Run dzVents script manually  [Solved]
foogy
Post by foogy »
Is there a way to run dzVEnts scripts manually? Or to force a script to be executed?
If I for example have a script that run every minute
timer = {
'every minute'
During development and debugging I don't want to wait one minute for the script to be executed.
ronaldbro
Re: Run dzVents script manually
Post by ronaldbro »
You can use a dummy switch or another switch.
I have a dedicated Xioami button for debugging and add it to the "on device" list when I work on that script.
Tjeerd13
Re: Run dzVents script manually  [Solved]
Post by Tjeerd13 »
I use this for manual activate the switch with device idx 50
    on =
        timer =
            'every minute', -- just an example to trigger the request
        devices =
            50,              -- Just an on Switch to activated the script manualy for testing.
        httpResponses =
            scriptVar, -- must match with the callback passed to the openURL command
Pi3, Pi4, Pi4 for Testing, Dashticz, RFXtrx433, Nest: "Thermostat V2, V3, Hello". Honywell Lyric T6R, RFXCom, KaKu, HUE, P1, Open Zwave USB,
