OTA update on Ikea E1743 switch
EddyG
Post by EddyG »
I managed to OTA update the switch from firmware 2.1.022 to 2.2.008
Everything went fine but it took more the 1 hour to update the switch.
OTA works but very very slow.
pipiche
Re: OTA update on Ikea E1743 switch
Post by pipiche »
How did you do the update ? Which plugin and Zigbee key are you using ?
From timing perspective, I think this is basically how the OTA works and for battery based devices, it takes indeed some time and drain the battery
EddyG
Post by EddyG »
I am using zigbee2mqtt with a CC2531 stick on a Raspberry PI 3B+
To update the firmware I use the GUI Zigbee2MqttAssistant which is running on Docker on a Synology DS1517+
When there is new Firmware it is shown in Zigbee2MqttAssistant and then there is button to update.
In the zigbee2mqtt log the progress is shown every minute or so, like:
info  2020-03-04 10:15:34: Update of 'SchakelaarEddy' at 98.47%, +- 1 minutes remaining
info  2020-03-04 10:15:34: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"ota_update","message":"Update of 'SchakelaarEddy' at 98.47%, +- 1 minutes remaining","meta":{"status":"update_progress","device":"SchakelaarEddy","progress":98.47}}'
info  2020-03-04 10:16:05: Update of 'SchakelaarEddy' at 99.35%, +- 0 minutes remaining
info  2020-03-04 10:16:05: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"ota_update","message":"Update of 'SchakelaarEddy' at 99.35%, +- 0 minutes remaining","meta":{"status":"update_progress","device":"SchakelaarEddy","progress":99.35}}'
info  2020-03-04 10:17:00: Update of 'SchakelaarEddy' at 100%
info  2020-03-04 10:17:00: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"ota_update","message":"Update of 'SchakelaarEddy' at 100%","meta":{"status":"update_progress","device":"SchakelaarEddy","progress":100}}'
info  2020-03-04 10:17:15: Finished update of 'SchakelaarEddy'
info  2020-03-04 10:17:15: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"ota_update","message":"Finished update of 'SchakelaarEddy'","meta":{"status":"update_succeeded","device":"SchakelaarEddy","from":{"softwareBuildID":"2.2.008","dateCode":"20190410"},"to":null}}'
