After trying to search some plugin to get the instant power and generated energy of my SMA Sunny Boy inverter 1.5 I've found nothing for domoticz or the solutions were for an inverter with MODBUS or similar.
Then came through a script in the openhab forum that, with the keys I captured for my device, worked fine. So, I've developed my own plugin, a very simple one but it works.
I don't have a github account, so far, then let me put in here just in case you want to use it, or even better, improve it.
- Spoiler: show
- # SMA Sunny Boy 1.5 Python Plugin for Domoticz
# Author: merlot
<plugin key="SunnyBoy15" name="SMA Sunny Boy 1.5 Solar Inverter" author="merlot" version="1.0.0">
<description>
<h2>SMA Sunny Boy 1.5 Solar Inverter Plugin</h2><br/>
<h3>Features</h3>
<ul style="list-style-type:square">
<li>Register instant power and dayly generated energy</li>
</ul>
</description>
<params>
<param field="Address" label="IP Address" width="200px" required="true"/>
<param field="Password" label="User group password" width="200px" required="true" password="true"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true"/>
</options>
</param>
</params>
</plugin>
import sys
sys.path.append('/usr/local/lib/python3.5/dist-packages/')
try:
import Domoticz
except ImportError:
import fakeDomoticz as Domoticz
import json
import requests
class BasePlugin:
enabled = False
lastPolled = 0
lastResponse = 0
def __init__(self):
return
def onStart(self):
Domoticz.Log("onStart called")
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
else:
Domoticz.Debugging(0)
if (len(Devices) == 0):
Domoticz.Device("pv watt", 1, "Custom", Options = { "Custom" : "1;W"}).Create()
Domoticz.Device("wh today", 2, "Custom", Options = { "Custom" : "1;Wh"}).Create()
Domoticz.Device("kwh total", 3, "Custom", Options = { "Custom" : "1;kWh"}).Create()
DumpConfigToLog()
Domoticz.Log("Plugin is started.")
# If Heartbeat>30 you'll get the error thread seems to have ended unexpectedly
# https://www.domoticz.com/wiki/Developin ... #Callbacks
Domoticz.Heartbeat(20)
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
Domoticz.Log("onConnect called")
def onMessage(self, Connection, Data, Status, Extra):
Domoticz.Log("onMessage called")
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Log("onDisconnect called")
def onHeartbeat(self):
Domoticz.Log("onHeartbeat called "+ str(self.lastPolled))
## Read SMA Inverter ##
url_base="http://" + Parameters["Address"] + "/dyn/"
url=url_base + "login.json"
payload = ('{"pass" : "' + Parameters["Password"] + '", "right" : "usr"}')
headers = {'Content-Type': 'application/json', 'Accept-Charset': 'UTF-8'}
self.lastPolled = self.lastPolled + 1
if (self.lastPolled > 3): self.lastPolled = 1
if (self.lastPolled == 1):
try:
r = requests.post(url, data=payload, headers=headers)
except:
Domoticz.Log("Error accessing SMA inverter on "+Parameters["Address"])
else:
j = json.loads(r.text)
try:
sid = j['result']['sid']
except:
Domoticz.Log("No response from SMA inverter on "+Parameters["Address"])
else:
url = url_base + "getValues.json?sid=" + sid
payload = ('{"destDev":[],"keys":["6400_00260100","6400_00262200","6100_40263F00"]}')
try:
except:
Domoticz.Log("No data from SMA inverter on "+Parameters["Address"])
else:
sma_pv_watt = j['result']['012F-730B00E6']['6100_40263F00']['1'][0]['val']
if sma_pv_watt is None:
sma_pv_watt = 0
sma_kwh_today = j['result']['012F-730B00E6']['6400_00262200']['1'][0]['val']
sma_kwh_total = j['result']['012F-730B00E6']['6400_00260100']['1'][0]['val']/1000
# Domoticz.Log(r.text)
# Domoticz.Log(str(sma_pv_watt))
# Domoticz.Log(str(sma_kwh_today))
Devices[1].Update(nValue=sma_pv_watt, sValue=str(sma_pv_watt))
Devices[2].Update(nValue=sma_kwh_today, sValue=str(sma_kwh_today))
sValue="%.2f" % sma_kwh_total
Devices[3].Update(nValue=0, sValue=sValue.replace('.',','))
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data, Status, Extra):
global _plugin
_plugin.onMessage(Connection, Data, Status, Extra)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
- create a directory under the plugin one, like SMA_Sunny_Boy
- copy&paste the code in a plugin.py file
- restart domoticz
- Add the device, introducing the IP and User group password
That's all
I have also updated to 4.10717 and I'm having some crashes, so I don't know if it's due to the plugin, that seems so simple to cause it, or it's the version since I've seen some other experiencing a similar issue.
Comments and improvements are welcome
Thank you
