Error in script  [Solved]
janpeetoom
Error in script
Post by janpeetoom »
Can anyone point me to the error in this script?
I don't see any :shock: .
return
    active = true
        timer = {
            'at 17:29 on fri'
execute = function(domoticz, timer)
    local esperessomachine = domoticz.devices('espressomachine')
    if (timer.trigger == 'at 18:45 on thu') then
        espressomachine.cancelQueuedCommands()
        espressomachine.switchOn()
This is the error get when the script is active:
Thanks in advance.
2020-03-06 17:28:00.413 ...domoticz/scripts/dzVents/generated_scripts/Script #2.lua:4: '}' expected (to close '{' at line 2) near 'on'
Re: Error in script
janpeetoom wrote: Friday 06 March 2020 17:35 Can anyone point me to the error in this script?
You forgot the , after active = true
freijn
Domoticz version: Stable
Re: Error in script
Post by freijn »
Not an expert but try this....
return
    active = true
        timer = {
            'at 17:29 on fri'
freijn
Re: Error in script
Post by freijn »
AAAaahhh Waaren never sleeps or is at Dinner :-)
janpeetoom
Re: Error in script  [Solved]
Thanks again.
There where also 2 writing errors in the script.
This is the working script:
return
    active = true,
        timer = {
            'at 18:15 on thu'
    local espressomachine = domoticz.devices('Espressomachine')
    if (timer.trigger == 'at 18:15 on thu') then
Re: Error in script
janpeetoom wrote: Saturday 07 March 2020 14:34 This is the working script:
If this is the complete and final script then I don't understand why you double check the timer rule.
This version would do the same.
return
        timer = {
            'at 18:15 on thu'
execute = function(domoticz)
janpeetoom
Re: Error in script
You are quite right Waaren.
Beginners unexperience :)
