Interesting code, because it looks like it has a bit more options than I do.
For sake of completeness here's what I did:
bought:
NODEMCU:
https://www.elektor.nl/nodemcu-microcon ... 66-and-lua
CC1101:
https://www.ebay.com/itm/381475961886
Sensor:
https://www.weerstationkopen.nl/accesso ... kan-sensor (for RF-Link 433mhz connection)
Soldered as described here:
https://github.com/supersjimmie/IthoEcoFanRFT
Used Arduino IDE to upload code from klusjesman:
https://gathering.tweakers.net/forum/li ... /1690945/3
Tested with
http://ip/timer etc (see code)
Then I used domoticz as below:
Used this script for activating on humidity:
http://www.domoticz.com/wiki/Humidity_control
I ended up with two switches:
1 Virtual switch is being activated by humidity control script of wiki
2 Virtual switch which is being activated by blockly if (1) is on.
- 2a has a http command wich is send to esp8266 wich activates the timer each time it set to on.
- 2b has a timeout of 5 minutes (no action just switches the virtual switch off) after off, it wil check state of 1 again and stay off or just restarts the timer command.
So result of 2 is it wil activate the timer command each 5 minutes as long as virtual switch 1 is on. When 1 is off, it will finish the timmer of 10min and then stop.
- ESP.jpg (295.63 KiB) Viewed 15832 times
