Start script from API  [Solved]
DewGew
Domoticz version: V4.10618
Post by DewGew »
I want to start a timer device Q for X mins from domoticz api.
Is it possible to start a dzVents timer from domoticz API with a variables?
/json.htm?type=command&param=customevent&event=TIMER&data=X
Re: Start script from API  [Solved]
DewGew wrote: Monday 09 March 2020 17:18 I want to start a timer device Q for X mins from domoticz api.
Not with a timer( that's driven by the domoticz event system) but starting from dzVents 3.0.0 (domoticz V4.11687) you can trigger dzVents scripts with customEvents. See the wiki chapter
In your example the customEvent name will be TIMER and you can access the passed data in the script.
return
    on =
        customEvents = { 'TIMER' },
    -- your code here
DewGew
Post by DewGew »
I looking for similar like this:
return
    on =
    	domoticz.devices(item.data.IDX).switchOn().forSec(item.data.T)
Call the script with this:
/json.htm?type=command&param=customevent&event=TIMER&data={IDX=12,T=30}
DewGew wrote: Tuesday 10 March 2020 7:33 I looking for similar like this:
Close ..
return
    on =
    execute = function(dz, item)
        dz.devices(item.data.IDX).switchOn().forSec(item.data.T)
/json.htm?type=command&param=customevent&event=TIMER&data={"IDX":12,"T":30}
DewGew
Post by DewGew »
Great Thanks alot :)
DewGew
Post by DewGew »
waaren wrote: Tuesday 10 March 2020 8:28
Close ..
return
    on =
Do I cancel the time if I send a switchOn() or switchOff() within the time?
Do I update time if I send a forSec() within the time?
DewGew wrote: Tuesday 10 March 2020 11:39 Do I cancel the time if I send a switchOn() or switchOff() within the time?
No
No
The forSec is determined and set when the script executes and only the cancelQueuedCommand() will stop any scheduled actions.
Also be aware that the next state is also determined when the script executes initially. This might lead to unexpected results if the state changes within the time of the forSec.
That is why my personal preference is to use a combination of
cancelQueuedCommands()
switchOn()
switchOff().afterSec(xx)
because the behavior is predictable and not influenced by other commands.
DewGew
Post by DewGew »
Great thanks @waaren works like a charm :)
