Help With PIR No motion  [Solved]
BladeM3
Post by BladeM3 »
I've searched in many posts wikis etc and i got confused
There are many examples in lua which i find more difficult than dzvents (just managed to make 1 simple script with switch click to toggle group lights thanks to waaren! ) and a lot of scripts that make to complicated stuff so it's difficult to remove some functions
is there any example to help please?
if no PIR1 motion is not detected for 5 mins and Door_sensor switches to ON then Switch on Living_room lights (group)
Re: Help With PIR No motion
BladeM3 wrote: Sunday 23 February 2020 19:21 is there any example to help please?
One more example..
return
    on =
        devices =
            'Door_sensor',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = "Door PIR"
    execute = function(dz, item)
        if item.active then
            local PIR1 = dz.devices('PIR1')
            if not(PIR1.active) and PIR1.lastUpdate.secondsAgo > 300 then
                dz.groups('Living_room lights').switchOn()
BladeM3
Re: Help With PIR No motion  [Solved]
Post by BladeM3 »
REALLY? it was so simple? im reading all day for this too with time stamps and time difference checking and so complex things .. Thank GOD You are a saviour!!!! Thank you so much! Now i can make most of the scripts i need with the rest of the devices!
