to my crontab but the nest devices are not updating so probably the code does not work. See below my crontab entries, anyones spots a problem?
did you try a call by hand?, to see if there are errors: first the read-call:
php get_nest.php
then the call to update a device, example here is for the away,heat or eco device (replace IDX for the number of 1 of your devices:
curl -X GET "http://127.0.0.1/json.htm?type=command& ... itchcmd=On"
(don't forget to remove the cache files if you use a different user, see the readme)
krizzz wrote: ↑Monday 09 March 2020 20:39
0 10 * * * sudo ~/domoticz/scripts/speedtest.sh
0 22 * * * sudo ~/domoticz/scripts/speedtest.sh
*/5 * * * * /home/pi/nest-api/get_nest.sh >/dev/null 2>&1[/code]
And Yes, the speedtest.sh file works fine
what is the content of the speedtest script?
get_nest.sh and the dzvents script are consuming a bit cpu when running, but this is very short, but if you measure cpu exact the same time, you get wrong results, as said before in this treath, a lot of people (also on the "High CPU usage with node" issue) are using top, top is a nice tool to see top-processes and to look at the wait-io,but not usable to measure cpu-usage.
(This is always the problemen if you take a sample, while other processes are running)
on unix the best way to do reliable cpu performance measurement,is sar (e.q. "sar 60 100")
more about sar: https://www.raspberrypi.org/forums/view ... hp?t=72274
28% because of this script, unless something is wrong, looks impossible to me, see also the post in this threat from "01 Mar 2020, 17:21"
my old pi2, with a lot of stuff running on it, Domoticz, 2 node instances, mqtt broker, 123solar, a lot of cron-scripts and cacti uses about 15%
Hi Roland,
Just to answer your first question:
php get_nest.php
for those who are using my nest-api script, and have problems,
you can call it now with "-d" option for extra debug info, see the readme: https://github.com/rolandbreedveld/nest-api
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
het is een hele lange variable, de xxxxx staan voor de rest
I looked up the method again on your GitHub how to get the token. I tried various time the same procedure, and I really do not think I have done anything wrong. Please see below the part I copy paste into the nest.auth.php file:
krizzz wrote: ↑Friday 20 March 2020 22:16
it is correct right?
Looks good,but I think this error shows not a wrong token but a typo-failure, like if you forgot something like the '; on the end
I double checked it, but the '; paramaters are set perfectly. So this isn't also it.
I do noticed something in the nest-api folder. Other PHP files are getting a color. The nest.auth.php file does not. I do not know If this is strange behaviour?
krizzz wrote: ↑Saturday 21 March 2020 13:35
I have problem with functioning of plugin.
What works perfectly:
1) connecting to Nest servers
2) creating devices
3) refreshing status changed remotely on all 5 devices
4) setting up thermostat temperature
5) switching home/away
not working
1) switching heating on/off -> switch does not change inside domoticz and do not change nest thermostat setting
2) switch eco on/off -> switch does not change inside domoticz and do not change nest thermostat setting
I attach log:
"2020-03-22 14:22:57.206 (Nest) Start thread Push
2020-03-22 14:22:57.175 Status: User: admin initiated a switch command
(318/Nest - Hallway Away/On)
2020-03-22 14:22:58.082 (Nest - Hallway Away) Updating device from
0:'0' to have values 1:'1'.
2020-03-22 14:22:58.088 (Nest) Update Nest - Hallway Away: 1 - '1'
2020-03-22 14:22:58.088 (Nest) End thread Push
2020-03-22 14:23:00.685 (Nest) Pushing 'onCommandCallback' on to queue
2020-03-22 14:23:00.729 (Nest) Processing 'onCommandCallback' message
2020-03-22 14:23:00.729 (Nest) Calling message handler 'onCommand'.
2020-03-22 14:23:00.729 (Nest) onCommand called for Unit 1: Parameter
'Off', Level: 1
2020-03-22 14:23:00.729 (Nest) Hallway - Nest - Hallway Heating
2020-03-22 14:23:00.685 Status: User: admin initiated a switch command
(317/Nest - Hallway Heating/Off)
2020-03-22 14:23:01.790 (Nest) Pushing 'onCommandCallback' on to queue
2020-03-22 14:23:01.790 Status: User: admin initiated a switch command
(319/Nest - Hallway Eco mode/On)
2020-03-22 14:23:02.697 (Nest) End thread Push
2020-03-22 14:23:04.215 (Nest) Pushing 'onHeartbeatCallback' on to queue
2020-03-22 14:23:04.250 (Nest) Processing 'onHeartbeatCallback' message
2020-03-22 14:23:04.250 (Nest) Calling message handler 'onHeartbeat'.
2020-03-22 14:23:04.250 (Nest) onHeartbeat called
2020-03-22 14:23:04.251 (Nest) Start thread
2020-03-22 14:23:04.251 (Nest) Thread: GetNestCredentials done
2020-03-22 14:23:04.980 (Nest) Thread: GetDevicesAndStatus done
2020-03-22 14:23:04.980 (Nest) End thread"
rolandbreedveld wrote: ↑Saturday 21 March 2020 16:14
My setpoint device is called "Nest", so you perhaps you need to change it.
Better don't use spaces in the device names if you call them from dzvents event's. I had a couple of times problems with this, removing the spaces solved it.
You can change it like this:
-- Nest SetPoint
-- dzVents script for updatting SetPoint of Nest thermostat with Google account
-- [email protected]
-- the name of my device is "Nest", change it if you likei, on both places.
local Nest = 'Przedpokój termostat'
return{
devices = {
Nest
local setpoint = tostring(domoticz.devices(Nest).setPoint)
print("Nest Setpoint Called, change SetPoint to :" .. setpoint .. " ...")
cmd = "/usr/bin/php /home/pi/nest-api/nest_setpoint.php " .. setpoint
os.execute(cmd)
Then you can haver any name with any signs with spaces etc and dzvents will work flawlessly and it is easier to explain what to change
Did you solve the problem?
This morning I suddenly have the same issue, re-checked the token and cookie but didn't solve. Was working everything correctly a few days ago.
rolandbreedveld wrote: ↑Saturday 21 March 2020 11:38
Today I had the same issue, if you run "get_nest.sh", or "php get_nest.php"
PHP Fatal error: Uncaught exception 'UnexpectedValueException' with message 'Response to login request doesn't contain required access token. Response: {"error":"USER_LOGGED_OUT","detail":"No active session found."}' in /home/pi/nest-api/nest.class.php:1100
for some reason the token and cookie stopped working after running fine for 2 months in my case
Did the steps in the readme again, don't forget to logout/login on the nest site, replaced the cookie and token with new ones, and it's working fine again.
But after fixing my crontab entry, the problem was that I added the script into the pi crontab and not root crontab, all devices are being updated. Also controlling al o the devices do change my Nest thermostat! So all is working, so why the strange error when executing the nest.auth.ph file. I don't know!
you can't run nest.auth.php, this is a config file.
if you use different users, be sure you delete the cache files, see the readme https://github.com/rolandbreedveld/nest-api
thanks for this, this is working well, on my debian VirtualBox. Only issue I have: every 5 mintes, the cron job changes the home/away status of the Nest. Any thoughts on how to solve?
LarsK wrote: ↑Saturday 28 March 2020 11:44
Thanks, Lars
run the script in debug mode “get_nest.sh -d”
