I added a few pirs to my network that can be read by rfxcom.
They work wonderfull within my alarm system, all made with domoticz and iot devices.
After an alarm i can reset all my devices and smoke detectors but not de pirs.
I defined them as motion detectorsand i cant find a command to reset them (tried reset(), switchodd, close etc.)
@waaren, few months ago, you added a reset for my smoke detectors, and they work great!
Can you do that for PIRs also?
When i push the pir manually it dos go off and gives
0-03-05 13:58:18.201 Status: User: Admin initiated a switch command (2227/pir_aanbouw_small/No Motion)
2020-03-05 13:58:18.461 Status: dzVents: Debug: - Device: pir_aanbouw_small
2020-03-05 13:58:18.516 Status: dzVents: Info: Handling events for: "pir_aanbouw_small", value: "No Motion"
when i do a
http://192.168.20.35:82/json.htm?type=c ... &passcode=
it also works...
reset pir [Solved]
pvklink
- Domoticz version: latest b
reset pir
Jablotron connection, Ikea
- waaren
Re: reset pir
can you run this script before switching the PIRs off and after ?pvklink wrote: Thursday 05 March 2020 14:08 I defined them as motion detectors and i cant find a command to reset them (tried reset(), switchodd, close etc.)
That might help in identifying what command is required to switchOff the device using a native dzVents command.
return
on =
devices =
'motionTrigger', -- Rename to a test / development trigger
logging =
level = domoticz.LOG_INFO,
marker = motion,
execute = function(dz)
local motionDevices = dz.devices().filter(function(dv)
return dv.switchType == 'Motion Sensor'
end)
motionDevices.forEach(function(dv)
dz.log(dv.name .. ', state: ' .. dv.state .. ', sValue: ' .. dv.sValue .. ', nValue: ' .. dv.nValue)
end)
pvklink
Re: reset pir
Is this what you are looking for?
2020-03-05 15:53:59.681 (rfxcom) Security (xxx_aanbouw_small)
2020-03-05 15:53:59.674 Status: User: Admin initiated a switch command (2227/xxx_aanbouw_small/No Motion)
2020-03-05 15:54:00.021 Status: dzVents: Debug: - Device: xxx_aanbouw_small
2020-03-05 15:54:00.106 Status: dzVents: Info: Handling events for: "xxx_aanbouw_small", value: "No Motion"
2020-03-05 15:54:00.107 Status: dzVents: Info: ------ Start internal script: testscript: Device: "xxx_aanbouw_small (rfxcom)", Index: 2227
2020-03-05 15:54:00.390 Status: dzVents: Info: xxx_aanbouw_small, state: No Motion, sValue: No Motion, nValue: 5 Raspberry (raspbian on rpi 3) , Domoticz Beta, dzVents , RFXtrx433e, P1, Hue, Yeelight, Zwave+, X10, ESP(easy), MQTT,Weather Underground, System Alive Checker, Domoticz Remote Server to RPI with Google Assistant,
pvklink
Re: reset pir
i updated the previous message, i was playing around with different sort of devices (smoke etc,) to see if i can solve this..
For your script i changed back to motion type, and the outcome is above (in the previous post)
- waaren
Re: reset pir [Solved]
I have no PIR with these options so kind of hard to test, You could try withpvklink wrote: Thursday 05 March 2020 15:56 i updated the previous message, i was playing around with different sort of devices (smoke etc,) to see if i can solve this..
setState() or setValues() methods (see dzVents wiki for syntax)
If that does not work, the domoticz.openURL() will.
pvklink
Re: reset pir
ok, thanks, i will!
pvklink
Re: reset pir
Indeed, this did the job (better than pushing a url)!
Thanks @waaren
Solution
dz.devices('pir_aanbouw_small').setState('No Motion')
Thanks @waaren
Solution
