUILTIN_MINIZIP)
# CURL
FIND_PACKAGE(CURL)
IF(CURL_FOUND)
  MESSAGE(STATUS "Curl libraries found at: ${CURL_LIBRARIES}")
  MESSAGE(STATUS "Curl includes found at: ${CURL_INCLUDE_DIRS}")
  INCLUDE_DIRECTORIES(${CURL_INCLUDE_DIRS})
  # add_definitions(-DWWW_ENABLE_SSL)
else()
  MESSAGE(FATAL_ERROR "cURL not found on your system, see install.txt how to get them installed. (for example 'sudo apt-get install curl libcurl4-gnutls-dev')")
ENDIF(CURL_FOUND)
# USB
option(WITH_LIBUSB "Enable libusb support" YES)
if(WITH_LIBUSB)
  find_path(LIBUSB_INCLUDE_DIR usb.h
     HINTS ${PC_LIBUSB_INCLUDEDIR} ${PC_LIBUSB_INCLUDE_DIRS})
  find_library(LIBUSB_LIBRARY NAMES usb
     HINTS ${PC_LIBUSB_LIBDIR} ${PC_LIBUSB_LIBRARY_DIRS})
  set(LIBUSB_LIBRARIES ${LIBUSB_LIBRARY})
  find_package_handle_standard_args(LIBUSB  DEFAULT_MSG  LIBUSB_LIBRARIES LIBUSB_INCLUDE_DIR)
  IF(LIBUSB_FOUND)
    MESSAGE(STATUS "LIBUSB found at: ${LIBUSB_LIBRARIES}")
    add_definitions(-DWITH_LIBUSB)
    target_link_libraries(domoticz ${LIBUSB_LIBRARIES})
  else()
    MESSAGE(STATUS "==== LibUSB not found, support for TE923/Voltcraft disabled!")
  ENDIF(LIBUSB_FOUND)
endif(WITH_LIBUSB)
## support lua popen on Linux platforms
#IF(${CMAKE_SYSTEM_NAME} MATCHES "Linux")
# SET(OperatingSystem "Linux")
# add_definitions(-DLUA_USE_LINUX)
#ENDIF(${CMAKE_SYSTEM_NAME} MATCHES "Linux")
# OpenZWave
# try to find open-zwave, if found, include support
option(USE_STATIC_OPENZWAVE "Build with static OpenZwave libraries" YES)
if(USE_STATIC_OPENZWAVE)
  find_library(OpenZWave NAMES libopenzwave.a HINTS "../open-zwave-read-only" "../open-zwave-read-only/cpp/build")
  set(OPENZWAVE_LIB ${OpenZWave})
else()
  pkg_check_modules(OPENZWAVE libopenzwave)
  if(OPENZWAVE_FOUND)
    MESSAGE(STATUS "==== OpenZWave package found!")
    find_library(OpenZWave NAMES libopenzwave.so HINTS ${OPENZWAVE_LIBRARY_DIRS})
    message(STATUS ${OpenZWave})
  endif()
endif()
IF(OpenZWave)
  target_link_libraries(domoticz ${OpenZWave})
  include_directories(${CMAKE_SOURCE_DIR}/hardware/openzwave)
  add_definitions(-DWITH_OPENZWAVE)
  # open-zwave needs libudev if statically linked
  IF(USE_STATIC_OPENZWAVE)
      set(IOKIT_LIBRARY "-framework IOKit -framework CoreFoundation" CACHE FILEPATH "IOKit framework" FORCE)
      target_link_libraries(domoticz ${IOKIT_LIBRARY})
    ELSEIF(CMAKE_SYSTEM_NAME STREQUAL "FreeBSD")
      MESSAGE(STATUS "Building on FreeBSD, libudev not needed!")
      FIND_PATH(ICONV_INCLUDE_DIR iconv.h)
      FIND_LIBRARY(ICONV_LIBRARIES NAMES iconv libiconv libiconv-2 c)
      IF(ICONV_INCLUDE_DIR AND ICONV_LIBRARIES)
        SET(ICONV_FOUND TRUE)
        #target_link_libraries(domoticz ${ICONV_INCLUDE_DIR})
        target_link_libraries(domoticz ${ICONV_LIBRARIES} -lrt)
        message(STATUS ${ICONV_LIBRARIES})
      ELSE()
        MESSAGE(FATAL_ERROR "libiconv not found on your system")
      ENDIF(ICONV_INCLUDE_DIR AND ICONV_LIBRARIES)
      MESSAGE(STATUS "Building on NetBSD, libudev not needed!")
    ELSE()
      find_library(UDEV NAMES libudev.a)
      IF(UDEV)
        message(STATUS ${UDEV})
        target_link_libraries(domoticz ${UDEV} -lrt -lresolv)
      ELSE()
        find_library(UDEV NAMES libudev.so)
        IF(UDEV)
        ELSE()
           MESSAGE(FATAL_ERROR "LIB UDEV not found on your system, see install.txt how to get them installed.\nsudo apt-get install libudev-dev")
        ENDIF(UDEV)
      ENDIF(UDEV)
    ENDIF()
  ENDIF(USE_STATIC_OPENZWAVE)
ELSE()
  MESSAGE(STATUS "==== OpenZWave not found, support disabled!")
ENDIF(OpenZWave)
IF(EXISTS /sys/class/gpio)
  message(STATUS "GPIO is available")
  add_definitions(-DWITH_GPIO)
ELSE()
  message(STATUS "GPIO is not available")
ENDIF()
find_path(TELLDUSCORE_INCLUDE NAMES telldus-core.h)
if (TELLDUSCORE_INCLUDE)
  message(STATUS "Found telldus-core (telldus-core.h) at : ${TELLDUSCORE_INCLUDE}")
  find_library(TELLDUS_LIBRARIES NAMES libtelldus-core.so)
  if(TELLDUS_LIBRARIES)
    message(STATUS "Found libtelldus-core at : ${TELLDUS_LIBRARIES}, adding telldus support")
    add_definitions(-DWITH_TELLDUSCORE)
  endif(TELLDUS_LIBRARIES)
else()
  message(STATUS "Not found telldus-core (telldus-core.h), not adding tellstick support")
endif (TELLDUSCORE_INCLUDE)
  target_link_libraries(domoticz ${Boost_LIBRARIES} ${ZLIB_LIBRARIES} ${MINIZIP_LIBRARIES} ${CURL_LIBRARIES} pthread ${LUA_LIBRARIES} ${MQTT_LIBRARIES} ${SQLite_LIBRARIES} ${CMAKE_DL_LIBS} ${TELLDUS_LIBRARIES})
elseif(CMAKE_SYSTEM_NAME STREQUAL "OpenBSD")
  target_link_libraries(domoticz ${Boost_LIBRARIES} ${ZLIB_LIBRARIES} ${MINIZIP_LIBRARIES} ${CURL_LIBRARIES} pthread ${LUA_LIBRARIES} ${MQTT_LIBRARIES} ${SQLite_LIBRARIES} ${CMAKE_DL_LIBS} ${TELLDUS_LIBRARIES} ${EXECINFO_LIBRARIES})
else()
  target_link_libraries(domoticz -lrt ${Boost_LIBRARIES} ${ZLIB_LIBRARIES} ${MINIZIP_LIBRARIES} ${CURL_LIBRARIES} pthread ${LUA_LIBRARIES} ${MQTT_LIBRARIES} ${SQLite_LIBRARIES} ${CMAKE_DL_LIBS} ${TELLDUS_LIBRARIES} ${EXECINFO_LIBRARIES})
ENDIF()
ADD_PRECOMPILED_HEADER(domoticz "main/stdafx.h")
  option(USE_STATIC_LIBSTDCXX "Build with static libgcc/libstdc++ libraries" YES)
  IF(USE_STATIC_LIBSTDCXX)
    message(STATUS "Using static libgcc/libstdc++")
    SET(CMAKE_SHARED_LIBRARY_LINK_C_FLAGS "${CMAKE_SHARED_LIBRARY_LINK_C_FLAGS} -static-libgcc -static-libstdc++")
    SET(CMAKE_SHARED_LIBRARY_LINK_CXX_FLAGS "${CMAKE_SHARED_LIBRARY_LINK_CXX_FLAGS} -static-libgcc -static-libstdc++")
    SET(CMAKE_CXX_LINK_FLAGS "${CMAKE_CXX_LINK_FLAGS} -static-libgcc -static-libstdc++")
  ELSE(USE_STATIC_LIBSTDCXX)
    message(STATUS "Using dynamic libgcc_s/libstdc++")
  ENDIF(USE_STATIC_LIBSTDCXX)
# build a CPack driven installer package
INCLUDE(InstallRequiredSystemLibraries)
SET(CPACK_GENERATOR "DEB")
SET(CPACK_PACKAGE_NAME "domoticz")
SET(CPACK_PACKAGE_DESCRIPTION_SUMMARY "${domoticz}-Home Automation System (Domotica).")
SET(CPACK_PACKAGE_VENDOR "Domoticz.com")
SET(CPACK_PACKAGE_CONTACT "[email protected]")
SET(CPACK_RESOURCE_FILE_LICENSE "${CMAKE_CURRENT_SOURCE_DIR}/License.txt")
SET(CPACK_PACKAGE_VERSION_MAJOR "${domoticz_VERSION_MAJOR}")
SET(CPACK_PACKAGE_VERSION_MINOR "${domoticz_VERSION_MINOR}")
SET(CPACK_PACKAGE_VERSION_PATCH "${domoticz_VERSION_PATCH}")
SET(CPACK_PACKAGE_INSTALL_DIRECTORY "domoticz")
#SET (DOMOTICZ_VERSION_SHORT "${domoticz_VERSION_MAJOR}.${domoticz_VERSION_MINOR}.${domoticz_VERSION_PATCH}")
#SET(CPACK_PACKAGE_FILE_NAME "domoticz-${DOMOTICZ_VERSION_SHORT}-${CMAKE_SYSTEM_NAME}")
SET(CPACK_SOURCE_PACKAGE_FILE_NAME "${domoticz}-dev")
SET(CPACK_PACKAGING_INSTALL_PREFIX "/")
SET(CPACK_PACKAGE_DEFAULT_LOCATION "/opt/${CPACK_PACKAGE_NAME}")
SET(CPACK_PACKAGE_EXECUTABLES "domoticz;Home Automation System (Domotica).")
#set(CPACK_DEB_COMPONENT_INSTALL TRUE)
SET(CPACK_DEBIAN_ARCHITECTURE ${CMAKE_SYSTEM_PROCESSOR})
INCLUDE(CPack)
IF(CMAKE_INSTALL_PREFIX_INITIALIZED_TO_DEFAULT)
  set(CMAKE_INSTALL_PREFIX "/opt/${CPACK_PACKAGE_NAME}" CACHE PATH "Install path prefix, prepended onto install directories." FORCE)
ENDIF(CMAKE_INSTALL_PREFIX_INITIALIZED_TO_DEFAULT)
install(TARGETS domoticz DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/www DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/License.txt DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/History.txt DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/server_cert.pem DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/scripts DESTINATION ${CMAKE_INSTALL_PREFIX} USE_SOURCE_PERMISSIONS)
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/plugins DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/Config DESTINATION ${CMAKE_INSTALL_PREFIX})
install(DIRECTORY ${CMAKE_CURRENT_SOURCE_DIR}/dzVents DESTINATION ${CMAKE_INSTALL_PREFIX})
install(FILES ${CMAKE_CURRENT_SOURCE_DIR}/updatedomo DESTINATION ${CMAKE_INSTALL_PREFIX} PERMISSIONS OWNER_EXECUTE OWNER_WRITE OWNER_READ GROUP_EXECUTE GROUP_READ)
Hope it can help
Runs fine on ODroid N2 4Gb Ubuntu 18.04 LTS except V2020.1
GJvdP
Domoticz version: 2022.1
Post by GJvdP »
I have the same problem. I tried to view my domoticz pages but could not get past the pop-up that told me to ugrade to 2020-1.
No notes on having to install a new OS first. Now my system doesn't work. No back-up made.
So pls advice with detailed instructions on either:
1 - revert to the previous version of Domoticz
2 - how to upgrade to the lastest Debian/Raspian version in order to get Domoticz working
I still have acces to my RP3+ through Putty and/or Winscp.
I hope anyone can help/
For future releases pls add the option not to install the update (was not possible this time) or warn the people that a needs an updated version of the OS to work. I had a perfect working system before this happened. :cry:
Decided to go ahead and try to upgrade to Buster on my Pi3+
Followed the outlines on the following site:
https://pimylifeup.com/upgrade-raspbian ... an-buster/
This indeed upgraded Stretch to Buster.
But Domoticz 2020.1 was still unreachable, but running updaterelease in the domoticz directory (through the terminal server) fixed that problem.
Happy times !!!!
zenodalla
Domoticz version: 4
Post by zenodalla »
Domange wrote: Tuesday 24 March 2020 21:36 I choose the version tagged 4.10726 on the source control
What do you mean?
Meanwhile I tried to install ver. 4.10717 -> fail and 4.10659 -> fail. I had problem because of boost. Actually in CMakeLists.txt there's this line:
I've found a issue post on github (obviously now I can't find it :roll: ) in which someone had same error, about the version of boost. I edited 10600 and replaced with 1.6.0 I don't know if this can be a problem.
After that I can successfully run this command
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt -DUSE_OPENSSL_STATIC="NO"
make
but when i type make at a certain point it "freezes" to this line
Building CXX object CMakeFiles/domoticz.dir/main/EventSystem.cpp.o
I don't know what I'm doing wrong, I'll try to find other solutions.
edit: now I'm trying to compile ver4.9700 but it gets stucked at this line:
[ 26%] Building CXX object CMakeFiles/domoticz.dir/main/WebServer.cpp.o
cc1plus: warning: ./stdafx.h.gch/.c++: not used because `BOOST_ALL_NO_LIB' is defined [-Winvalid-pch]
Domange
Post by Domange »
I choose the version V4.10717 by a checkout on the label "4.10717"
I think you have some trouble trouble with the BOOST library.
Have you any error when you have generated it ?
Maybe am I lucky but I don't have any problem to generate it....
zenodalla
Domoticz version: 4
Post by zenodalla »
no, it seemed to be ok when I generated it. I found this old sd card with an installation of ver 4.10717 so I simply copied the folder. :)
freijn
Domoticz version: Stable
Post by freijn »
Copy the domoticz.sb from your crashed SD card and playback to the older version.
Calzor Suzay
Domoticz version: 4.9700
Post by Calzor Suzay »
zenodalla wrote: Sunday 29 March 2020 20:07 no, it seemed to be ok when I generated it. I found this old sd card with an installation of ver 4.10717 so I simply copied the folder. :)
Was it the arm7l version? Can you upload the directory online to be downloaded?
I have the same issue and need the old folder back...
zenodalla
Domoticz version: 4
Post by zenodalla »
I don't think the RPi3b+ is arm7l. I'm sorry.
Calzor Suzay
Think it is, the main download page says "Arm 32bit(Raspberry/Cubie/...) and if you hover over the file to download it's called domoticz_linux_armv7l.tgz
Do you have this file for the previous stable release or anyone else for that matter?
trissbe
Post by trissbe »
Same at my installation.
But I was stuck at; Linking CXX executable domoticz, it appeared that OpenZwave 1.6 was blocking my installation, so I did the following steps to install 1.4;
rm -rf open-zwave-read-only/
git clone https://github.com/OpenZWave/open-zwave.git open-zwave-read-only
cd open-zwave-read-only
git checkout v1.4-3335-g74e0598
make
sudo make install
After this installation I have finally a running copy of version 4.10693
But I still experience the error about driver failed :evil:
2020-04-20 17:49:44.225 Status: Domoticz V4.10659 (c)2012-2019 GizMoCuz
2020-04-20 17:49:44.225 Status: Build Hash: 649306c4d-modified, Date: 2019-05-06 10:27:06
2020-04-20 17:49:44.225 Status: Startup Path: /home/pi/domoticz/
2020-04-20 17:49:44.294 Sunrise: 05:37:00 SunSet: 19:48:00
2020-04-20 17:49:44.294 Day length: 14:11:00 Sun at south: 12:43:00
2020-04-20 17:49:44.294 Civil twilight start: 05:01:00 Civil twilight end: 20:24:00
2020-04-20 17:49:44.294 Nautical twilight start: 04:16:00 Nautical twilight end: 21:09:00
2020-04-20 17:49:44.294 Astronomical twilight start: 03:25:00 Astronomical twilight end: 22:01:00
2020-04-20 17:49:44.372 Status: PluginSystem: Started, Python version '3.7.3'.
2020-04-20 17:49:44.373 Status: Philips Hue: Using default poll interval of 10 secs.
2020-04-20 17:49:44.382 Active notification Subsystems: (0/13)
2020-04-20 17:49:44.383 Status: WebServer(HTTP) started on address: :: with port 8080
2020-04-20 17:49:44.402 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2020-04-20 17:49:44.402 Error: WebServer(SSL) check privileges for opening ports below 1024
2020-04-20 17:49:44.403 Status: Proxymanager started.
2020-04-20 17:49:44.404 Status: Camera: settings (re)loaded
2020-04-20 17:49:44.405 Starting shared server on: :::2224
2020-04-20 17:49:44.405 Status: TCPServer: shared server started...
2020-04-20 17:49:44.406 Status: RxQueue: queue worker started...
2020-04-20 17:49:46.407 Status: WOL: Started
2020-04-20 17:49:46.408 Status: Philips Hue: Worker started...
2020-04-20 17:49:46.408 Status: Nest: Worker started...
2020-04-20 17:49:46.408 Status: Panasonic Plugin: Started
2020-04-20 17:49:46.409 Status: SolarEdgeAPI Worker started...
2020-04-20 17:49:46.410 Status: EventSystem: reset all events...
2020-04-20 17:49:46.412 Status: EventSystem: reset all device statuses...
2020-04-20 17:49:46.509 Status: Panasonic Plugin: (Living) Starting thread.
2020-04-20 17:49:46.510 Status: Panasonic Plugin: (Living) started.
2020-04-20 17:49:46.522 Status: Python EventSystem: Initalizing event module.
2020-04-20 17:49:46.523 Status: EventSystem: Started
2020-04-20 17:49:46.524 Status: EventSystem: Queue thread started...
2020-04-20 17:49:46.797 Status: PluginSystem: Entering work loop.
2020-04-20 17:49:46.910 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2020-04-20 17:49:46.913 Always, OpenZwave Version 1.4.3335 Starting Up
2020-04-20 17:49:46.914 Status: OpenZWave: Starting...
2020-04-20 17:49:46.914 Status: OpenZWave: Version: 1.4-3335-g74e05982-dirty
2020-04-20 17:49:46.915 Error: OpenZWave: Driver Failed!!
*edit*
*using Razberry with firmware 5.36 on a PI
pinknemo13
Post by pinknemo13 »
freijn wrote: Sunday 29 March 2020 20:36 Copy the domoticz.sb from your crashed SD card and playback to the older version.
Thanks but can you share more info about it? Thanks in advance.
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
