Dasticz only working on laptop, not on tablet Topic is solved
Boattailman
Post by Boattailman »
Installed dasticz on my pi a couple of days ago. So far so good but after two days of hard work on my laptop I wanted to see how it looked on my phone and ipad, well nothing. The ipad(chrome and safari) and my phone(chrome) both give an error. Tried my wife's ipad, also nothing while on her laptop everything showed up fine. The domoticz log shows an incoming connection so that's ok. My son get's on chrome on his phone an error, connection refused. I'm stuck here, someone with a brilliant idea?
var config = {}
config['domoticz_ip'] = 'https://192.168.0.124:443';
config['login_timeout'] = '60';
config['user_name'] = '0';
config['pass_word'] = '0';
config['room_plan'] = 0;
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen';
config['news_scroll_after'] = '7';
config['default_cors_url'] = 0;
config['dashticz_php_path'] = './vendor/dashticz/';
config['standby_call_url'] = 0;
config['standby_call_url_on_end'] = 0;
config['theme'] = 'default';
config['background_image'] = 'img/bg2.jpg';
config['standby_after'] = 0;
config['start_page'] = 1;
config['enable_swiper'] = '2';
config['vertical_scroll'] = '2';
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['blink_color'] = '255, 255, 255, 1';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'en_US';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 0;
config['gm_zoomlevel'] = 0;
config['gm_latitude'] = 0;
config['gm_longitude'] = 0;
config['speak_lang'] = 'en-US';
config['wu_api'] = 'f0df90d835cb4e0c9f90d835cb8e0cd6';
config['wu_city'] = '0';
config['wu_name'] = '0;
config['wu_country'] = 'NL';
config['owm_api'] = 0;
config['owm_city'] = 'Mainaschaff';
config['owm_name'] = 0;
config['owm_country'] = 'de';
config['owm_lang'] = 0;
config['owm_cnt'] = '4';
config['idx_moonpicture'] = 0;
config['longfonds_zipcode'] = 0;
config['longfonds_housenumber'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 0;
config['sonarr_url'] = 0;
config['sonarr_apikey'] = 0;
config['sonarr_maxitems'] = 0;
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = 0;
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = '0';
config['garbage_street'] = '0';
config['garbage_housenumber'] = '0';
config['garbage_housenumberadd'] = 0;
config['garbage_maxitems'] = '2';
config['garbage_width'] = 0;
config['setpoint_min'] = '5';
config['setpoint_max'] = '40';
config['evohome_status'] = 'Auto';
config['evohome_boost_zone'] = '60';
config['evohome_boost_hw'] = '15';
config['loginEnabled'] = 0;
config['disable_update_check'] = 0;
config['enable_websocket'] = 1;
config['no_rgb'] = 1;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['disable_googleanalytics'] = 0;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['security_button_icons'] = 0;
config['edit_mode'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['owm_days'] = 0;
config['owm_min'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
var blocks = {}
//var frames = {}
//frames.buienradar = {width:4,frameurl:"https://api.buienradar.nl/image/1.0/RadarMapNL?w=215&h=155"}
//Scenes
blocks[85] = {}
blocks[85]['width'] = 6;
blocks[85]['title'] = 'Eettafel';
blocks[85]['last_update'] = false;
blocks[85]['hide_data'] = true;
blocks[91] = {}
blocks[91]['width'] = 6;
blocks[91]['title'] = 'Schakelaar TVKamer';
blocks[91]['last_update'] = false;
blocks[91]['hide_data'] = true;
blocks[133] = {}
blocks[133]['width'] = 6;
blocks[133]['title'] = 'Schakelaar Tuin';
blocks[133]['last_update'] = false;
blocks[133]['hide_data'] = true;
//blocks[137] = {}
//blocks[137]['title'] = 'TVKamer Avond Scene';
//blocks[137]['last_update'] = false;
//blocks[137]['hide_data'] = true;
blocks[42] = {}
blocks[42]['width'] = 6;
blocks[42]['title'] = 'Schakelaar Keuken';
blocks[42]['last_update'] = false;
//Lampen
blocks[1] = {}
blocks[1]['width'] = 4;
blocks[1]['title'] = 'Plafond';
blocks[1]['last_update'] = false;
blocks[8] = {}
blocks[8]['width'] = 4;
blocks[8]['title'] = 'Keuken';
blocks[8]['last_update'] = false;
blocks[16] = {}
blocks[16]['width'] = 4;
blocks[16]['title'] = 'Eettafel';
blocks[16]['last_update'] = false;
blocks[17] = {}
blocks[17]['width'] = 4;
blocks[17]['title'] = 'Eettafel_2';
blocks[17]['last_update'] = false;
blocks[18] = {}
blocks[18]['width'] = 4;
blocks[18]['title'] = 'Eettafel_3';
blocks[18]['last_update'] = false;
blocks[19] = {}
blocks[19]['width'] = 4;
blocks[19]['title'] = 'Eettafel_4';
blocks[19]['last_update'] = false;
blocks[20] = {}
blocks[20]['width'] = 4;
blocks[20]['title'] = 'Eettafel_5';
blocks[20]['last_update'] = false;
blocks[26] = {}
blocks[26]['width'] = 4;
blocks[26]['title'] = 'Lamp Voor Buiten';
blocks[26]['last_update'] = false;
blocks[24] = {}
blocks[24]['width'] = 4;
blocks[24]['title'] = 'Aqua CO2';
blocks[24]['last_update'] = false;
blocks[14] = {}
blocks[14]['width'] = 6;
blocks[14]['title'] = 'Hue Mink';
blocks[14]['last_update'] = false;
blocks[2] = {}
blocks[2]['width'] = 6;
blocks[2]['title'] = 'Hal';
blocks[2]['last_update'] = false;
blocks[13] = {}
blocks[13]['width'] = 4;
blocks[13]['title'] = 'Hue Kachel';
blocks[13]['last_update'] = false;
blocks[12] = {}
blocks[12]['width'] = 4;
blocks[12]['title'] = 'Hue Strip Buiten';
blocks[12]['last_update'] = false;
blocks[23] = {}
blocks[23]['width'] = 4;
blocks[23]['title'] = 'Hue White Kast';
blocks[23]['last_update'] = false;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars Lampen';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Zonnepanelen';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Overig';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Weer';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Schakelaars Overig';
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'Overig';
blocks['blocktitle_7'] = {}
blocks['blocktitle_7']['type'] = 'blocktitle';
blocks['blocktitle_7']['title'] = 'Monitoring';
//Weer
blocks[28] = {}
blocks[28]['title'] = 'Voordeur Temp:';
blocks['35_1'] = {}
blocks['35_1']['title'] = 'Tuin Temp:';
blocks[38] = {}
blocks[38]['title'] = 'Tuin Regen:';
blocks['graph_46_2'] = { devices: ['46'],
title: 'Zonnepanelen',graph: 'bar',datasetColors: ['yellow']}
blocks[180] = {}
blocks[180]['title'] = 'Keukenraam Screen';
blocks[180]['last_update'] = false;
blocks[180]['width'] = 7;
//PI
blocks[79] = {}
blocks[79]['width'] = 4;
blocks[79]['title'] = 'PI CPU Usage';
blocks[79]['last_update'] = false;
blocks[80] = {}
blocks[80]['width'] = 4;
blocks[80]['title'] = 'PI Temp';
blocks[80]['last_update'] = false;
blocks[81] = {}
blocks[81]['width'] = 4;
blocks[81]['title'] = 'PI Memory Usage';
blocks[81]['last_update'] = false;
//columns defenition
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1', 2, 14, 91, 85, 133, 42,'blocktitle_5', 24, 180]
columns[1]['width'] = 3;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_2', 'graph_46_2', 'blocktitle_4', 28, '35_1', 38, 'sunrise']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_7', 'garbage', 79, 80, 81, 'log']
columns[3]['width'] = 4;
screens = {}
screens[1] = {
  columns: [1,2,3]
Version of dashtics is V3.4.0 beta.
freijn
Domoticz version: Stable
Re: Dasticz only working on laptop, not on tablet
Post by freijn »
Its worth showing the exact error as it can be anything.
Starting with the basics. Is the "normal" Domoticz page still reachable?
Lokonli
Post by Lokonli »
Boattailman wrote: Thursday 12 March 2020 19:03 Installed dasticz on my pi a couple of days ago. So far so good but after two days of hard work on my laptop I wanted to see how it looked on my phone and ipad, well nothing. The ipad(chrome and safari) and my phone(chrome) both give an error. Tried my wife's ipad, also nothing while on her laptop everything showed up fine. The domoticz log shows an incoming connection so that's ok. My son get's on chrome on his phone an error, connection refused. I'm stuck here, someone with a brilliant idea?
var config = {}
var blocks = {}
//var frames = {}
//Scenes
blocks[85] = {}
blocks[91] = {}
blocks[133] = {}
//blocks[137] = {}
blocks[42] = {}
//Lampen
blocks[1] = {}
blocks[8] = {}
blocks[16] = {}
blocks[17] = {}
blocks[18] = {}
blocks[19] = {}
blocks[20] = {}
blocks[26] = {}
blocks[24] = {}
blocks[14] = {}
blocks[2] = {}
blocks[13] = {}
blocks[12] = {}
blocks[23] = {}
//Weer
blocks[28] = {}
blocks['35_1'] = {}
blocks[38] = {}
blocks[180] = {}
//PI
blocks[79] = {}
blocks[80] = {}
blocks[81] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
screens = {}
screens[1] = {
  columns: [1,2,3]
How did you install Dashticz? Did you use the manual install method or the automatic install (and using the Docker image)? See the installation instructions at https://dashticz.readthedocs.io/
If you have installed Dashticz in the Domoticz www folder, then you only have access after login to Domoticz from the same client (which is not convenient ...)
Did you configure user authentication in Domoticz? Set it to basic-auth, or allow access for the local network, or temporarily disable authentication completely.
If you followed the installation instructions, and you are using Domoticz development branch, then try to add the following to your CONFIG.js:
Try with http instead of https for the Domoticz connection.
config['enable_websocket'] = 0;
or switch to master, via (in the Dashticz folder:)
git checkout master
Boattailman
Lokonli wrote: Thursday 12 March 2020 21:04
var config = {}
var blocks = {}
//var frames = {}
//Scenes
blocks[85] = {}
blocks[91] = {}
blocks[133] = {}
//blocks[137] = {}
blocks[42] = {}
//Lampen
blocks[1] = {}
blocks[8] = {}
blocks[16] = {}
blocks[17] = {}
blocks[18] = {}
blocks[19] = {}
blocks[20] = {}
blocks[26] = {}
blocks[24] = {}
blocks[14] = {}
blocks[2] = {}
blocks[13] = {}
blocks[12] = {}
blocks[23] = {}
//Weer
blocks[28] = {}
blocks['35_1'] = {}
blocks[38] = {}
blocks[180] = {}
//PI
blocks[79] = {}
blocks[80] = {}
blocks[81] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
screens = {}
screens[1] = {
  columns: [1,2,3]
Auto install
Nope
All done
Done, no change
Done, and now my solar panel graph is gone ;-(
git checkout master
The error is just a simple error message, error, for more help visit dashticz etc.....
Domoticz is working fine, on laptop and on ipad/phone
Lokonli
Post by Lokonli »
Boattailman wrote: Thursday 12 March 2020 21:48
var config = {}
var blocks = {}
//var frames = {}
//Scenes
blocks[85] = {}
blocks[91] = {}
blocks[133] = {}
//blocks[137] = {}
blocks[42] = {}
//Lampen
blocks[1] = {}
blocks[8] = {}
blocks[16] = {}
blocks[17] = {}
blocks[18] = {}
blocks[19] = {}
blocks[20] = {}
blocks[26] = {}
blocks[24] = {}
blocks[14] = {}
blocks[2] = {}
blocks[13] = {}
blocks[12] = {}
blocks[23] = {}
//Weer
blocks[28] = {}
blocks['35_1'] = {}
blocks[38] = {}
blocks[180] = {}
//PI
blocks[79] = {}
blocks[80] = {}
blocks[81] = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
screens = {}
screens[1] = {
  columns: [1,2,3]
Auto install
Nope
All done
Done, no change
git checkout master
Is the master version working ok on your ipad and phone? (excluding the graph)
Boattailman
No, same error, perfect on windows laptop and mac but no go on ipad en phones.
Lokonli
Post by Lokonli »
Can you remove the next two lines from CONFIG.js and retest?
Boattailman
Done, but still error on my phone and ipad. Even tried firefox, same error.
clinkadink
Post by clinkadink »
There are errors in your config.js is:
Missing a closing apostrophe - change this ...
To this ...
config['wu_name'] = '0';
Also, your graph block is incorrect, devices takes an array of integers, not strings - change this ...
To this ....
blocks['graph_46_2'] = { devices: [46],
Boattailman
Ah, your right thx, corrected this.The wu name was already fixed, but the graph (stupid) mistake fixed the errors on my tablet. Strange why this affected dashticz on my phone and ipad and not laptops. Anyway, thx all for helping!
clinkadink
Boattailman wrote: Friday 13 March 2020 10:12 Ah, your right thx, corrected this.The wu name was already fixed, but the graph (stupid) mistake fixed the errors on my tablet. Strange why this affected dashticz on my phone and ipad and not laptops. Anyway, thx all for helping!
Glad this is has now resolved the issue. At the top of this topic, please can you 'Accept this answer' with the tick button, thanks ;)
