RGB switch and Lua script
Tamanar
Post by Tamanar »
Hi!
I want to use an wemos d1 mini as a master and an arduino as slave to make a clock.
The clock use an RGB strip led (ws2812b). I only need to send information to the arduino with a serial liason. (because I already a code with bluetooth)
Because of that i have to program myself the wemos and not use a firmware.
With many tutorial i finally speak with my board and i can send an on/Off signal with the RGB switch: Image Image
One of help found give me a lua script which i have done some changes to send the right URL to my board.
DomDevice = 'P1'; -- Votre peripherique à controler
IP = '192.168.0.32'; -- L'adresse IP de l'ESP8266
PIN = "20"; -- Le pin GPIO du servo
if devicechanged['P1'] then
   if(devicechanged[DomDevice]=='Off') then
       print ("OFF dim = "..DomDevice);
        CalcValue = 0x00;
    else if(devicechanged[DomDevice]=='On') then
        print ("ON dim = "..DomDevice);
        CalcValue = 0xFFFFF;
        print("Other");
        DomValue = otherdevices_svalues[DomDevice];
        CalcValue=DomValue;
        --commandArray['Variable:dimmer'] = tostring(DomValue);
        print ("dim Level = "..CalcValue);
    runcommand = "http://" .. IP .. "/gpio?id="  ..PIN.. "&etat="..CalcValue .. "&token=123abCde"; -- Commande de Led
    print(runcommand);
    commandArray['OpenURL']=runcommand;
    print("PWM value= "..CalcValue);
But something that i can't find on the internet is that i can't get the RGB value of the color wheel.
I see on the log one i make a changes on the color wheel this:
2020-03-16 13:14:30.534 Status: setcolbrightnessvalue: ID: 1, bri: 50, color: '{m: 3, RGB: 9dff96, CWWW: 0000, CT: 0}'
2020-03-16 13:14:30.569 Status: LUA: Other
2020-03-16 13:14:30.569 Status: LUA: dim Level = 50
2020-03-16 13:14:30.569 Status: LUA: http://192.168.0.32/gpio?id=20&etat=50&token=123abCde
2020-03-16 13:14:30.570 Status: LUA: PWM value= 50
2020-03-16 13:14:30.570 Status: EventSystem: Fetching URL http://192.168.0.32/gpio?id=20&etat=50&token=123abCde after 0.2 seconds...
2020-03-16 13:14:30.570 Status: EventSystem: Script event triggered: RGBSwitch
2020-03-16 13:14:33.968 Error: Error opening url: http://192.168.0.32/gpio?id=20&etat=50&token=123abCde
2020-03-16 13:15:00.377 Error: EventSystem: in RGBSwitch: [string "-- Merci @MikeF : https://www.domoticz.com/fo..."]:11: attempt to index global 'devicechanged' (a nil value)
So what i undestand is that
give me the brightness of the switch. But i'm interested in the RGB value (here 9dff96)
To resume
How can i get the RGB value of the RGB switch?
And my two more questions which are less important is :
what does mean the two last Error ?
The first one, i suppose that it can't open the link, but it triggered anyway the board, so it's a "non-error"
And the second one (which i get aproximatly every minutes) i suppose it's because i try to check on the device change list, but because i haven't any devices i got an error. So again a "non-error"
Thanks in advance for any help you can provide.
Tamanar
Re: RGB switch and Lua script
Post by Tamanar »
Quick update.
When i triggered my script on device i only got one error:
2020-03-17 09:19:19.480 Error: Error opening url: http://192.168.0.32/gpio?id=20&etat=88&token=123abCde
So i delete one of the two error \o/
But i still can't access to the data i need...
Tamanar wrote: Tuesday 17 March 2020 9:21 But i still can't access to the data i need...
I have no clue how to get the color data in classic Lua but in dzVents you would use something like
device.color
it returns a JSON like
{"b":0,"cw":255,"g":0,"m":2,"r":0,"t":160,"ww":255}
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
Tamanar
Post by Tamanar »
Hi!
Well i get what you said, but i can't access to each individual color. (i'am more than a beginner on Dzevent and Json)
and what is the equivalent for
Or how can i send an http request with dzevent ?
Thanks for your help
Tamanar wrote: Tuesday 17 March 2020 20:33 Or how can i send an http request with dzevent ?
Hope that this example will get you going.
DomDevice = 'P1' -- Votre peripherique à controler
IP = '192.168.0.32' -- L'adresse IP de l'ESP8266
PIN = "20" -- Le pin GPIO du servo
return
    on =
        devices =
            DomDevice,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = color,
    execute = function(dz, item)
        dz.log('State of ' .. item.name .. ' is: ' .. item.state, dz.LOG_DEBUG )
        local CalcValue, DomValue
        if item.state == 'Off' then
           CalcValue = 0x00
        elseif item.state == 'On' then
            CalcValue = 0xFFFFF
            dz.log('dimlevel of ' .. item.name .. ' is' .. tostring(item.level),dz.LOG_DEBUG )
            CalcValue = item.level
        local url = "http://" .. IP .. "/gpio?id="  ..PIN.. "&etat="..CalcValue .. "&token=123abCde"; -- Commande de Led
        dz.openURL(url)
        dz.log('color of ' .. item.name .. ' is' .. item.color,dz.LOG_DEBUG )
        local colorTable = dz.utils.fromJSON(item.color)
        dz.utils.dumpTable(colorTable)
        dz.log('Colors of ' .. item.name ..
                'red: ' .. colorTable.r .. ', ' ..
                'green: ' .. colorTable.b .. ', ' ..
                'blue: ' .. colorTable.g .. '.',    dz.LOG_DEBUG)
