domoticz scripts
webrazor
domoticz scripts
My domoticz is broken after a update to the latest version. Now i want to do a compleet reinstall of raspbian and domoticz.
I have had some scripts running that where made in domoticz using lua. Is there a location on the sd-card where i can find these scripts to make a backup?
thank you
thank you
freijn
- Domoticz version: Stable
Re: domoticz scripts
/home/pi/domoticz/scripts/lua
if you do not see them there, they are in your database.
- jvdz
- Domoticz version: 4.107
They are either in the domoticz.db when created through the webinterface or in e directory /home/pi/domoticz/scripts/lua
Jos
Jos
webrazor
i made them in the web interface, any way to get them out of the database i still have a backup image of my Sd-card?
freijn
if you restore your last working domoticz.db into your fresh build image you will have your scripts back.webrazor wrote: Wednesday 26 February 2020 21:38 i made them in the web interface, any way to get them out of the database i still have a backup image of my Sd-card?
To be 100% save , grab the domoticz.db from your broken sd card as well. If you are lucky and nothing has changed in the .db you
also have your data history back.
webrazor
That sounds like a good plan, will try that. thxfreijn wrote: Wednesday 26 February 2020 22:26 if you restore your last working domoticz.db into your fresh build image you will have your scripts back.
- psubiaco
Hi.
Most probably your problem is caused by missing lib. I had the same problem.
The new versions of Domoticz required some libs from Raspbian Buster: to solve this issue, just follow the easy instructions at
https://www.domoticz.com/forum/viewtopi ... 40#p236428
Then you'll get everything working, without the need to reinstall Domoticz!
Paolo
Paolo
Paolo
webrazor
Will try that also, to get my data back and old image working. Thx.psubiaco wrote: Sunday 01 March 2020 21:34 Hi.
Paolo
That Dombus1 board that you are using sound really interesting. Are you happy with it?
webrazor
Is that the only file i need to restore all the old data?freijn wrote: Wednesday 26 February 2020 22:26 if you restore your last working domoticz.db into your fresh build image you will have your scripts back.
freijn
Can't tell you.......
I do have lots of other script in other places....
If you only created lua scripts from the webinterface the answer is yes.
But again.. doing so at your own risk!
I always have an aditional sd card. I leave the old card as it is. Re-building a fresh card.
If something is missing... Swap the old card back in , grab the required and go back to the new.
For a while I now have a production Raspberry and test lab... Makes live so much easier...
webrazor
I need something like that, because of domoticz is not working alot of stuff in the house is not working so thats a problem.
Better to make a backup first before update or change something.
