Concatenating an URL with values from sensors. Topic is solved
radiochild
Post by radiochild »
Hi, I am running Domoticzs on a Synology NAS and I am trying to send a value to an ESPEasy LED display. I can send the dummy info, just as a straight number, e.g.
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..333 }
but I can't substitute a sensor value for the number, e.g.
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..sensortemp}
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'..['Sensor_Temperature']}
The errors usually relate to concatenation a global or things like that.
I don't understand the examples and other posts I have read. Can someone please explain if this can work or how to do it if it can't?
Re: Concatenating an URL with values from sensors.
radiochild wrote: Wednesday 11 July 2018 7:32 Hi, I am running Domoticzs on a Synology NAS and I am trying to send a value to an ESPEasy LED display. I can send the dummy info, just as a straight number, e.g.
Yes it can work. If you post the complete script it is easier to comment on what modifications are needed to get this to work.
radiochild
Hi Waaren, thanks for having a look for me.
-- Variables
baseurlESPEasy = "http://192.168.1.xx/control?cmd="
commandArray =  {}
if devicechanged['Undercot_Temperature'] then
This works.
I just can't figure out how to put a value from a sensor where the '333' is.
radiochild wrote: Wednesday 11 July 2018 12:13
-- Variables
commandArray =  {}
This works.
This will send the same as in your example with the temperature from sensor Undercot_Temperature. (dzVents)
-- Send Undercot Temp
    on =        {       devices   =   { "Undercot_Temperature" }},
    logging =   {       level   =   domoticz.LOG_DEBUG,
                        marker  =   "Send undercot" },
    execute = function(domoticz, undercot )
        local baseurlESPEasy = "http://192.168.1.xx/control?cmd="
        domoticz.openURL({
                            url = baseurlESPEasy .. "7dt" .. undercot.temperature,
                            method = "GET"
radiochild
Hi Waaren.
I tried your code and I get;
Error: EventSystem: in Portable LED Display: [string "-- Send Undercot Temp ..."]:6: attempt to index global 'domoticz' (a nil value)
I am using this in Events. I realise I didn't mention that before, does that make a difference?
jvdz
Domoticz version: 4.107
Post by jvdz »
So you have an LUA event script and you want to send the new received value for ... to ESPEASY....right?
Something like this should be close for a Device Lua event script:
commandArray =  {}
commandArray[1]={['OpenURL'] = baseurlESPEasy..'7dt,'.. devicechanged['Undercot_Temperature']}
.. but are you sure about that ESPEASY URL? Does that work directly from a browser?
Jos
radiochild
Hi jvdz,
Thank you! That worked a charm. The url works in a browser for ESPEasy. It now works in Domoticz. It's just an update to a MAX7219 LED display. So simple but I just couldn't figureit out.
Thank you again, Waaren and jvdz for helping me out.
radiochild wrote: Wednesday 11 July 2018 13:29 Hi Waaren.
Hi radioChild, my script is dzVents. Choose dzVents in the event editor and copy paste the script ..
MarloCZ
Post by MarloCZ »
Hello, please can someone advise me, I try the script written above, but my display shows nothing.
When I enter a command via URL, it will show up on the display.
Thanks for the help
    on =        {       devices   =   { "Outdoor_thermometer" }},
        local baseurlESPEasy = "http://192.168.7.71/control?cmd="
        domoticz.openURL({
                            url = baseurlESPEasy .. "7dt" .. Outdoor_thermometer,
                            method = "GET"
Device:
48 Dummy 14080 1 Outdoor_thermometer Temp LaCrosse TX3 2.7 C
LOG:
2020-02-19 06:57:59.694 Status: dzVents: Error (2.4.19): Send undercot: An error occured when calling event handler Displej-1
2020-02-19 06:57:59.694 Status: dzVents: Error (2.4.19): Send undercot: ...Domoticz\scripts\dzVents\generated_scripts/Displej-1.lua:13: attempt to concatenate global 'Outdoor_thermometer' (a nil value)
2020-02-19 06:57:59.694 Status: dzVents: Info: Send undercot: ------ Finished Displej-1
2020-02-19 06:58:02.679 EventSystem: Event triggered: Termostat-Loznice_2
MarloCZ wrote: Wednesday 19 February 2020 6:56 Hello, please can someone advise me, I try the script written above, but my display shows nothing.
You copied and paste some unexpected values.
Can you try this
-- Send temperature of a sensor to ESP Easy
return
    on =
        devices   =
            'Outdoor_thermometer',
    logging =
        marker = 'Temperature to ESPEasy'
    execute = function(dz, item)
        local ESPEasyURL = 'http://192.168.7.71/control?cmd='
        dz.openURL(
                url = ESPEasyURL .. '7dt,' .. item.temperature,
                method = 'GET',
MarloCZ
Post by MarloCZ »
Thank you very much for the modified script.
I turned it on, but the screen still doesn't show me anything :(
The extract from the log is as follows:
2020-02-19 13:06:25.489 Status: dzVents: Info: Handling events for: "Outdoor_thermometer", value: "5.06"
2020-02-19 13:06:25.490 Status: dzVents: Info: Temperature to ESPEasy: ------ Start internal script: Display-1: Device: "Outdoor_thermometer (Dummy)", Index: 48
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: url = http://192.168.7.71/control?cmd=7dt5.0599999427795
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: method = GET
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: post data = nil
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: headers = nil
2020-02-19 13:06:25.490 Status: dzVents: Debug: Temperature to ESPEasy: OpenURL: callback = nil
2020-02-19 13:06:25.491 Status: dzVents: Info: Temperature to ESPEasy: ------ Finished Display-1
MarloCZ
Post by MarloCZ »
So I figured it out - it works :)
There was no comma in 7dt,
Can I have another request, could it be done on the display alternate between two different temperatures - from outside and from inside thermometer - alternately ?
Thank you in advance for your help.
MarloCZ wrote: Wednesday 19 February 2020 13:22 Can I have another request, could it be done on the display alternate between two different temperatures - from outside and from inside thermometer - alternately ?
Could be something like
-- Send temperature of two sensors alternately to ESP Easy
return
    on =
        timer =
            'every minute',
    logging =
        local display
        if dz.time.minutes % 2 == 0 then
            display = dz.utils.round(dz.devices('Outdoor_thermometer').temperature,1)
            display = dz.utils.round(dz.devices('Indoor_thermometer').temperature,1)
        dz.openURL(
                url = ESPEasyURL .. '7dt,' .. display
                method = 'GET',
MarloCZ
Post by MarloCZ »
Thanks for the new script, but it reports me an error :(
2020-02-19 21:36:57.915 Status: dzVents: Error (2.4.19): error loading module 'Display-2' from file 'C:\Program Files (x86)\Domoticz\scripts\dzVents\generated_scripts/Display-2.lua':
2020-02-19 21:36:57.915 ...Domoticz\scripts\dzVents\generated_scripts/Display-2.lua:32: '}' expected (to close '{' at line 30) near 'method'
MarloCZ wrote: Wednesday 19 February 2020 21:43 Thanks for the new script, but it reports me an error :(
Sorry for that. I missed a comma after display.
can you try again ?
return
    on =
        timer =
            'every minute',
    logging =
        local display
        dz.openURL(
                url = ESPEasyURL .. '7dt,' .. display,
                method = 'GET',
MarloCZ
Post by MarloCZ »
Thank you, it works very well. ;)
I have one more request, is somehow done to change temperatures not after one minute, but after 5 (10) seconds :?:
Thank you
MarloCZ wrote: Thursday 20 February 2020 7:07 is somehow done to change temperatures not after one minute, but after 5 (10) seconds
Thank you
That's possible with the attached script. Please note that the temperature shown can be 50 seconds behind measured temperature. It is possible to have a real-time temperature with a different approach but that would require dzVents >= 3.0.0
-- Send temperature of two sensors alternately to ESP Easy every 10 seconds
local scriptVar = 'Temperature to ESPEasy'
return
    on =
        timer =
            'every minute',
    logging =
        marker = scriptVar,
        local display = {}
            display[0] = dz.utils.round(dz.devices('Outdoor_thermometer').temperature,1)
            display[1] = dz.utils.round(dz.devices('Indoor_thermometer').temperature,1)
        local function sendTemp(selector)
            temperature = display[selector % 2]
                dz.openURL(
                    url = ESPEasyURL .. '7dt,' .. temperature,
                    method = 'GET',
                }).afterSec(selector * 10)
        -- main
        for i = 0, 5 do
            sendTemp(i)
MarloCZ
Post by MarloCZ »
Thank you very much, it works great. ;)
MarloCZ wrote: Thursday 20 February 2020 17:37 Thank you very much, it works great. ;)
Show us a picture please ?
MarloCZ
Post by MarloCZ »
Picture of what? A picture of the display?
I am currently testing two adults, 7 numbers and 4 numbers.
https://uloz.to/file/Up42O3LzfwyK/2020- ... -40-50-jpg
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
