I'm trying to create a tester for domoticz, in which does a series of actions, and in the end is checking if everything is in the correct state. I was planning to use a user_var to determine in what phase the test is, and what action then is needed.
But for some reason I can't get further than the next 'if statement'.
I created a smaller version which contain the same issue. It won't go to the 'if statement' with the scene_initial_phase = 2.
Can you help me what I do wrong?
switching on user var
netric
- Knipsel2.JPG (26.86 KiB) Viewed 391 times
- Knipsel.JPG (116.5 KiB) Viewed 391 times
wouterlet
Re: switching on user var
Changing a variable won't make your if work, if you make a dummy instead of a variable it might work...
