Activate scene in which Fibaro Dimmer 2 is not used
appie76
Post by appie76 »
due to the layout of the switches and wiring in my house, I have ran into the problem below that I cannot figure out. I guess this is more a Fibaro-related issue and not so much a Domoticz issue, but perhaps there's a workaround (using some scripting) in Domoticz that will help.
PROBLEM:
I have a double toggle switch and a Fibaro Dimmer 2. One switch is connected to S1, the other to S2. So far, so good, but here's the thing: I need both S1 and S2 to activate scenes in which the connected light source is not used.
Activating the scenes is no problem, but the connected light always turns on/off and I don't want that: it should remain "as is".
(The reason for this being I have a similar setup elsewhere in the room that starts a scene that does include the aforementioned light, including some other lights.)
Is there anything I can do about this?
