I've setuped a Influxdb with docker and nginx in front.
I try to send data from Domoticz to Influxdb but it seems that https is not supported ?
Here is my setup:
remote address: influx.myserver.fr
port: 443
path:
database: domoticz
username: admin
password: password
Domoticz error: 2020-03-03 23:17:00.299 Error: InfluxLink: Error sending data to InfluxDB server! (check address/port/database/username/password)
If someone can help me with this.
BTW, it's working with Home Assistant, they have an ssl option.
Influxdb https
chatainsim
- Domoticz version: v4.11307
roblom
Re: Influxdb https
I know it's a while ago but I have the same problem so I was interested in if you solved it.
chatainsim
Re: Influxdb https
I have forget this option.
Got some servers for my home lab and got influxdb running locally.
So no Https/ssl need. Sorry.
roblom
Re: Influxdb https
I have it also running locally. It did work but without I didn't change anything it stopped working and throws this error.
- Domoticz version: 2025.1
Re: Influxdb https
Is your influxdb V1 or V2? For V2 you need Domoticz beta
https://www.domoticz.com/wiki/Influxdb
roblom
Re: Influxdb https
I have V2 with the latest Domoticz beta.
roblom
Re: Influxdb https
Correction, I did an assumption but I was wrong. I have version 1.8.9 running. Could this be the problem?
And if I try "influxd upgrade" I get
unknown command "upgrade" Run 'influxd help' for usage
Does anyone know a good update instruction?
Re: Influxdb https
Running V1 is still ok but you have to set the API V2 switch in hardware to off.
I have no influxdb so cannot help further.
roblom
Re: Influxdb https
On or off does not make any difference. Thanks for your tips anyway.
